R5 vs R5C for primarily handheld (!) video
Started 11 months ago | Discussions
gruncharov
gruncharov Forum Member • Posts: 82
Hi,
considering to switch back to Canon after 2 years 'cheating' with Fuji - just couldn't live with the apsc crop.
So I gotta decide between the R5 and R5C - something I might have to mention is that I do handheld video, I hate gimbals, I am probably getting old - in addition, I mostly use old glass, e.g. manual focus - I probably won't be making much use of the auto focus options. I still gonna get the 24-70 for 'clinical' corporate jobs where i need reliable focus, but thats secondary.
Now, on paper it would seem that the R5 wit stabilization would be the better choice for handheld video, but I am a bit concerned about overheating issues - and on youtube, well, you don't know who to trust anymore.
I am more leaning towards the R5C because of all the additions for video, however I am just a bit worried how it will handle handheld - Of course I gonna add the battery grip, a smallrig frame/handle, monitor etc on it, so it will be heavy - e.g. stable. Of course the R5 is cheaper, especially second hand, so there is that too.
Any thoughts on that, appreciated.
George
Canon EOS R5 Canon EOS R5 C
paratom Veteran Member • Posts: 3,019
Re: R5 vs R5C for primarily handheld (!) video
Are the time constrictions due to overheating of the R5 are a problem for you needs?
Do you shoot from a tripod anyways or do the lenses you plan to use have IS?
cortex95x Contributing Member • Posts: 862
The OP had clearly stated that he shoots ":handheld".
I shoot video with a C300 MK III and, more recently, with the R5c. On several occasions I have shot 4k with the R5c, handheld, battery grip attached, with an EF lens offering OIS, and found that the OIS, along with the camera's own EIS, had been sufficient to produce smooth video. This might not be the case for someone walking with the camera, but standing in place and panning slowly had worked out just fine. More often than not, however, both of the cameras mentioned above are shot from a monopod with a fluid video head mounted on top. I hope this helps to answer the OP's question.
Ken Ross Senior Member • Posts: 1,215
I have the R5 & R5c and have used both. Like you I was initially concerned with the R5c’s lack of IBIS. However I’ve found if you’re using any RF lens with OIS, it’s really no concern. The IBIS actually adds very little stabilization to a lens already equipped with OIS. The bottom line is I’m delighted with the R5c and will be selling my R5.
Above is a video I shot, all handheld, with the R5c & the 100-400 RF lens. Many shots were at 400mm! You can see the stabilization is really quite good.
 Ken Ross's gear list:Ken Ross's gear list
Canon EOS R5 Fujifilm X-H2
palane Contributing Member • Posts: 617
gruncharov wrote:
Hi,
George
In a month Fuji's latest sensor/processor will be known.
A speedbooster(viltrox is one) with EF glass gives a FF perspective and the crop is handy too.
The X-H bodies are very well sealed,ergos are nice.A choice of 26 or 40+ mp.IBIS and plenty of small light lenses(that you can use manually).
H1 has the nicest shutter too, I hope thats included with the NewBys.
It'll be worth the wait$ I think.
bestzoom Regular Member • Posts: 181
I just switched from R5 to R5c, having used 5D4, R for video previously on a gimbal.
If you are planning to shoot handheld only, then R5 is perfect. If you are planning to walk and shoot video, then a gimbal or glidecam is required.
There is no overheating issue with either camera after R5 firmware update unless you plan to shoot 8K raw continuously for more than 30 minutes (with R5).
R5C in video is much easier to achieve accurate colour or white balance when you shoot in 8k raw, which also comes in smaller file size-- Canon Raw LT.
Reasonable steady hands with slow movement coupled with lens OIS is adequate for video as you can also apply stabilisation in post to steady your shots.
If video is your primary reason for the gear (like me), R5C is a no brainer!
All the best!
 bestzoom's gear list:bestzoom's gear list
Canon EOS R5 Canon EOS R5 C Canon EF 20mm f/2.8 USM Canon EF 85mm F1.8 USM Sigma 35mm F1.4 DG HSM Art +8 more
Markr041 Forum Pro • Posts: 10,078
It is a fact that IBIS does NOT contribute much stabilization for lenses above 100mm, and none likely at 400mm.
The advantage of IBIS is the ability to shoot with non-stabilized lenses below 100mm. Many excellent primes do not have OIS.
Also, IBIS provides more axes of stabilization typically than OIS, and adds axes and stability with lenses that have OIS. But one can do very well handheld with OIS lenses and no IBIS.
 Markr041's gear list:Markr041's gear list
Panasonic ZS100 Olympus TG-5 Canon EOS M Panasonic Lumix DMC-GH4 Nikon Z6 +5 more
Today I tried the non-OIS 50mm RF lens utilizing the electronic IS of the R5c. The stabilization was surprisingly good and I didn’t find the slight zoom to be a significant issue
Of course the caveat is you can’t use it when shooting 8K RAW, but the oversampled 4K60 & 4K30 is so good that it’s easy to live with that limitation when not using an OIS lens. Truth be told, I almost never use the 50mm anyway.
An interesting note on digital IS in the R5c. You are unable to use digital IS in 8K RAW, yet you can use it in the HEVC, non-RAW flavors of 8K. That would be both 8192X4320 & 7680X4320.
The quality in these modes is also excellent and since it's 10bit 4:2:2, there definitely room for some grading.
