Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
Started Apr 18, 2022 | Discussions
Pete Berry Veteran Member • Posts: 4,322
Re: Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
bclaff wrote:
Pete Berry wrote:
AURA PA wrote:
Pete Berry wrote:
So to play Devil's advocate, Bill, 7 of the past 8 Panny m4/3s you've tested have shown higher PDR's than the OM-1 - as have all three of the Olys sharing the E-M1-III sensor, The G9 eclipses the OM-1 by a whopping 0.76 EV.
Not so much. The 20MP Sony sensors had the same DR with little actual variance. The "peak" you're looking comes at the expense of color accuracy as explained previously .
So surely the OM-1 was designed with only mediocre stills in mind, along with its sub-class video performance!
Obviously haven't used one. It is the most complete M43 camera to date.
Having both the G9 and GH6 I've yet to experience any significant low-iso photographic difference in DR, and appreciate the 5MP frame increase.
Just don't lift the shadows and you'll be fine.
Whatever...
Below, tight crop for 12x16" print from above. Shadows boosted 95% in ACR
That's not a high dynamic range scene, dark cormorant with shadow on neck.
But push the neck hard and you get this.
Bill, while I appreciate your incredible work with comparative sensor characteristics, this is really pretty silly! Push anything hard enough and it falls apart - reductio ad absurdum.
I was surprised to see the clearly defined pale blue eye emerge from the very dark background, with blacks a dense as 8-bit RGB 4-4-2
knickerhawk Veteran Member • Posts: 7,615
5
Whatever...
Nevertheless, you can push most other current generation mFT cameras even harder, and they will hold up better than the GH6 with respect to shadow noise in stills. You can easily see for yourself by using the exposure latitude comp tool here. (Note the lower noise levels in the GH5ii, OM1 and EM1x despite all three of them having lower exposures than the GH6.
Whatever...
The GH6 does not have good deep blacks this is what you see creeping here
A camera with good blacks will resist manipulations of shadow better than another with better DR but worse blacks
In the case of the GH6 I can say the GH5M2 can take a lot more beating and even more of the G9 as it has better blacks
I guess I need to be enlightened about how you define "better blacks" as a sensor characteristic. The GH6 gives what I consider good looking JPG blacks. As does my GH9.  I've not seen a weakness in GH6 prints, but I of course PP them to taste.
JakeJY Veteran Member • Posts: 5,442
Whatever...
He makes a fair point your sample proves nothing about the sensor performance when pushing, as the given performance demonstrated likely would still be achievable by cameras in 10-bit mode with reduced DR (like when G95 is in bracketing mode). The exposure latitude test linked by others shows the weakness of the GH6 very clearly (you can compare to the G95 which was tested in error in 10-bit mode).
https://www.dpreview.com/reviews/panasonic-lumix-dc-g95-g90-review/5
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Pete_W
Pete_W Senior Member • Posts: 2,838
DPR added a statement that said: "We will re-shoot and re-assess this test and the score as soon as we can." The review was in Aug 2019. Unfortunately the re-assessment has never happened.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
Yep, that never happened unfortunately, and many people had a really poor impression of the G95 as a result (didn't see that statement). Originally I was suspecting the GH6 results might have been from some sort of similar bracketing mode that pushed it into a 10-bit mode (given the results are similarly poor), but after seeing these test results it makes complete sense that this is simply poor performance from the sensor at lower ISOs.
To be clear this is not to say this cameras is worthless in stills, it still performs well at ISO 800+ when the dual output gain kicks in, but it's fairly obvious this camera is not optimized for lower ISOs.
bluevellet Veteran Member • Posts: 4,168
They just re-assessed the re-assessment.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
