alcelc
Re: Upgrade from G7+GF1 to GX8 / GX85 / GX9 / G85 / G95 or G9
Would you do BIF? If yes, G9. If not, the AF of other options on your list could be good enough.
Do you care the size and weight? If no, G9 could be the best ergonomically. If not, GX85 would be the smallest on your wishing list (relatively), GX9 is larger, than GX8 which is close to G85, G95 is slightly larger than the largest G9.
Do you need a great evf, a deep hand grip at the front for larger lens, and weather sealing but on rangefinder form factor? If so, GX8 without doubt.
Please make no mistake, GX85 is called GX7 mk-II and GX9 is called GX7 mk-III in Japan, so these two are not in the same class of GX8.
G85/G95 are successors to G7.
I think GX85 and it's twin lens kit set (12~32 & 45~150) should be the cheapest among your options. On IQ, they are close in real life. G85 should also be under deep discount nowadays.
All of those options on your wishing list are significant upgrade from GF1. Regarding G7, it actually uses the same 16Mp generation of sensor of GX85 and G85. Its IQ is much closer to your options than GF1. However considering the IBIS, DUAL IS, DFD, and various interesting 4K photo modes ( high speed shooting) & Post focus (Focus Stacking), plus sharper SOOC JPG output because of no AA filter on sensor (exclude GX8), you could expect quite observable improvement.
The crop factor of video will make the AoV of the lens narrower only, no big deal.
Regarding dirty sensor, might consider wet cleaning.
You shall never go wrong on any new of them.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
