EF extender on RF mount?
Started 11 months ago | Questions
julyas43
julyas43 New Member • Posts: 17
I'm not really into telephoto shooting much (yet?) but I was just wondering something. So I have an RP and 60D with mostly EF (or EF-S) glasses from the 60D days, and a third party EF lens to RF mount adaptor. One tele lens I have is the EF 70-200 f4L IS. This is quite wild,
1. would an RF extender put on the RP, then the adaptor in front of it, and then the lens work? Or
2. is it better to use an EF extender between the adaptor and the lens then put the adaptor on to the body? Heck,
3. would the second configuration work with an RF extender between the body and adaptor?
I know it would be like f/16 at the brightest aperture (using both 2x extenders) but it's a theoretical experiment anyway. Danke
 julyas43's gear list:julyas43's gear list
Canon EOS 60D Canon EOS RP Canon EF-S 18-200mm f/3.5-5.6 IS Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F4L IS USM +5 more
Canon EOS 60D Canon EOS RP Canon Extender EF 2x III
Steven Blackwood Senior Member • Posts: 2,210
Re: EF extender on RF mount?
The only configuration that will work is camera>adapter>ef extender>Ef lens
Steve
stevenblackwood1950@gmail.com
Milwaukee WI
 Steven Blackwood's gear list:Steven Blackwood's gear list
Canon EOS R Canon EOS R6 Sigma 100-400mm F5-6.3 Canon EF 70-200 F4 II Canon RF 35mm F1.8 IS STM Macro +2 more
BobKnDP Senior Member • Posts: 3,140
I'm not disagreeing, but could you explain?
sushipep Regular Member • Posts: 113
The RF extender expects an RF mount device at the back and and RF mount device up front
The EF extender expects an EF mount device at the back and an EF mount device up front
An RF camera expects an RF mount device up front
An RF-EF adapter expects an RF mount device at the back and an EF mount device up front.
You cannot mount an RF adapter in front of an RF extender, although if you want to hack up your adapter, you can try
https://www.the-digital-picture.com/News/News-Post.aspx?News=35054
If you put this all together
Camera > Adapter > EF Extender > EF lens
 sushipep's gear list:sushipep's gear list
Canon EOS RP
grovep Forum Member • Posts: 59
I understand the Canon RF extender does not physically fit the Canon EF-RF adapter nor other makes as far as I know.  Some have taken a third part adapter and filed bits off to make it fit leaving almost exposed electrical connections in the procress.
Therefore I believe the most common option is to use an EF extender after the adapter
PicPocket Veteran Member • Posts: 5,897
The short answer is that the RF-EF adapter doesn't physically fit in front of RF extender. The adapter has a protruding baffle inside which interferes with the protruding front element if the extender
So, taking the RF extender out of equation, what remains is above combination
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Bigger Contributing Member • Posts: 640
The CommLite CM-EF-EOS R works better with only minor mods:
Re: How did you stack the EF 2x III and EF 1.4x III: Canon EOS R Talk Forum: Digital Photography Review (dpreview.com)
 Bigger's gear list:Bigger's gear list
Canon EOS 5DS R Canon EOS R5 Canon EOS R7
You can put the RF extender behind a suitable, modified EF/RF adapter, and it will function. The only problem is that the R5 will display the RF extender in the EXIF, but it won't multiply the focal length by the extender ratio. So this may affect IBIS stabilization.
