Moonrise April 16
Started 11 months ago | Photos
DavidWright2010 Veteran Member • Posts: 3,733
Moonrise April 16
7
It's been a while since I've taken the SD1M off the shelf. So long, in fact, that all my SD batteries were dead, and the cam had forgotten the date...
So with 1/2 hour 'til Moonrise, I charged up a battery and walked to the end of the block to wait for the Moon to show up.
See that fuzzy blob on the bottom picture? It's not a cloud...
It sure looks like a turkey buzzard to me. Although why it is out flying in the dark? And notice that AF focused on the powerlines.
This last is a composite. When I positioned myself to get sunset glow reflected in the windows,, the Moon was waaayy off to the right.
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
Comment & critique:
Sigma SD1 Merrill
SigmaChrome Forum Pro • Posts: 15,728
Re: Moonrise April 16
Fascinating moon shots, David.
Maybe the next Sigma Foveon camera will have adjustable AF points.
The last shot is a winner!
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Very fine moon shots and the last one is a beauty.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
OP DavidWright2010 Veteran Member • Posts: 3,733
Thanks Vitée.
Actually, I think that atmospheric turbulence meant that the power lines were much sharper edges than the Moon's limb, so the AF chose the wires.
David
S
Thanks Ceistinne.
I did this same shot sometime last year, and the reflected sky in the windows was better then, I think.
But you work with what Nature gives you.
David
larryj Forum Pro • Posts: 13,086
Nice moon sequence David; thanks for sharing
larryj
If you can see the light, you can photograph it
Quote from Myron Woods
 larryj's gear list:larryj's gear list
Sigma SD1 Merrill Sigma 24-70mm F2.8 EX DG HSM Sigma 150-500mm F5-6.3 DG OS HSM Sigma 105mm F2.8 EX DG OS HSM Sigma 18-35mm F1.8 DC HSM Art +1 more
