Atmospheric Distortion?
Started 11 months ago | Discussions
Neon Birding
Neon Birding Regular Member • Posts: 197
Quesions for the long lens super telephoto wildlife shooters who do video and photo.
How do you deal with the various elements that cause the Atmospheric Distortion on videos and photos?  And are their ways to deal with it?  And what are the best way's to deal with it while recording/capture?
Thanks in advance.
petrochemist Veteran Member • Posts: 3,619
Re: Atmospheric Distortion?
Thanks in advance.
I think other than picking a time with less turbulence (early morning) & reducing the amount of atmosphere you're shooting through, there's very little that can be done. With the moon at least you can take multiple shots & pick the results where distortion is least - this rarely works well for wildlife!
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Well, for long exposure sequences with telescopes there are methods that essentially use a laser to estimate the atmospheric distortion and then map it out much like lens distortions. However, I've never heard of anybody trying to do that with a single shot. If there was geometric content in the image, you might be able to estimate a distortion function and hence its inverse, but for wildlife? I think it's probably unavoidable.
Just try to shoot under conditions where the air isn't distorting things too much, e.g., no heat waves, low humidity, no serious pressure gradients, and not-too-much atmosphere between you and your subject.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Neon Birding
OP Neon Birding Regular Member • Posts: 197
Ah, thank you both for your tips.  I'm starting to now see the importance of the light's angle and humidity.
