Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
Started Apr 18, 2022 | Discussions
bclaff Forum Pro • Posts: 13,939
20
Files provided by Interceptor121 see his conclusions at Panasonic GH6 Video and StillL Performance
It does look as if it's optimized for video with a still capability that is limited below ISO 800.
Here's the Photographic Dynamic Range (PDR)
Of technical note spectral analysis shows the Dual Output Gain kicking in at ISO 800
In this 3D chart the lowest ISO is on the right and ISO goes up as you move left.
The peaks in the center start at ISO 800 and are due to the Dual Output Gain.
Bill ( Your trusted source for independent sensor data at PhotonsToPhotos )
AURA PA
AURA PA Contributing Member • Posts: 661
Re: Panasonic DC-GH6 Sensor Measurements at PhotonsToPhotos
6
Thank you for this analysis.  The low PDR measured here confirms what we have seen in the samples provided, and in Richard Butler's article.
Perhaps Lumix will release a photo oriented M43 camera soon.  The FF Lumix line is badly in need of a refresh as well.
 AURA PA's gear list:AURA PA's gear list
Olympus OM-D E-M1X Nikon Z9 OM-1 Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro +11 more
SrMi
SrMi Veteran Member • Posts: 4,377
Thank you, Bill. I hope that you will be able to measure HHHR and tripod HR modes (they have different noise characteristics).
Interceptor121 Veteran Member • Posts: 8,691
Am doing those later tonight
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
SrMi
Thank you, as well!
Austinian
Austinian Forum Pro • Posts: 13,597
I was hoping for something like a G9 Mark II for stills, but not if its sensor has the same low-ISO behavior as these measurements indicate.
 Austinian's gear list:Austinian's gear list
Panasonic Lumix DC-G9 Sony a7R IV Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G Macro 30mm F2.8 Panasonic 12-60mm F3.5-5.6 OIS +6 more
Unfortunately due to the design optimised for video is not possible to understand the benefit of higher bit depth
As I stated before is unlikely this sensor will be used for any still orientated camera
Funny Valentine
Funny Valentine Senior Member • Posts: 1,392
hmmm, what a disaster for Panasonic... GH6 scores worse than the OM-1 and and last gen EM1-2 and 3...
 Funny Valentine's gear list:Funny Valentine's gear list
Olympus E-M1 II Canon 6D Mark II Canon EF 50mm F1.4 USM Canon EF 100mm f/2.8 Macro USM Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II +2 more
OP bclaff Forum Pro • Posts: 13,939
5
This camera is not designed with still photography in mind.
SrMi
I am waiting for P2P results, but my impression is that tripod HR is really good. The noise and alaising is considerably reduced, motion artifact removal works really well, and it takes only 9 sec.
Funny Valentine
But Panasonic's limited r&d already went into the development/purchase of this sensor from tower semi, so it will end up in the next gen G9, GX9, etc. Or maybe it's a sign that Panasonic will axe the photocentric cameras to concentrate on video only.
9
I wouldn't make that assumption. Part of what we are seeing here is how the firmware uses this sensor and not necessarily a limitation of the sensor per se.
JakeJY Veteran Member • Posts: 5,442
If the results are this bad, I doubt it will go into a stills oriented camera like the G9 (if there is even a successor for that model). Maybe something that is closer to a hybrid like a G95 successor? At this point, using the older IMX272 (from GH5) for a GX10 is a much better choice.
I realized going with a non-Sony sensor would likely be worse, but didn't expect it to be this much worse.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
It is a conscious design decision Panasonic already does better than all olympus oma cameras so they would know what to do if they wanted to but they don’t this is a video camera
(unknown member) Forum Member • Posts: 66
Princess Bride quote
"You Keep Using That Word, I Do Not Think It Means What You Think It Means"
Like Bill said, "This camera is not designed with still photography in mind."
The cameras does what it was meant to, and better than anything in its price range.
dbateman Contributing Member • Posts: 866
You don't seem to know how to read that graph. This is quite good for a very fast front side illuminated higher resolution sensor optimized for video. If anything the OM-1 isn't looking quite as good as it should. The Em1mk2 needs to be corrected to the right 1/3 a stop due to gain choices. The stacked nature of the Om-1 semsor is hurting significantly any gains from being BSI, and its still very slow read out sensor compared to even the GH6.
I can see why now Panasonic choose this sensor over the Sony stacked BSI one. Its better.
 dbateman's gear list:dbateman's gear list
Olympus E-3 Olympus E-510 Sigma SD14 Olympus E-M1 Nikon Df +5 more
jrsforums Senior Member • Posts: 1,859
Bill, are you saying Panasonic could, if they wanted, improve the GH6 stills performance with a firmware change?
 jrsforums's gear list:jrsforums's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DC-GH6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +17 more
Possibly but it might also involve disabling or removing some video specific circuitry surrounding the sensor and that might not be possible by just changing the firmware.
Just saying that the sensor per se is probably more capable than what we are seeing and if used in another body could possibly get much better low ISO results.
bluevellet Veteran Member • Posts: 4,168
Hard to believe
6
Those charts are worse than the G6 and the EM5 (the mark I!), cameras released 10 years ago. WTH.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
(unknown member) Forum Pro • Posts: 47,805
So about same or notch better than OM1 above Iso 800/6400
overall but below ISO 800 OM-1 looks Cleary better (for stills).
Not entirely surprised. Panasonic clearly is prioritizing video with this camera.
I don't know at this point if they plan to prioritize their MFT line for stills. But hey Panasonic, a well designed modern successor to the GM5, maybe now that APSC/FF mirrorless have approached the MFT size, maybe sells better now?
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - Apparently Selwyn Duke and not George Orwell
