Important limitation of Fuji X Raw Studio software
Started Apr 23, 2022 | Discussions
fernandojval
fernandojval Regular Member • Posts: 428
I have a collection of film simulation settings in files ending in .fp1 on my computer.
Some I have downloaded from the internet and some I have created myself.
The limitation of the Fuji X Raw Studio software, from which the simulations are handled, is that when I connect the X-T4 to my computer, it can only process pictures taken with that camera. It is impossible to process pictures taken with other models, such as the X-E2, X-T2, X-T3 and X-S10.
I find this a major limitation of Fujifilm's software.
 fernandojval's gear list:fernandojval's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 70-300 F4-5.6 R LM OIS WR Tamron 17–70mm F2.8 Di III-A VC RXD +3 more
Panasonic Lumix DMC-FP1
Erik Baumgartner Senior Member • Posts: 6,893
Re: Important limitation of Fuji X Raw Studio software
The limitation is that the software must use the camera's own internal processing engine to do what it does (proprietary Fuji in-camera RAW processing). If you want to process X-T2 files, you must connect an X-T2, X-T4 files, you must connect an X-T4. It's not impossible to process files from other cameras but If you don't have the other cameras that produced the files, you do indeed have a problem.
Pretty sure the older X-E2 isn't supported at all, though.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
jaberg
jaberg Senior Member • Posts: 1,037
The Fuji X Raw Studio software uses the camera itself,to process the images. The software is just a hook and (better, or at least bigger) UI for the camera. Arguably easier to experiment with and adjust images, but no real work is done by the computer.
I believe you can change the metadata in your old files to spoof your current camera into believing it made the images. I’ve never done this. This images will be processed as if they were files from that camera and there may be slight differences in output then if you were using the original camera.
 jaberg's gear list:jaberg's gear list
Fujifilm X100V Fujifilm X-S10 Nikon AF Nikkor 85mm f/1.8D Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +3 more
fernandojval
OP fernandojval Regular Member • Posts: 428
How do I change camera metadata from Lightroom?
primeone Regular Member • Posts: 120
This limitation is documented, so it should not have been a surprise that it "works that way".
https://fujifilm-x.com/en-us/stories/fujifilm-x-raw-studio-features-users-guide/
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,178
Change meta data
I use Exiftool to change meta data. But I am on Linux. However, I believe there is a Windows GUI.
Also, I've never changed meta data for the purpose of using X-Raw Studio with a different model. Don't know whether this works. Search this forum.
I always recommend darktable. That's my standard raw converter. Pretty happy with it. I occasionally use X-Raw Studio, Silkypix, and in camera raw conversion.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Possibly but its not obvious what you need to change - its not as easy to fool as Lightroom
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
jaberg
As I said, I’ve never tried this myself — doesn’t feel worth the bother — but I recall hearing of it.
jaberg
I get the surprise if one hasn’t taken the time to understand “how” the software works. I’d bet most assume it’s an analog to the edit panel of  “Lightroom” (or Apple’s Photos), not a control interface (and I/O buss) for the camera’s processor.
Papa48
Papa48 Senior Member • Posts: 4,860
Yes, that’s owing to the camera’s own processor being the app.
 Papa48's gear list:Papa48's gear list
Sony Cyber-shot DSC-RX10
(unknown member) Regular Member • Posts: 223
If you actually took the time to learn about the program, you’d realize it uses the camera to process the image.
