GH6 Full Moon HHHR (tripod) HR vs Preserve Details 2.0
Started Apr 15, 2022 | Photos
(unknown member) Forum Pro • Posts: 47,805
Re: GH6 Full Moon HHHR (tripod) HR vs Preserve Details 2.0
SrMi wrote:
Raist3d wrote:
SrMi wrote:
Raist3d wrote:
Val_K wrote:
Nice photo!
How did the HHHR turn out better than HR if there are both on a tripod?
HHHR probably takes less time than tripod HR. For completely static subjects I expect tripod HR to be better. But the moon is not as static as one may think. Point with a good zoom to the moon sometime on a tripod, go away for 30 seconds-60 seconds and see how much the moon already moved off frame!
FYI:
HHHR takes 16 sec, tripod HR takes 9 sec, approximately (1/800 sec).
HHHR takes 16 shots and selects 8 best, HR takes probably 8 shots.
Are you talking about 16 second to take the shots or 16 seconds to go end to end with the processing? Because the processing of the shots is not the same time it takes to take the shots.
Finally on the HHHR shots it's quite possible it aligns some shots with the moon more shifted and by the registration process effectively "shift it back."
It is the total time from shutter press to the end of the assembly. The time from shutter press to start of computation is always less than a second in my test (1/800 sec shutter speed, sensor readout speed is likely the limiting factor).
So the original message / comparison really doesn't apply. We need to see if the shots being taken are taken faster vs tripod HR.  We also need to see if there's a chance for registration of part of the hand held shots that could minimize detail loss when the moon moves.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - Apparently Selwyn Duke and not George Orwell
SrMi
SrMi Veteran Member • Posts: 4,377
Raist3d wrote:
SrMi wrote:
Raist3d wrote:
SrMi wrote:
Raist3d wrote:
Val_K wrote:
Nice photo!
FYI:
The acquisition time is about twice as fast with HR than with HHHR (i.e., not counting the computation time). This makes sense as HR likely takes 8 shots while HHHR takes 16 shots.
However, HHHR can pick the first 8 shots from the 16 taken so that the relevant acquisition time (time from the first to last shot used) may be the same.
AURA PA
AURA PA Contributing Member • Posts: 661
Far too much noise present in the HHHR file for ISO 100. There is visible grid pattern in the HR file indicating camera movement. Seems motion compensation does not address this.
 AURA PA's gear list:AURA PA's gear list
Olympus OM-D E-M1X Nikon Z9 OM-1 Olympus 40-150mm F2.8 Pro Olympus 7-14mm F2.8 Pro +11 more
SrMi
Which mode was set in Motion Blur Processing?
OP Interceptor121 Veteran Member • Posts: 8,691
Pete Berry wrote:
Jeff Wahaus wrote:
Interceptor121 wrote:
I like HHHR first
All shots from tripod as it was windy tonight
I'm seeing a weird noise pattern in all the lmages at 1:1. Oversharpened perhaps?
I don't think that's noise or over-sharpening, esp. @ ISO 100, but the response to the absence of repeatable detail in the 8 frames with the nearly full moon, where surface detail is the least. My take is that the processing algorithm, since it can't just leave a hole there, just fills it with this pattern.
Where there is some shadow/crater detail in the SE rim area, you don't see it. I've seen that in another ~ full moon HR image, where it was more striking and linear. And in this image, it does take on a linear pattern in some areas...
The part where the sharpening has gone overboard is the HHHR because I applied the same sharpening of the HR shot for comparison
the HR shot and the upscaled shot don’t have anything but the HHHR does I will post a reprocessed one with less sharpening
Patterns however would have nothing to do with read noise
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Reprocessed HHHR Shot
As explained I applied sharpening to the HR shot until possible and then applied the same to the HHHR but this shot could not take that same amount of sharpening
So this is with a much milder sharpening applied
the shots were taken with motion compensation MODE2
He has no idea. The issue as explained is sharpening. HR files need sharpening and I used the HR one as basis, as the HHHR was already good that ended up oversharpened
All shots were in MODE2 the moon moves
AURA PA
Mode 2 but there is obvious artifact present in the HR file (far left).  The HHHR file was given aggressive NR on the second go-round (center) so now has less detail than the orginal HHHR file (far right).
HR left, HHHR second process center, HHHR first process right
HHHR gives good resolution but no noise benefit which is disappointing even at ISO 100.
HR in mode 2 does not control camera shake, perhaps only object motion.  The solution is to downscale the image enough to hide the grid artifacts.
Pete Berry Veteran Member • Posts: 4,322
Re: Reprocessed HHHR Shot
The same pattern in the detail-free areas remains - just not so obvious. And at a lower screen mag., it's a much more interesting and informative image - more like the photos you would see of the full moon from large aperture telescopes. Below, a screen shot of the orig. 100% HHHR image @ 50% screen mag:
What were you expecting exactly? A completely clean image out of a shot taken with a zoom lens in a light polluted area?
you go figure
you go figure
What?! WTH gave you THAT idea?
Just showing that you can make a basically un-viewable @ 100% HHHR image - due to your above noted limitations - into a more viewable and informative one by reducing the mag. only - that's  significantly better than the 100% 25MP  "straight" 400mm image you shot.
