G9 or GX7/80/9 with 14-140?
Started Apr 11, 2022 | Discussions
Pannylumixfan Regular Member • Posts: 150
Hi,
I've been wondering which body folks (who own both the G9 and GX7/80/9) prefer to use with their Panasonic 14-140 lens (assuming they own one!).  For this question please just consider how the combination balances and handles, and how easy the camera's controls are to operate and disregard the additional useful features of the G9.
I've recently bought a GX9 as a second body to my G9 and have been pleasantly surprised how well it handles with my 14-140.
Thanks in advance for your replies.
Best wishes, Brian
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix DMC-GX7 Panasonic Lumix G 14mm F2.5 II ASPH
windmillgolfer
windmillgolfer Forum Pro • Posts: 17,782
Updated - Re: G9 or GX7/80/9 with 14-140?
Pannylumixfan wrote:
Hi,
I have G80 (x2) and G9, plus GM/GF bodies. I recently added a GX80, which is very similar body and weight-wise to the GX9. The 14-140mm sits well on the G and GX bodies, the G9 combo is noticeably heavier and bulkier. My choice of a body/lens combo depends on the intended subject matter. If the subject matter is moving, BIFs included, then for me it’s a G80 or G9. Though I tend to use the G9 with the 100-400mm.
The GX80 is for street and landscape, when the tilt screen works fine, with 12-60mm and the 14-140mm. The kit 12-60mm is very similar in size and weight to the 14-140, well balanced and easy to handle. The lenses zip tend to use with the GX80 are the 12-32mm and the 12-60mm.  I did try the GX80 for BIFs and quickly decided it didn’t suit.
Best wishes, Brian
 windmillgolfer's gear list:windmillgolfer's gear list
Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-ZS40 (TZ60) Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GF7 +13 more
larsbc Forum Pro • Posts: 18,282
Hi,
Best wishes, Brian
I don't have that lens but I find that the GX9 handles just fine with all my lenses (12-60, 12-35/2.8, 35-100/2.8, 8-18)  save for the 100-400 which benefits from a bigger grip so I can hold the entire thing more steadily.
marvinvee Regular Member • Posts: 188
I would use the 14-140 on the g9. The 14 -140 is a bit heavy for the gx 7-8-9. I   had a g7 with the 14-140. as i am getting older I went with the gx9 a lot lighter to hold. The g7 and the 14-140 was a god combo. But I like the gx9 with the 45 -150 for my kind of photographing. plus, I have other lenses that i also use.                            Just my 2 cents
 marvinvee's gear list:marvinvee's gear list
Olympus E-1 Panasonic Lumix DMC-GF1 Panasonic Lumix DC-GX9 Olympus Zuiko Digital 35mm 1:3.5 Macro Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 +5 more
scphoto
scphoto Senior Member • Posts: 2,094
Hi,
Best wishes, Brian
I have a GX9, G9, and the 14-140mm lens. For me personally, both bodies handle this lens very well. If you want a smaller lighter and less obvious camera, go with the GX9. If you need the extra features of the G9, go with that. If you are using the camera for wildlife action photography, go with the G9 because the AF is faster and more accurate. (But you said not to consider the non-handling camera features, so maybe AF is not important to you???)
Just my two cents ...
- Simon
 scphoto's gear list:scphoto's gear list
Olympus Tough TG-4 Sony RX100 VI Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 OM-1 +1 more
Impulses Forum Pro • Posts: 10,039
I'd use it even on a GM or GX850 if I had that lens, and I have used one on them in the past (as I gifted a 14-140 to my mother, who uses it on a G85). It's a small enough and light enough lens that I doubt you'd face any unsurmountable issues on any kinda body.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
My favoured walk around setup is still GX8 + 14-140 MK2.  ...even though for most other tasks I shoot Olympus now.
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
OP Pannylumixfan Regular Member • Posts: 150
Hi Simon,
Thanks for your comments.
AF is important to me; it's just that I was interested to hear about how people find the handling of the respective setups.
