Question to GH6 owners related to EVF sharpness
Started Apr 23, 2022 | Discussions
Dirray New Member • Posts: 5
I've just bought a GH6 and am in general quite happy about it.
However, I've noticed that the sharpness of the EVF is much lower when A-, S-, M-, P-, Cx-modes are chosen versus when chosing "Creative Video Mode".
It creates fatigue to the eyes as you constantly try to get optimal focus with your eyes, which is not possible.
The issue is most visible when you're looking at something at far distance (infinity focus).
I've checked another camera in a shop and it turns out to have the same behavior, so it seems to be a generic GH6 issue.
Can other users of this camera verify whether this is the case for them also?
To best see the issue:
(1) put the turnwheel on Creative Video Mode, focus on something at far distance; you'll see that the image through the EVF is perfect.
(2) now turn the turnwheel to any other mode, and you'll see the screen "switch" with (much) less sharpness.
Thanks for sharing your experience.
alcelc
alcelc Forum Pro • Posts: 19,003
Re: Question to GH6 owners related to EVF sharpness
You use evf to take video?
Not sure the sharpness (or evf setting) would be changed on using different shooting mode. It should be the same (after set) for still (P/S/A/M) and video (M-Video).
Have you tried to save a video shooting environment in one of the C? i.e. M-Video ( either P/S/A/M) to a C to see how your evf will behave?
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
Danielvr Veteran Member • Posts: 6,860
Are you recording video in a lower resolution than the full pixel dimensions of the sensor? If so, the larger magnification of the pixels will likely result in the illusion of greater sharpness.
Besides this, a slew of different settings may be activated in Creative Video Mode, such as dynamic range boost, higher luminance, enlarged display, etc that will affect the image in the viewfinder.
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
Pete Berry Veteran Member • Posts: 4,322
The E-Stab. Effect
You've discovered the video E-Stabilization effect!
The EVF doesn't change it's properties - It's not actually any sharper - just magnified a bit, as the E-Stab. imposes about an 8% sensor crop in all video modes. So turn it off, unless you need it, and focus your EVF critically in a stills mode, which will not "jump" when switching to Creative Video.
Interceptor121 Veteran Member • Posts: 8,691
LVF/Monitor Display Setting
I just checked and I think you have set the EVF to display shooting settings outside the frame
This means the 4:3 image gets scaled to make room for the shooting settings
So there is no difference with the previous models once you set them same way
If you don't want the field of view to change make sure the settings are in the frame in both photo and video
In video they will be outside anyway unless you shoot anamorphic and in photo they will overlay the image
Your store should know better
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
katy C. Senior Member • Posts: 2,209
Your dismissive "you use evf for video".
I certainly shoot video via EVF: it is easier
to hold the camera steady that way rather
than arms outstretched looking via LVF,
katy
 katy C.'s gear list:katy C.'s gear list
Canon EOS M50 Canon EOS M6 II Fujifilm X-T4 Panasonic Lumix DC-S5 Canon EF-S 60mm f/2.8 Macro USM +10 more
katy
I agree
Using the EVF is better when for example you handhold the camera or use a monopod.
When you are on a tripod instead you can't use the EVF but generally the LCD is small and you should really use a monitor
The Gh6 and Gh5m2 LCD are brighter and with a hood can be used outdoors but remain small and low resolution and should not be used for critical focus in my view
Neon Birding
Neon Birding Regular Member • Posts: 197
If you're reviewing photos on the evf or live view.   It's likely you have the exposure modes set with RW2, RAW or Raw+JPG.  THe cameras creative mode and Ai exposures all use JPG for the playback review of photos on the camera.
Thus, when you zoom in all the way on the camera's playback screen, you can see the sharpness difference between RAW file and JPG.
Raw has no role in the display which is based on the selected photo style
either the photo style used for photo and video are different or simply is a difference of crop that depends on the display settings as explained in my post here
Neon Birding
Yes, you are correct.  The raw photo when viewed on the display will show the image quality of the raw photo taken, which is less sharp then if you were to take a photo set to JPG only.   So, having photo set to RAW file will be different than viewing a fully cropped in shot in JPG.
No that is incorrect
RAW can't be displayed on any screen it is not an image. If you save a RAW+JPEG the camera displays the jpeg with the photo style chosen
If you make the mistake of shooting RAW only it will show the embedded JPEG that is very low resolution
But on live with it makes no difference what is shown is the photo style of the jpeg
All cameras only display their JPEG there is no such a thing as RAW display as the screens are gamma corrected so can only display an sRGB signal
OP Dirray New Member • Posts: 5
Has anybody tried to look through the viewfinder, and switch from any mode towards Creative Video Mode?
Do you see a diffrence?
Re: The E-Stab. Effect
I don't understand your reply to be honest. E-stab is actually OFF.
Well of course. It's different because of the top and bottom video 16:9 ratio format height crop of the 4:3 default stills format. But the center remains unchanged. Unless you're in video E-Stab., which you say you aren't.
With it, going in and out of video mode with the main selector, the center "jump's" to a slightly magnified state, by cropping in about 4% of all sides and appearing wider, deeper, and a bit sharper, due to the mag. And going to any stills mode, it jumps back to the normal state - same width as the video frame, but filling the VF top and bottom. And the video played back shows a a ~4% crop, and my 12-35 becomes a 12.5-36.5 effective FL w/ E-Stab..
How is yours different?
Are you sure? See above reply. Nothing else I know makes the video image magnify (get clearer) slightly in all video formats allowing it.
Put your selector on creative video, get the E-Stab Yes/No dialog on screen, and switch back and forth and see the image change. Is this anything near what you're experiencing? Because in non-video modes, E-stab is auto-off regardless of setting.
say_doyster Regular Member • Posts: 147
Yes, and other than the 16x9 framing (cropped top and bottom), I find no difference in the EVF sharpness. There can be changes in exposure as you cycle through the options going from PASM to CVM, but there are no other changes in the sharpness.
B
 say_doyster's gear list:say_doyster's gear list
Canon EOS 5D Mark III Canon EOS 5DS Panasonic Lumix DMC-GX8 Panasonic GH5 Panasonic Lumix DC-G9 +1 more
Read my post
https://www.dpreview.com/forums/post/66110135
I’ve checked this and the issue is not linked to the setting RAW or JPEG.
jrsforums Senior Member • Posts: 1,859
Are you using identical photo style, sharpness, etc.?  Different from prior models, GH6 allows separate settings for stills and video.
 jrsforums's gear list:jrsforums's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GH6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +17 more
Read my post
Yep, that produces a shift to a smaller stills screen, with the same effect - the difference being that with E-Stab. on there's a crop-mag of the video making it a bit sharper rather than a shrinking of the stills frame.
Since he says E-Stab is off, your explanation must be the one.
