Canon, where is your compact bokeh king?
Started 11 months ago | Discussions
Bas Hamstra Senior Member • Posts: 2,070
Which compact is the blur king? With F-stop equivalencies:
G1X    - F3.6 to F7  - 120mm tele
G1X2 - F3.6 to F11 - 120mm tele
G5X2 - F5.4 to F8.4 - 120mm tele
G7X3 - F5.4 to F8.4 - 100mm tele
MFT12-40 F5.6 to F5.6 - 80mm tele
Actually I thought the G1X series would have a bigger advantage here, but as you can see below the G7X3 keeps up well with the best G1X up till 100mm. The G5x2 then has the same range as the G1X-2, so these are comparable.
So it seems the LX100 still is the clear winner and outperforms for example an Olympus EM1.2 with 12-40PRO lens (in terms of DOF control).
But what is the limit? How much lower can we theoretically go in the graph below, still in a compact body? Well, the A7C is a fairly compact full frame camera, say with a pancake 40/2.8 type of prime (a la the existing Canon 40/2.8) it would seem like a dream machine. But Sony doesn't have it. But maybe even a fixed, folding zoomlens (a la G1 design) would be an option? Have they really hit a brick wall yet? Or havent they been trying?
Kind regards,
Bas Hamstra
 Bas Hamstra's gear list:Bas Hamstra's gear list
Canon EOS 5D Canon EOS 6D Olympus OM-D E-M10 Olympus E-M1 II Canon EF 35mm F1.4L USM +11 more
Olympus E-M1 Panasonic LX100
MyM6II Senior Member • Posts: 2,424
Re: Canon, where is your compact bokeh king?
Canon M200 + EF-M 22mm f/2.0 😃
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
OP Bas Hamstra Senior Member • Posts: 2,070
Interesting, and less expensive than the overpriced G5x. I don't know this line very well I must say, but its interesting. But the lens does stick out too much to be even coat pocketable. Anyway thanks for the pointer, IQ seems top notch.  So far I have had a couple of eye openers, for one thing I will no longer look for a G1X.
Bas
KEG
KEG Veteran Member • Posts: 4,910
Bas
I am able to stick M6 and EF-M 22 in my pocket.
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
AdamT
AdamT Forum Pro • Posts: 62,282
and the 11-22 gives a zoom to add if you have a large coat , its truly excellent and a breath of fresh air after the rest of the M zooms which range from very poor to barely OK . with the M6-II`s cropping abiity you get to extend the "reach" of the short 22mm end too ..
The G5X-II is actually a very good camera despite its 1st gen popup EVF and flaws which could be fixed in firmware (but canon won't of course as they never do) - its such a shame they had to follow Sony's lead on ludicrously overpricing these compacts , £499 I`d say was about right , £850 is so outrageously comical its not funny .. they are obtainable mint condition used from a dealer with warranty for £599 which is a lot better but still only £30 less than the groundbreaking G1X Mk1 was brand new at launch
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
KEG wrote:
Bas
Yeah, but what I see here looks sizewise too much like a MFT sized camera, which I already have. For me, as die hard used camera user, it would be probably cheaper for me to buy an old slim olympus body and put the 20mm/1.7 pancake on.
https://www.dpreview.com/forums/post/63256606
But still can't help to be intrigued by the G7X, I had so much fun for years using my old Ixus, and these later 1 inch cams seem to have gotten really good now. If I look at some samples here and there (I downloaded a couple my to regular favourite image viewer to be sure).
Bas
Are there any ones to avoid? I am willing to spend around 400EUR, and for that I see the following options:
  1. G7X mark II for around 300EUR
  2. G7X mark III for around 500EUR
  3. G7X mark I probably around 200EUR
  4. G5X mark I around 350EUR
The G5X mark II probably way above 500 or even 600 which I am not willing to spend.
My impression is that at least the G7X.3 and G5X.2 have rather good lenses. How about the G7X.2?
Kind regards,
Bas
AdamT
Prob the sweet spot as the Mk3 didn`t seem to add much of worth IMO as the Stacked sensor would appear to add little or nothing to these cameras (it's not as if they need it for fast PD-AF readout or 30 frames per second bursts with tracking and C-AF or anything) - the Mk3 is a lot more money but the RAW image quality of the MK1 is just as good and they are cheap on the used market - Mk2 added a bit more speed but for stills the mk1 is just as good, at least in RAW ..
  1. G5X mark I around 350EUR
this is a unique camera - basically a similar body to the G1X Mk3 and EOS-M5 but in 1" form with the G7X lens and Mk1 era processing - handles by far the best of the lot but is the same age as the G7X Mk1 so again, don`t expect a speed demon
All the G7X series and the G5X Mk1 have exactly the same lens .. it`s sharp and is the total opposite of the sony models in that its weakest at the widest end due to distortion , CA and black corners from the optics which needs correcting in camera or in RAW converter but it gets better and better as you zoom (amazingly good at 100mm even at F2.8 for instance) whereas the RX100 series are at their best at the wide end and get weaker and softer as you zoom especially at distance .
the G5X Mk2 has a newer better lens which has better more consistent optics though the range with less issues but is also weakest at the widest end, it gets better quicker than the G7X series lens .
All the Canon models have superb IS - something I found to be a weak point in the Sonys , I was amazed at how slow a shutter speed I could hold the LCD only G7X Mk1 let alone an EVF equipped model .. the touchscreens are superb and responsive too even in the MK1 cameras
F8AD Regular Member • Posts: 196
Bas
I don't think the G5X ( f/1.8-f/2.8) is overpriced ;it looks to be less of an expense than the M200,plus it has a viewfinder. It fits in a jacket pocket, but won't ever fit my pants pocket. I really enjoy mine.
Could you post a portrait/headshot with as much background blur as possible, if it's not too much trouble? Even better would be one with a head filling the frame and one  head+shoulders filling the frame.
Thanks in advance,
Bas
Thanks in advance,
Bas
  - Sorry , I rarely shoot portraits with the G5X . You may find some examples on Flickr when you search "G5X " and search in "photos" . It could help you decide.
Best of luck !
RLight Senior Member • Posts: 4,427
Kind regards,
Bas Hamstra
Compact and bokeh don’t usually go together due to the reality of optical physics. “Fast” lenses are not usually compact unless a compromise exists.
The Canon compact bokeh king is the G1X mark II, but, due to its archaic sensor and processor, I’d say the G5x Mark II is the only relevant Canon compact bokeh king.
The other is less obvious; an RP or M6II married to a fast prime. As I said about physics… Those are much larger offerings.
The LX100 is still the king of compacts, but like the G1X Mark II, it suffers due to sensor design… Despite it’s fast optic the LX100 suffers in low light. I think the best explanation I’ve heard as to why is poor amplification. That’s a thing I might add. Poor sensor design can rain on the parade of a larger sensor. Just ask Canon’s G1X mark II with its poor DR. Simple stuff can make or break an otherwise good thing.
 RLight's gear list:RLight's gear list
Canon EOS M6 II Canon EOS R3 Canon EOS R50 Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
Luis Gabriel Photography
Luis Gabriel Photography Senior Member • Posts: 2,607
Kind regards,
Bas Hamstra
I dont have one but a ZV-1 with the "bokeh button" looks pretty good from the samples I have seen. Of course its still only 70mm and no EVF so it does not feed my needs as a travel camera but in terms of bokeh smoothness, it could be a good option if the rest of it fits your needs.
 Luis Gabriel Photography's gear list:Luis Gabriel Photography's gear list
Canon EOS R5 Sigma 50mm F1.4 DG HSM | A Sigma 105mm F1.4 DG HSM Art Sony RX10 IV Nikon Coolpix P950 +2 more
Chris 222 Senior Member • Posts: 1,981
I respectfully disagree.
Having used them all, the best overall compact out there is (and probably will remain forever given the direction in which industry seems to be going) by far, the Canon G1X3. It outperforms the LX100 quite significantly (for both photos and videos.)
This is not geek talk, but actual user experience.
rita416
rita416 Regular Member • Posts: 420
But would this have Image Stabilization (I don't think so)? If it does, I would look into buying one.
Thanks, Rita
 rita416's gear list:rita416's gear list
Canon G7 X II Canon G9 X II
rita416
KEG wrote:
Bas
But no image stabilization, right? I have a tremor.
Thanks, Rita
lynnG Regular Member • Posts: 393
Kind regards,
Bas Hamstra
Your list is not quite right,
G1X, 28-112mm Equiv F2.8-5.8
G1X ii, 24-120mm equiv. F 2.0-3.9
Even you convert the aperture to full frame equivalent, I cannot understand why F number become F11 for G1Xii whilst G1X become F7. I have used most of those cameras. The best background blur (Not bokeh, Bokeh has more meanings than background separation) is Canon G1Xii at the end of tele zoom. Panasonic LX-100 has short zoom. The background separation at the end of zoom (70mm) is not as significant as what we could get from G1Xii. So far G1Xii is the king. Searching the sample photos in the internet, it is not difficult to figure this out.
I've seen samples that the G1X III "beats" the LX100 in low light despite the equivalence advantage the LX100 has. You're not going to get much fight from me arguing the Canon is better as a largely Canon shooter.
However in talking sheer bokeh rendering capability, it's the LX100 and G1X Mark II. I didn't say either of those cameras are better otherwise over the G1X III though...
strawbale Senior Member • Posts: 2,453
You're right - the list is wrong
Kind regards,
Bas Hamstra
You're right that the list is wrong - for 1.5" sensor (crop factor 1.92):
G1X i becomes f/5.4-10.8 (FF eq)
G1X ii becomes f/3.8-7.5 (FF eq)
