a refined 2D-to-3D conversion technique
Started Apr 25, 2022 | Discussions
uuglypher
uuglypher Regular Member • Posts: 250
comments? critiques?
Dave
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
threed123
threed123 Senior Member • Posts: 1,490
Re: a refined 2D-to-3D conversion technique
Looks good. Question is how you are doing it?
uuglypher
OP uuglypher Regular Member • Posts: 250
Th@nks, Threed;
I’m waiting for some more objective comments/critiques before broaching technique.
Best regards,
Dave
uuglypher
Wayne Gretzky
uuglypher
Here’s another set prepared by the same technique.
Comments? Critiques?
Dave
uuglypher
Wayne Gretzky
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
I found it somewhat uncomfortable (although possible) to fuse. When auto-aligning the pair with SPM, it removed all the distortions applied to the "original", by the following corrections:
and the result was almost dead flat (with a slight tilt of a flat plane towards the bottom):
So it appears that most of the "conversion" was performed by distorting the original along the vertical axis.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
uuglypher
Insert caption here. If you do not edit this text it will be automatically removed.
Hi, Wayne,
As is the usual case with those of us over age 65, only 27% are reported* to experience full binocular depth perception (BDP) ; the remaining 73% ranged between just subnormal BDP to “stereo blind”*. Our BDP, on average, begins to decline in our fifth decade , and among those functions that often evidence age-related decline is ease of foveation of disparity displacements other than horizontal ( diagonal and vertical).. The geometric transformations involved in the examples of 2D-to-3D conversion I posted in my original post do, indeed, impose some vertically and diagonally displaced disparities. As you demonstrate, elimination of most vertical and diagonal disparities result in an almost “flat” 3D illusion. If this forum includes any participant in their 40s or younger (who would likely be more competent foveators of vertical and diagonally displaced disparities) I would be eager to read of their degree of viewing success with the 3D image pairs I posted initially. Note that the image pair posted herewith (made with a standard technique used with anaglyphs) provides more realistic depth than does the pair you posted.
*Wright LA, Wormald RPL. Stereopsis and ageing. Eye 1992;6:473-6.
Best regards,
Dave
uuglypher
Wayne Gretzky
uuglypher
Here’s the image pair intended to have been included with the previous s post!
Sorry for the lapse!
uuglypher
Wayne Gretzky
Turbguy1
Actually, that second pair is more comfortable for me, although the "warping" of an otherwise flat plane is about all I can discern through stereopsis. I detect almost no "solidity" to facial features, although I can talk myself into them.
I suppose there can be some age-related degradation of our "cyclopian eye". Perhaps that partially explains why stereophotography is so "niche"? Some personal experience:
About two months ago, I had a sudden onset of binocular diplopia. Needless to say, stereopsis was a challenge. A trip to the ER for MRI and CT scans revealed nothing, and the ophthalmologist couldn't find anything either. I began vision therapy (those folks have some neat stereo toys!), and it has since totally resolved, although I credit aspirin and time, over therapy. Therapy consisted of fusing pairs that were displaced "all over the map", including divergence well beyond my interocular distance, and vertical displacements as well. I certainly "felt" both of those when taken to the extreme!
I think I floored the therapist when I volunteered words such as "stereopsis" , "retinal rivalry", "convergence/divergence", "accommodation" and other stereo terms.
Immediately after the onset, fusing stereo pairs via freeviewing was almost impossible (one eye's image was displaced vertically and rotated about 3 degrees). Attempting to process stereo pairs for postings/competitions was hard. Particularly when setting the stereo window!
It is of interest that there may be an association between loss of stereopsis and onset of dementia!
Have you had a Frisby stereotest? I am going to ask my therapist if she has one...
uuglypher
Hi, Wayne,
Thanks for looking and commenting.
I’m glad to hear that vision therapy got your diplopia under control. They can often do wonders rehabilitating binocular depth perception in geriatric patients.
I, too, experienced occasional diplopia as well as some minor foveation problems, but a week of regular bead-on-the-string workouts got me back in shape. Since then I have discovered that I usually prefer the results of crossed view over those of parallel, which was my standard viewing techniques for years.
Your comment re: fusing images “all over the place” suggests that the visual training has helped improve your foveation such that you are no longer as insistant on exclusively horizontal disparity displacements as you have been in the past.
I have a routine vision work-up scheduled for July and will have BDP checked. As for Frisby test. It has been well over a decade since that was used with me. I only remembered the name because of the “Mother Frisby pie tin” game The result, by the way, was the comment : “ Well, you certainly have no problems with stereopsis; few are as lucky as
you!” This time I’ll be savvy enough to ask for more specifics.
Here are a few more examples of 2 D-to-3D conversions of mostly en face portraits for your comments.
Best regards,
Dave
uuglypher
Wayne Gretzky
Turbguy1
uuglypher wrote:
Hi, Wayne,
Best regards,
Dave
The Frisby Stereotest is intended to measure personal stereopsis "acuity", express in seconds of arc.   My therapist doesn't have one.  Pity.
While offsets of true stereo pairs shifted vertically (homologous points offset vertically) can be fused, there is some level of discomfort, which depends on the amount of offset.  Eventually the pair cannot be fused.
Crossview examples: 0% offset:
3% picture height vertical offset:
10%picture height vertical offset:
20% picture height offset:
Do you experience any discomfort/"fuseability" with any of these (no fair tilting your head)?
Wayne
uuglypher
Hi, Wayne,
All are easy and effortless  to fuse - no discomfort until for  long foveation over ~ 30 seconds.
Given that when we foveate at our over-the-shoulder extremes of NW, NE, SE, AND SW we unconsciously incorporate some head tilt in our foveational neuromuscular g6mnastics before we actually turn our body toward the otherwise almost excessively peripheral point of attention… so 0lease 3x use me for having disobeyed your instruction/ suggestion re: head tilt!
uuglypher
Wayne Gretzky
uuglypher
Hi, Wayne,
Here ‘s a “big step” set of increasing angular displacements from 0° to 24°.Most viewers will report some discomfort to inability to fuse somewhere within this series.
Most of them report the angle that is their end-point fused for five to ten seconds before becoming uncomfortable and then breaking up soon after that.
The point is that in routine viewing of our surroundings we change our sequential point of attention three to four times per second. We thus skip across occasional high angles of disparity without notice.
When viewing 3D image pairs containing points of excessive angular disparity we often find ourselves dwelling beyond the usual fraction of a second- and then, finally, often with discomfort - on those points of discomfort!
Just a point to consider.
Dave
uuglypher
Wayne Gretzky
