Canon RF 24-70mm f/2.8L Longitudinal CA
Started 11 months ago | Discussions
M J Valentine Senior Member • Posts: 1,293
Hi,
Is this amount of longitudinal CA typical for the RF 24-70 on an R5? The exposure (first photo) was f/2.8, 1/1600,  IS0 100, 70mm, +0.3 EV, MFD. The second photo: MFD, f/4.5, 1/320, ISO 640, +0.3 EV.
Is the 24-105mm f/4L any better in similar conditions?
Thanks,
Martyn
Don't be dense; it's lens not 'lense'!
Canon EOS R5 Canon RF 24-70mm F2.8L IS USM
Canon_Guy
Canon_Guy Senior Member • Posts: 1,486
Re: Canon RF 24-70mm f/2.8L Longitudinal CA
Unfortunetely it is normal with RF 24-70/2.8 but only towards the 70 mm end.
RF 24-105/4 has this abberation not that pronounced by also present at the very end. So at 70 mm the 24-105 might be significantly better than 24-70.
 Canon_Guy's gear list:Canon_Guy's gear list
Canon EOS R6 Canon EF 70-200mm F2.8L IS II USM Sigma 14-24mm F2.8 DG HSM Art Sigma 105mm F1.4 DG HSM Art Canon RF 24-105mm F4L IS USM +6 more
ProDude Senior Member • Posts: 4,851
Virtually ALL lenses can be copy dependent regarding their flaws. I got lucky except for one lens of the 6 I own, having them virtually perfect and CA and LOCA free including a RF24-70 f2.8L copy. Only my first copy of a RF24-240 had those issues. The replacement is perfection. So you can't paint with a wide brush attacking such a lens. Guess you have one made on a Friday afternoon. LOL
Name the gear and I've probably owned it and used it.
Canon_Guy
This is more down to a lens design and materials used for lens elements than to deviation between manufacturing shifts.
OP M J Valentine Senior Member • Posts: 1,293
Thanks, I'm not attacking the 24-70 per se, just enquiring as to whether I have to stop down to f/5.6 or smaller just to avoid LOCA when shooting at MFD. I don't mind lateral CA as it's easily corrected.
Don't be dense, it's lens not 'lense'!
Thanks, I'll try the 24-105 f/4L with flowers at 70mm. Maybe the 28-70 is a better option. Incidentally, the 100-500 is very useful for close up photography.
Sorry to tell ya I'm not the only one I've communicated with that has found their 24-70 copy free of what you claim in inherent. It's NOT.
Canon_Guy
Or may be you just do not meet it in your pictures because of the way you shoot. That is much more likely.
Aberrations are attributes of a light going through the glass. There are lense designs more prone to it (RF 24-70) based on the used elements and their chararacteristics and less prone to it (EF 70-200/2.8 II).
By design.
