Silkypix "An incompatible camera was detected" Panasonic GH6
Started Apr 16, 2022 | Discussions
DNature
DNature Regular Member • Posts: 310
I downloaded Silkypix Developer Studio 11 Pro from their website and when I tried to open GH6 RAW images I just get the message "An incompatible camera was detected" and it won't open them and I just get a black screen. I tried searching for updates but it says it is the latest version.
Am I using the right version of SIlkypix? Or is there another reason the files won't open?
If find that the best way to live life, is not in the pursuit of material possessions, but its to live in the pursuit of making positive differences to both other people and to the planet as a whole and if you can get others to do similar or the same, so much the better.
 DNature's gear list:DNature's gear list
Canon EOS 400D Canon EOS 500D Canon EOS 600D Panasonic GH5 Canon EF-S 18-55mm f/3.5-5.6 +9 more
JakeJY Veteran Member • Posts: 5,442
Re: Silkypix "An incompatible camera was detected" Panasonic GH6
https://silkypix.isl.co.jp/en/product/dsp11/
The website doesn't say GH6 is supported.
The SE version is the one that says GH6 is supported:
https://www.isl.co.jp/SILKYPIX/english/p/
The Panasonic discount version of the 11 Pro doesn't say it supports GH6 either.
https://silkypix.isl.co.jp/en/ext/special/dsp11fujipana/
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
DNature
OP DNature Regular Member • Posts: 310
Thanks, I didn't see that version. When I searched for it, I only found the 11 version.
alcelc
alcelc Forum Pro • Posts: 19,003
The free version of Silkypix offered by Panny is model exclusive (nearly and I am quite sure older versions of Silkypix will not be compatible to model released after your model).
Usually at some where of the manual (normally at the end) will have a link for the compatible version of Silkypix to your particular camera.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
