dbateman
Contributing Member
Re: Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
Interceptor121 wrote:
SrMi wrote:
dbateman wrote:
Funny Valentine wrote:
hmmm, what a disaster for Panasonic... GH6 scores worse than the OM-1 and and last gen EM1-2 and 3...
You don't seem to know how to read that graph. This is quite good for a very fast front side illuminated higher resolution sensor optimized for video. If anything the OM-1 isn't looking quite as good as it should. The Em1mk2 needs to be corrected to the right 1/3 a stop due to gain choices. The stacked nature of the Om-1 semsor is hurting significantly any gains from being BSI, and its still very slow read out sensor compared to even the GH6.
I can see why now Panasonic choose this sensor over the Sony stacked BSI one. Its better.
OM-1’s readout speed is much faster than GH6’s (8ms vs. 18ms, source DPR).
Nope that’s not correct the camera can produce 75 fps raw 16 bits file
Thanks for the correction, what DPR wrote here seems incorrect. It should be 8ms vs. 13ms.
I think he is referring to rolling shutter which for the GH6 in video is 12.7ms
But the cameras are not comparable
The GH6 is a premium video camera that takes some photos. The OM-1 is a still camera that takes some video
I was remembering some of the numbers wrong. The OM-1 is a faster sensor.
Gh6 can do 14 fps mechanical shutter, 75 fps full sensor read out saved at full resolution, full sensor uncropped read out of 120 fps but saved as 4k.
OM-1 can do 10 fps mechanical shutter, 120 fps saved at full resolution, but only electronic flash sync of 1/100 seconds.
I was remembering the 1/100 electronic flash sync of yhe OM-1 vs the 120 fps 4k read out for the GH6. Obviously not the same thing.
