OP
MacM545
Contributing Member
Re: IR photography question about narrowband 950nm filter
what effect of a narrow band spectrum is there for diffraction? and, is there an improvement when using a large aperture?
slightly off-topic, and actually about the electromagnetic spectrum (not just IR), I've read that shorter wavelengths can supposedly limit diffraction therefore allowing a smaller aperture to work (there might be other factors that might complicate such a conclusion, such as the optics in question, which you've mentioned). For example, at F/28, the image might be sharper in the Blue channel than in the Red channel. of course, red and blue don't focus exactly the same so the results might be different and complex in some situations.
I was thinking also about using the technique which has been used for astrophotography, by using an individual spectrum of light per image, before assigning the images into the appropriate color channels and stacking into a colorful image. but for my main purpose of this technique, I wanted to see if the technique could be helpful not just for astro, but also for using very small and very large apertures at various distances, and for various macro magnifications with lenses of different types.
It might be interesting to compare a wideband image made at short wavelengths, to a very narrowband image at long wavelengths, regarding large and small aperture. The longer wavelengths, from what I've read, can be a problem for small pixels. but, as you've mentioned, a narrowband spectrum can be useful for reduction of abberations.
It is possible that I might need some more understanding of science to know these answers for sure, and I might need to take many factors into account for a precise comparison. nonetheless, it seems like a scientific investigation.
