Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
Started Apr 18, 2022 | Discussions
Tim200 Regular Member • Posts: 405
Re: Ugh, charts
Ranlee wrote:
Tim200 wrote:
Simon97 wrote:
I look at the studio scene RAW conversions. Ask yourself if the difference between models is really that drastic. What if you scale the 25mp images down to 20 and compare to the OM-1 or other MFT cameras? Would it make a difference in your photography?
I'd get the GH6 if I had a collection of MFT lenses and wanted to get more into video. Looking at the sample gallery it is a pretty good photo shooter but would lean to the OM-1 for straight photo work.
Yes, the gh6 and om1 look about equal in the studio scene. In fact I think gh6(scaled) actually looks a bit better at higher ISO e.g. 6400. In my use, stills look fine as long as I'm careful with how the shot is exposed. However, what I'm also seeing is the issue outlined in the dpreview article about gh6 low ISO DR. If I have to raise shadows, it quickly becomes noisy. Example I've run into is a subject in front of a bright window. It has taken some practice to get a shot like this which can be processed decently.
This is a reasonable statement and I certainly am not qualified to dispute it. However, the question for me is compared to what? I have taken test shots like you describe (bright window dark shadows) with both G9 and GH6 with exposure as close as I could get it -1.3 GH6 -1G9 (I think the GH6 meters brighter than the G9, even a third stop wasn't quite enough). I imported the Raw's to LRC, zeroed sharpening and NR, brightened by +2 and exported. Regarding noise, in every case from ISO100 to 25600 I would take the GH6 files over the G9's. As far DR, I could not see a difference in my test files, and the G9 is regarded as best in MFT for DR. Now, was this scientific - hardly. But it was done as equally as I could within my expertise, and within the parameters of my normal shooting. For example, I didn't raise anything by 5ev and probably never will.
Now, I expect someone will tell me what I did wrong in testing. That's cool, but doesn't mean I will understand them or suddenly decide my GH6 is trash. So far I happen to like the camera.
That's interesting, and good to hear. It's good to see some positive reports from practical use.  I've shot full frame the last couple of years, so that's probably slanting my perspective a bit. Despite the scenario I mentioned, I love the gh6 and don't regret getting it.
 Tim200's gear list:Tim200's gear list
Panasonic Lumix DC-GH6 Panasonic Lumix DC-S5II
Ranlee Senior Member • Posts: 2,258
Re: Ugh, charts
Dale108 wrote:
Hi Randy:
Test charts are fascinating but real world shooting is what matters in the end.
Have you tested GH6 CAF vs G9? Curious if any improvements.
Dale
Hi Dale.  As far as moving subjects and CAF I simply haven't tested.  Semi-stationary wildlife and landscapes are mostly where I dwell but I can give you my impressions of the focusing.
It's been a cold, rainy, snowy spring so far which has limited me to my yard for the most part.  I had lot of trouble in the beginning shooting a few Robins and a rabbit that doesn't mind posing.  It was frustrating as I couldn't to get many shots in focus.  I tried all the different modes with little in the way of results.  It dawned on me that I was shooting both through an open window and downward, and from too far a distance.  The Robins always had grass etc.. close behind and the Rabbit had drooping vegetation in front and strong contrasty objects behind.  I was continually getting focus behind the subjects.  I got quite a bit of improvement using SAF and using the Near focus option.  I got even better results simply by going out of the house and shooting from a different angle.  So it was me and the conditions that were the problem.  I'm getting my usual high percentage of in focus shots now in SAF with the small focus box.
Regarding CAF.  I rarely used it on my G9.  The constant warbling in the view finder was distracting and I didn't find it that accurate.  I have been using CAF quite a bit on the GH6 and find the small warble doesn't bother me like it does on the G9.  Probably because of the improved speed I suppose.  I have using it the same as do with SAF, that is single small focus box and am getting consistently good results.  I have not had much luck with the animal detection to date.   It finds the animal easily enough and consistently, But high contrast backgrounds and the box being always slightly larger than the animal cause more rear focusing.  This is mitigated somewhat by the Near option again but not very satisfactorily.  Hopefully when I get back to my woods I'll be able to vary the backgrounds and do a better test.  I do think I will be using CAF a lot more with the GH6.
I do really miss the AF Focus Scope.  I use it all the time on my G9.  I hope a firmware update will give that back.
Something else I found (nothing to do with AF).  The option to save settings to the memory card now includes an option to have formatting leave the file alone.  I like this.  On the G9 I usually do a quick erase of files by using the format command which always also removed the settings file.  Ok, I got a little windy.  Hope this was helpful.
Randy
 Ranlee's gear list:Ranlee's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix DC-S5II Canon EF 200mm f/2.8L II USM +10 more
DDoram
DDoram Forum Pro • Posts: 10,369
Re: Ugh, charts
Thanks Randy
Dale
Ranlee wrote:
Dale108 wrote:
Hi Randy:
Dale
 DDoram's gear list:DDoram's gear list
Sony RX10 IV Pentax K-1 OM-1
knickerhawk Veteran Member • Posts: 7,615
HHHR drops varying numbers of frames
Interceptor121 wrote:
drj3 wrote:
It looks the same to me, though we have no measurements.
On the M1x, tripod HR takes only 8 shots and has a very similar PDR to HHHR (16-shots). We do not know how many of those 16 or 12 shots are used by the HHHR algorithm. GH6's HHHR mode picks the best 8 out of 16 shots.
The OM-1 and probably the E-M1s use 8 of the images. I assume the OM-1 can get the same IQ with fewer images because of the faster readout speed of the sensor and faster frame rates which would reduce the chances of other factors affecting the images.
You can count the number used by looking at an image with something moving (like counting the number of London has fallen in the attached which was scrolling on a TV screen (7 plus the one blank).
I could post an image of a waterfall where you see the many hundreds of droplets 8 times, but I would have to process the image and load it over my slow internet connection.
I think what is likely to happen here is simply that is using the first set of 8 images and then 4 of the 8 for the corners where it is possibly getting most of the issues for a variety of reasons including distortion.
If it has more speed it would not make sense to drop any frames unless they have worked out that some of them do not do much statistically
But as all of this is not clearly explained we will not know
At least with respect to the EM1iii, HHHR definitely drops varying numbers of frames. It also frequently fails completely and reports an error and doesn't record an HHHR image at all. Here's a test I did with a swinging flashlight. About 2/3 of the HHHRs successfully recorded used all 16 shots, the other 1/3 of the HHHRs used fewer than 16 shots.
Top=All 16 shots recorded; Upper Middle=15 shots used with 5th (counting from left) missing; Lower Middle=14 shots used with 5th and 9th (counting from left) missing; Bottom=13 shots used with 5th, 9th and 15th (counting from the left) missing.
Re: Not Knowing it's Severe Handicap...
Raist3d wrote:
Funny Valentine wrote:
Pete Berry wrote:
And that reminds me: my almost 5 year old G9 sensor still rules the m4/3 DR roost along with it's use in the more recent GH5-II if you're into the top-dog sensor thing... I do like the larger GH6 stills files, along with the excellent HHHR implementation.
Somehow it seems the GH6 HHHRS doesn't suppress noise like Olympus HHHRS. This needs to be confirmed by someone who owns both.
Also we need to know if the OM-1 HHHRS is as good as E-M1 III HHHRS because they went down to 12 stacked photos from 16. Why would they do this ?
Because due to faster cpu/sensor readout, they can be more confident the number of images they need to create the HHHR are less than the other case, where they may have had to throw away more of the images.
according to Robin Wong and Olympus themselves, in the E-M1 III and X, the HHHRS RAW files were made of 16 stacked photos, for a total of 320 megapixels that were oversampled to 50 mp.
They do take 16 shots but are they using them? And I wouldn't believe everything Robin says. He's not perfect - like for example saying the EM5.3 EVF can do 120fps refresh rate- that's not true.
See my post here. At least with respect to the EM1iii, often all 16 shots are used in the HHHR image generated by the camera, but sometimes its fewer than that and sometimes the camera gives up and errors out instead of generating an HHHR image.
So if the math adds up, the OM-1 must be oversampled from 240 MP only, with 1 stop less DR than the E-M1 X and III.
Again, for hand held high res, you may not use all the shots. They need to register. WE need to confirm they are using all the shots. Also it's possible the new sensor with better color-in noise characteristics gives them the ability to use less shots.
So in ideal conditions, the old HHHRS should outperform the new HHHRS.
I wouldn't 'go by that assumption. A test should uncover this though.
Yes, it should be tested. Since the EM's can potentially incorporate more frames (and hence a larger aggregate exposure), they might have a modest noise advantage, but perhaps OM has tweaked the alignment algorithms or done other things to counter the need for the additional frames. Until tested, this is speculative.
James Stirling
James Stirling Veteran Member • Posts: 9,282
Re: HHHR drops varying numbers of frames
Thanks for that it gives a great visual of what is going on
Jim Stirling:
It is undesirable to believe a proposition when there is no ground whatever for supposing it true” Russell
Feel free to tinker with any photos I post
 James Stirling's gear list:James Stirling's gear list
Sony RX100 IV Panasonic Lumix DMC-GX8 Nikon Z7 Olympus E-M5 III Nikon Z7 II +10 more
(unknown member) Senior Member • Posts: 1,941
Re: Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
Cafe Racer wrote:
So essentially we now know that the DR of the GH6 is worse than it's m4/3 peers when shooting still images under ISO 800.
That is what the test images say.
That's also what PhotonstoPhotos GH6 PDR chart says.
I provided the images that make the chart so I guess I know lol
send a link  iso 200 and 800 for me
of this file
The confusion starts when the scientists can't agree amongst themselves. Henry F
Interceptor121 Veteran Member • Posts: 8,691
The HHHR of the GH6 can also fail when not exposed correctly
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
JakeJY Veteran Member • Posts: 5,442
JakeJY wrote:
hmmm, what a disaster for Panasonic... GH6 scores worse than the OM-1 and and last gen EM1-2 and 3...
You don't seem to know how to read that graph. This is quite good for a very fast front side illuminated higher resolution sensor optimized for video. If anything the OM-1 isn't looking quite as good as it should. The Em1mk2 needs to be corrected to the right 1/3 a stop due to gain choices. The stacked nature of the Om-1 semsor is hurting significantly any gains from being BSI, and its still very slow read out sensor compared to even the GH6.
I can see why now Panasonic choose this sensor over the Sony stacked BSI one. Its better.
FYI the sensor readout of the OM1 is 120fps, the fastest in M43. The GH6 is only 75fps.
Readout in fps depends on bit depth and pixel count
120x20.2x12=29088
75x25x16=30000
Under ISO 800 it doesn't look to have anything that requires 16 bit. From the results, it looks like that would even fit in 10 bit (the results from latitude test are consistent with the G95 in 10-bit mode, perhaps even a bit worse).
If you drop the bit depth to 12 bits you get 100 fps at 25 megapixels if you bin downwards you get to the same point
The camera have different objectives and design principles and can't really be compared
When it's doing the dual output gain the stream into the ISP may be even more than 16 bits total, but that is hardly relevant to the max fps the sensor can do. I doubt your claim it can do 100 fps at 25MP in 12 bit, as Panasonic does not offer that mode at all.
All video modes are read at 12 bits and scaled to 10 in the process.
The camera is limited at the compression stage not readout for video
Note I'm talking purely about the sensor here and not only about video, also including the RAW stills. Currently Panasonic only offers 75 fps mode as the max for both full res stills and video regardless of ending bitrate. They don't offer a 100 fps mode full res mode by dropping to 12 bit or even 10 bit. Compression bottlenecks can be addressed in future cameras by ISP upgrades, but sensor bottlenecks will always be there.
OM1 instead offers 120 fps outright at 12 bit, so we can be sure the sensor at minimum supports that.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
120x20.2x12=29088
75x25x16=30000
As I said the limit is on the output
the OM-1 may run at 120 fps but other than writing to a buffer for less than 1 second  no function runs at that speed autofocus works at 60fps so in effect there is no tangible benefit for a use case
the 75fps of the GH6 is also not that useful to be frank
in order to run the camera at 120 fps you need cooling the 4k120 fps mode is the only one that gets the camera hot
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
bluevellet Veteran Member • Posts: 4,168
yo
So far, the OM1 has only given up on me once with HHHR, which is a marked improvement over the EM1iii.
In very difficult situations, the OM-1almost always succeeds in creating a stacked image, but the final image can be crooked when you really push it.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
Pete Berry Veteran Member • Posts: 4,322
This camera is not designed with still photography in mind.
So to play Devil's advocate, Bill, 7 of the past 8 Panny m4/3s you've tested have shown higher PDR's than the OM-1 - as have all three of the Olys sharing the E-M1-III sensor, The G9 eclipses the OM-1 by a whopping 0.76 EV.
So surely the OM-1 was designed with only mediocre stills in mind, along with its sub-class video performance!
Having both the G9 and GH6 I've yet to experience any significant low-iso photographic difference in DR, and appreciate the 5MP frame increase.
Funny Valentine
Funny Valentine Senior Member • Posts: 1,392
the GH6 is such a mystery, there's little to no review about the photographic capabilities of that new 25mp sensor, only a bunch of spec sheet readers on youtube...
I would love to see a real life comparison between OM-1 and GH6 RAW files, using OM workspace and Silkypix to exploit them fully
 Funny Valentine's gear list:Funny Valentine's gear list
Olympus E-M1 II Canon 6D Mark II Canon EF 50mm F1.4 USM Canon EF 100mm f/2.8 Macro USM Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +2 more
AURA PA
AURA PA Contributing Member • Posts: 661
Not so much.  The 20MP Sony sensors had the same DR with little actual variance.  The "peak" you're looking comes at the expense of color accuracy as explained previously .
Obviously haven't used one.  It is the most complete M43 camera to date.
Just don't lift the shadows and you'll be fine.
 AURA PA's gear list:AURA PA's gear list
Olympus OM-D E-M1X Nikon Z9 OM-1 Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro +11 more
Whatever...
Below, tight crop for 12x16" print from above. Shadows boosted 95% in ACR
Pete_W
Pete_W Senior Member • Posts: 2,838
Pete Berry wrote:
That really is an excellent outcome Pete!
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
AURA PA
Whatever...
Its a pretty bird but at 2MP with NR I’m not sure this says anything about shadow noise.
OP bclaff Forum Pro • Posts: 13,939
Whatever...
That's not a high dynamic range scene, dark cormorant with shadow on neck.
But push the neck hard and you get this.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
Whatever...
The GH6 does not have good deep blacks this is what you see creeping here
A camera with good blacks will resist manipulations of shadow better than another with better DR but worse blacks
In the case of the GH6 I can say the GH5M2 can take a lot more beating and even more of the G9 as it has better blacks
Whatever...
I shot it as a silhouette, but on review saw it was a Double-crested cormorant I hadn't seen before. I did sharpen moderately to bring out bill and other detail, and if I did use NR, which I don't recall, it didn't affect details. The 100% pre- and post comps:
100%
