Canon Macro Twin Lite MT-26EX-RT question
Started 11 months ago | Questions
danferrin Contributing Member • Posts: 730
I have an EOS R5 and the EF 100mm L macro lens.  Recently I decided that I wanted to get the Macro twin lite for my system, and three weeks ago I ordered it direct from Canon.  I immediately received a backorder notice and have not yet received my flash.  With Spring sprouting up, I would really like to have my lite.  I know I can shoot macro without it, but have been anxiously looking forward to shooting with it.  Just wondering if anyone here has this light, and if so, how long it took to get it.
My life is a circle of confusion - photography is my meditation.
See my work at www.danferrinphotography.com
 danferrin's gear list:danferrin's gear list
Canon EOS 60D Canon EOS 7D Mark II Canon EOS RP Canon EOS R5 Canon EOS R7 +20 more
Canon EOS R5
Larry Cunningham
Larry Cunningham Senior Member • Posts: 1,228
Re: Canon Macro Twin Lite MT-26EX-RT question
I'm in the same situation as you. I've been using a Meike MK-MT24II-C twin flash, and want to move up to the Canon flash. Of course, just when I decide to hand somebody all that money for the Canon flash, nobody has it in stock (other than some miscreant on Amazon who wants about $1300 for the kit). I'm monitoring for availability, and will post here if I find anyone selling them (after ordering my copy ).
Larry
 Larry Cunningham's gear list:Larry Cunningham's gear list
Canon EOS M5 Canon EOS M3 Canon EOS M6 II Canon EOS R7 Canon EF 50mm F1.8 II +20 more
OP danferrin Contributing Member • Posts: 730
Looks like we're practically neighbors.  I'm south of Canal, almost to Chestnut Ridge.  I can usually find anything I need at Midwest Photo, but they're on backorder, too.  So, I figured Canon Direct was my best shot, but no luck so far.
Larry Cunningham
We are indeed nearly neighbors. I'm just north of Gahanna and south of Blendon Woods Metro Park.
I'm starting to think that the Canon macro flash might be a victim of the infamous chip shortage. I'll keep looking!
Larry
John K Veteran Member • Posts: 9,870
The working distance of that lens, at 1x, is 6" (`15cm). IMHO macro twin flashes (all of them) perform best at working distances in the 4" (10cm) or less range. The flash heads are small, and the diffuser that Canon supplies with the MT-26EX RT is not that great (really does nothing to make the light larger). The larger a light source is in the subject's field of view the softer the light, so getting good light quality from a macro twin flash is tough.
I use the MT-26EX RT with the MP-E 65mm and the EF-S 60mm and have spent many years experimenting with different diffuser designs and materials. Here is a video of an older set that I built, but my current set is similar (just a little larger):
Here is a recent shot that I took:
Tech Specs: Canon 90D (F11, 1/125, ISO 200) + a Canon MP-E 65mm macro lens (set to 2x) + a diffused MT-26EX-RT, E-TTL metering, -2/3 FEC. This is a single, uncropped, frame taken hand held. In post I used Topaz Denoise AI and Clarity in that order. Shutter and ISO set to expose the sky in the background.
I took that one at 2x, so the distance from the front of the lens to the bee was 2.5" (6.35cm). Here's what the light looks like at 1x (4" or 10cm working distance):
The greater the working distance the harder it is to get good specular highlights. If the light is not diffused enough the specular (reflective) surfaces will return the color of the light source instead of the color of the specular surface and you will lose detail.
Not saying that you cannot use a macro twin flash with a 100mm lens, but you might look into either getting the flash heads closer to the subject or using extension tubes to go above 1x and reduce the working distance. You could also get an EF-S 60mm and use a 12mm (or larger) extension tube so you can attach it to your R5. I use to shoot with a 1D Mark III using the EF-S 60mm and tubes and it worked fine. Best to get some practice shooting above 1x with a standard macro lens before you buy the MP-E 65mm.
Thank you John.  Those really are great shots, and good information.  My primary intention for the macro twin lite was to photograph my wife’s jewelry, which she sells online.  Mostly, she does beaded bracelets, and I thought the macro.lens and light would be a good solution.  Because of the unavailability of the light, we’ve decided to go with a continuous light source and bought three of the Westcott Solix bicolor lights and a Novoflex Magic studio setup.  Still plan to use the 100mm macro on the R5, but with continuous light, my wife will be able to judge the lighting better before we shoot.
by the way, I called Canon support yesterday to ask when they expected to ship the twin lite, and they had no idea.
danferrin wrote:
Thank you John. Those really are great shots, and good information. My primary intention for the macro twin lite was to photograph my wife’s jewelry...
You are infinitely better off with a small softbox and one or two standard flash units on stands.
Larry Cunningham
While I'm waiting for the Canon Macro Twin Lite to show up, I thought I would explain how I use a macro twin flash. (I'm currently using the Meike version.)
I don't take "true" macro shots of the sort John K discusses using a twin flash. I sometimes delve into that type of photography, but when I do it's with totally different lighting.
I also don't use the twin flash to take photos of small items like jewelry; for that I use a softbox as suggested by danferrin.
I use the twin flash for a specific kind of plant photography, using a technique that was taught to me by an ace naturalist/photographer a few years ago. My goal is to get photos of small plants like tree buds and wildflowers using lighting that throws the background of the photo into almost complete darkness. If I do it right, the result is a photo that doesn't need a lot of postprocessing to look like a "scientific specimen" photo.
First my gear, which includes a Canon EOS M6 Mark II with a Canon EF 100mm f/2.8L IS USM macro attached using a Canon adapter. The Meike twin flash is attached to the end of the lens, of course.
The camera is set to Manual mode. The flash is set to manual at 100% power. The shutter speed is set to the camera's sync speed, which in the case of this camera is 1/200 second. The ISO is set to either 100 or 200. The f/stop is initially set to a really small aperture, like f/22 or even f/32. I take a couple of test shots, adjusting the f/stop as needed for proper exposure.
Here are three examples from a recent outing to photograph early-spring tree buds; hopefully, the EXIF details will survive the upload.
Larry
Larry
Sorry Larry, but it is called flash fall off and it can be done with any flash. In fact it is really easy -just do not place anything close behind the subject, or expose for the natural light in the background. I call it macro on easy mode because anyone, with any flash, can do it. You do not need a macro twin flash to get dark backgrounds.
Taken with the MT26EX RT:
Notice the black background behind the wasp.
Also taken with the MT26EX RT:
ISO and shutter  set to expose for the natural light in the background.
Same flash, different backgrounds...
Here is an example using an artificial flower to keep the background from being black (so nothing but the flash in this next shot):
No need to be an ace...
Larry Cunningham
I guess we'll have to agree to disagree. I've tried on-camera and off-camera Speed Lite type flashes (most recently the Canon 600EX II-RT), several brands of ring flashes, and two brands of twin macro flash, and I prefer the results and flexibility I get using the twin macro flash.
I work alone in the field (mostly local and state parks), and due to physical limitations (mostly just aging), I try hard to travel light. The combination of a mirrorless camera and a lens-mounted twin flash give me the best bang for my buck.
Larry
Thanks to both John and Larry for your perspective.  I’ve looked at both of your work and am impressed by both.  I look forward to getting my twin flash, whenever it shows up, and learning what I can do whit it.
The inverse square law is physics Larry so you are not disagreeing with me, but with science.
Larry Cunningham
I was not disagreeing with you regarding the inverse square law, and I resent the implication that I'm that ignorant. I've been a serious amateur photographer for well over fifty years, I don't need any lectures on basic optics. I never stated nor implied that I had somehow discovered something new to science or photography. I described my method for the sake of those who might not be familiar with the technique. Not everybody is as savvy as you obviously are.
I was disagreeing with this statement of yours:
"I call it macro on easy mode because anyone, with any flash, can do it."
You can indeed do it with any flash, or any light source for that matter, but I have found that I get by far the best results with a twin flash.
Please don't expect any more replies from me in this thread. For whatever reason, you seem determined to argue about something not worth arguing about, and life is too short.
Larry
From a previous post of yours:
"I use the twin flash for a specific kind of plant photography, using a technique that was taught to me by an ace naturalist/photographer a few years ago. My goal is to get photos of small plants like tree buds and wildflowers using lighting that throws the background of the photo into almost complete darkness. If I do it right, the result is a photo that doesn't need a lot of postprocessing to look like a "scientific specimen" photo."
You do not need to be an "ace photographer" to let the background go black due to flash fall off, and no one flash will give you better results than another one. They all are effected equally by the inverse square law. You made black backgrounds sound difficult or special, when anyone can do it and it is easy...
Edit: Not really trying to pick on you, I just do not want to see someone buy a twin flash thinking that it will perform differently than a standard flash unit. Also it kinda sounds to me like you are trying to talk yourself into getting a twin flash, and me thinks you are gonna be disappointing with it. Out of the box they are BRUTALLY harsh and difficult to diffuse in a short distance.
c h u n k
c h u n k Senior Member • Posts: 2,042
I use the Yongnuo twin flash. Its solid. I havent tried it with my R mount yet though. I will test it out. I also had the yongnuo ring flash and there were some compatability issues when I sold my 70d to replace with 80d so I would make sure it works, but if it is all clear, I can definitely suggest it. Honestly, I wouldnt pay the price for tcanon twin flash with other options
Some of my photos here: https://flic.kr/ps/2i6XL3
“You're off to Great Places! Today is your day! Your mountain is waiting, So... get on your way!” --Dr. Seuss
 c h u n k's gear list:c h u n k's gear list
Canon EOS 70D Canon 6D Mark II Canon EF 85mm F1.8 USM Canon EF 100mm f/2.8 Macro USM Tamron AF 28-75mm F/2.8 XR Di LD Aspherical (IF) +7 more
c h u n k
Easy boys. Goodness gracious.
While John is def right that its very easy to drown out all ambient light, even in the middle of the day with almost any speedlight, twin flashes do have a purpose I specifically use them for - or I should say a couple purposes now. Ironically, one of them is lighting the background as I prefer not have black backgrounds in most of my shots. I will get to those in a second. Before I do, I want to add that while I agree with John that using the twin flash without being creative with solutions does make it less than optimal with longer working distance macro lenses. Its harsh because the light is too far from subject. However, there are small magic arms that can mount to the adapter giving you much more flexability with flash head placement. You can easily get the heads with diffusers right on the subject while using a 100mm macro for instance. Not to mention, you can simply reduce working distance by using an achromat. The DCR250 changes magnification from 1:1 (min) - 2:1 (max) if memory serves.
One thing the twin flash does is "mold" the subject. When you use a speedlight, it creates a pleasing, but flat lit image because all of the light is coming from just slightly above and directly from the camera. Kind of like beauty lighting in portraits, but sometimes in the macro images shadow can be an issue. When you use 2 lights from different angles it gives depth to the subject. You can also use it so you have a main/key light and fill, getting rid of the shadow issues.
Lastly, I have another set up with much longer arms. I will sometimes  use one flash to light the subject and have the other light at full blast hitting the background. This has worked great sometimes and helps me from having to hold something to work as a background behind a skittish bug.
Using the yongnuo twin flash to light background
Notice catch lights in spider. Both lights evenly lighting opposite sides giving a feeling of depth. Especially around the spiders chelicerae. I feel like I can grab them.
One last photo showing both the depth Nd the fill made possible witb 2 lights
c h u n k
Oh, let me also add, and this time without caveats, that JK is absolutely right about twin flashes not being an out of the box and off to the races type thing --- well, unless you are taking shots that dont necessarily require "pleasing" light, like if you are just documenting different specimens of insect, whatevs. Maybe it will be fine. But if you want pleasing, non harsh light, it takes some time and practice...and experimenting, but thats 3/4 of the fun of photography! I will say this, Im not yet content with my diffusing solutions. I have a couple ways to diffuse with them, but I think I can still come up with something better. I also really, really LOVE the long arms for some situations but I keep breaking them. Sooooo frustrating. I just wish someone would make them so they can be moved around a lot without snapping. The ones I used was basically a long arca plate with 2 goosenecks attached on either side. I just attached cold shoes to the ends and vula. Those things are super strong. Could hold 2 small speedlights, but that would be a beast to handle. Its just when I keep adjusting them, eventually they snap where the arms connect to the plate. Errrrrr
