IBIS v OIS lens stabilization question ..
Started Apr 11, 2022 | Discussions
britcam
britcam Senior Member • Posts: 2,583
I have used an X-E2 for many years, along with predominantly zooms lenses (10-24, 18-55, 18-135, 55-200) as well as occasionally, the excellent 60 macro.
I am looking to upgrade to the X-S10, but can anyone advise how many stops of stabilization my OIS lenses give compared to using IBIS with the X-S10 ?
If the difference is marginal, then I feel that I may as well move up to the T3, as that body is available new, for less than the S10 where I live ...
Regards
Rich S
 britcam's gear list:britcam's gear list
Fujifilm X-E2 Fujifilm X-M1 Fujifilm X-S10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +8 more
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50) Fujifilm X-E2
ednewton New Member • Posts: 11
Re: IBIS v OIS lens stabilization question ..
Taken from the DP Review:   'It offers 6 stops of shake reduction on all unstabilized Fujifilm lenses save for the XF 16-55mm F2.8, which weighs in at 5.5 stops. Most stabilized Fujifilm lenses vary from 5.5 to 6 stops, save for the XF 80mm macro, which offers 5 stops.'
britcam
OP britcam Senior Member • Posts: 2,583
Many thanks ... in that case, it looks like the T3 is the way I should go , which is my much preferred option,  having compared it's handling directly with the S10 ...
Regards
Rich S
Propheticus Junior Member • Posts: 28
Found some older discussion on the same:
https://www.dpreview.com/forums/thread/4526488
Looks like a combo of IBIS and OIS can add up to 1.5 stop of stabilisation.
IBIS also offers stabilisation on more axes than OIS.
See https://fujifilm-x.com/en-us/stories/intermediate-month-3-motion-10-ois-and-ibis/
 Propheticus's gear list:Propheticus's gear list
Fujifilm X-S10 Fujifilm XF 16-80mm F4 Fujifilm XF 16mm F1.4 R WR
Travelerdave Regular Member • Posts: 183
I was under the impression that with both available, when the lens has OIS as well, they work together covering different Aries each.
edit - I’m sorry, I see now that is all answered in the link in the previous post
 Travelerdave's gear list:Travelerdave's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H1 Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Miller_bike Regular Member • Posts: 164
I had an XE2 (then XE3 then XT2) but now have XS10. My interest is mainly video these days and for that, IBIS is a big advance over OIS. The XS10 is a lovely camera, the one I've liked most in the digital era.
Atsel
Atsel Regular Member • Posts: 265
If all your lenses are zooms with OIS, then the difference is marginal from my experience
Almost no difference for 18-135, around a stop difference for 18-55
 Atsel's gear list:Atsel's gear list
Olympus PEN E-PL2 Nikon Coolpix P330 Samsung GX-20 Panasonic Lumix DMC-GM1 Olympus PEN-F +42 more
DarnGoodPhotos Forum Pro • Posts: 11,881
Bear in mind that IBIS stabilizes different motion than OIS stabilizes. Combined you get better stabilization even if the number of stops is similar.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 18mm F2 R +3 more
Atsel
Have you experienced that in real life?
If so, with what lenses?
OIS stabilizes tilting motion. IBIs stabilizes up/down, left/right, and forwards]/backward motion. Together its called six-axis stabilization.
Atsel
OK, let's just believe it has its advantages
Wolf's Head Regular Member • Posts: 407
I’ve never understood the ‘five axis’ (or in this case ‘six axis’) thing. Surely there are only three axes and the motion of any point in space can be described using them…
Best wishes,
Alan J
Monochrome photography blog :: https://penycae.wordpress.com
Image galleries :: http://www.pbase.com/wolfs_head
 Wolf's Head's gear list:Wolf's Head's gear list
Sony RX100 IV Leica Q2 Fujifilm X-Pro3 Nikon AF Nikkor 50mm f/1.8D Fujifilm XF 18-55mm F2.8-4 R LM OIS +18 more
OrigamiCactus Contributing Member • Posts: 667
yes, you said it yourself, the motion of a point.
But if you want to describe the motion of a 3D object, then you need to add tilt/roll/ swivel? for a total of 6.
 OrigamiCactus's gear list:OrigamiCactus's gear list
Fujifilm X-T4 Fujifilm X-Pro3 Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +1 more
Propheticus wrote:
This article talks about Sony, but the same is true with Fuji.
https://alikgriffin.com/how-in-body-stabilization-works-3-axis-vs-5-axis/
