GH6 Full Moon HHHR (tripod) HR vs Preserve Details 2.0
Started Apr 15, 2022 | Photos
Interceptor121 Veteran Member • Posts: 8,691
8
HHHR
PD 2.0
HR
I like HHHR first
All shots from tripod as it was windy tonight
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Comment & critique:
Val_K Junior Member • Posts: 35
Re: GH6 Full Moon HHHR (tripod) HR vs Preserve Details 2.0
Nice photo!
How did the HHHR turn out better than HR if there are both on a tripod?
 Val_K's gear list:Val_K's gear list
Olympus E-M5 II Canon EOS RP OM-1 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
Pete Berry Veteran Member • Posts: 4,322
Interceptor121 wrote:
HHHR
PD 2.0
HR
I like HHHR first
Yes, HHHR the best - only one to clearly show the Alpine Vally E. of Plato, and Schroter's Valley adjacent to Aristarchus. I suspect that the HHHR was best because of the wind effect on the tripod/lens. The granular effect of the smooth background is a bit distracting, though, and has been seen on past lunar shots (but worse) in HR mode - from a E-M-III, IIRC. I'm looking forward to trying it on a partial lunar phase with craters on the shadow line in sharp relief and much more detail possible.
SrMi
SrMi Veteran Member • Posts: 4,377
Val_K wrote:
Nice photo!
Apparently, HR and HHHR work differently. In my test cases, tripod HR will generate a somewhat better image than HHHR (less aliasing and noise).
OP Interceptor121 Veteran Member • Posts: 8,691
Both the HR shots are sharpened with the same strength for testing purposes but I think foe that shot the radius is excessive
Val_K wrote:
Nice photo!
Because it was windy and HHHR has IBIS and the other doesn’t
SrMi
Val_K wrote:
Nice photo!
FWIW: it is possible to shoot HHHR with IBIS off, but a quick message appears saying to turn the stabilization on.
I am really liking the results that I am getting from GH6 HR and HHHR.
Val_K wrote:
Nice photo!
I just meant the HR shot wast that steady after all
rashid7
rashid7 Veteran Member • Posts: 7,011
WoW
Keep it fun!
lcubed11 Contributing Member • Posts: 985
what is Preserve Details 2.0?
 lcubed11's gear list:lcubed11's gear list
Canon PowerShot S5 IS Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH4 Panasonic Lumix DC-G9 +11 more
(unknown member) Forum Pro • Posts: 47,805
Val_K wrote:
Nice photo!
HHHR probably takes less time than tripod HR.  For completely static subjects I expect tripod HR to be better.  But the moon is not as static as one may think.  Point with a good zoom to the moon sometime on a tripod, go away for 30 seconds-60 seconds and see how much the moon already moved off frame!
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - Apparently Selwyn Duke and not George Orwell
SrMi
Raist3d wrote:
Val_K wrote:
Nice photo!
FYI:
HHHR takes 16 sec, tripod HR takes 9 sec, approximately (1/800 sec).
HHHR takes 16 shots and selects 8 best, HR takes probably 8 shots.
JakeJY Veteran Member • Posts: 5,442
SrMi wrote:
Raist3d wrote:
Val_K wrote:
Nice photo!
FYI:
Isn't it the acquisition time that matters in this case not the processing time?
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Jeff Wahaus Contributing Member • Posts: 943
I like HHHR first
I'm seeing a weird noise pattern in all the lmages at 1:1.  Oversharpened perhaps?
 Jeff Wahaus's gear list:Jeff Wahaus's gear list
Olympus E-M1 III Olympus OM-D E-M10 IV Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +6 more
The first and third have the same sharpening but 3 remains soft
2 is adobe process
i have redone 1 with less sharpening but cant be bothered posting it
I like HHHR first
I don't think that's noise or over-sharpening, esp. @ ISO 100, but the response to the absence of repeatable detail in the 8 frames with the nearly full moon, where surface detail is the least. My take is that the processing algorithm, since it can't just leave a hole there, just fills it with this pattern.
Where there is some shadow/crater detail in the SE rim area, you don't see it. I've seen that in another ~ full moon HR image, where it was more striking and  linear. And in this image, it does take on a linear pattern in some areas...
SrMi wrote:
Raist3d wrote:
Val_K wrote:
Nice photo!
FYI:
Are you talking about 16 second to take the shots or 16 seconds to go end to end with the processing? Because the processing of the shots is not the same time it takes to take the shots.
Finally on the HHHR shots it's quite possible it aligns some shots with the moon more shifted and by the registration process effectively "shift it back."
SrMi
Raist3d wrote:
SrMi wrote:
Raist3d wrote:
Val_K wrote:
Nice photo!
FYI:
It is the total time from shutter press to the end of the assembly. The time from shutter press to start of computation is always less than a second in my test (1/800 sec shutter speed, sensor readout speed is likely the limiting factor).
Raist3d wrote:
SrMi wrote:
Raist3d wrote:
Val_K wrote:
Nice photo!
FYI:
OP mentioned in other post that the HHHR looks to have better detail because the IBIS does help, while given it was windy, the shots on the tripod actually ended up with more movement between shots.
