GH6 Standard vs HHHR vs HR examples
Started Apr 11, 2022 | Discussions
OP Interceptor121 Veteran Member • Posts: 8,691
f/5.6 example
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: f/5.6 example
Interceptor121 wrote:
HHHR
Standard
Thanks for that. It's hard to judge here on DPR and on a phone. But I see they are the same resolution and megabytes?? Either way, the GH6 seems to handle contrasty stuff like this very well.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
Re: f/5.6 example
I scaled them to 25 megapixels so that you can look at 100% and see the SNR benefit. As we know pixel shift has not a lot of impact on resolution itself in pure terms
mikero
mikero Veteran Member • Posts: 3,057
Re: f/5.6 example
Doesn't look like a night and day difference to me.
Mike
 mikero's gear list:mikero's gear list
Olympus E-M1 II OM-1 Olympus Zuiko Digital 2.0x Teleconverter EC-20 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
Re: f/5.6 example
Mike
No it is very small from what I can see and only in the really deep shadows
mikero
Re: f/5.6 example
Mike
I'm puzzled as to why these latest two look almost the same from a contrast perspective, but your original samples showed a massive difference in contrast between standard and high res.  Any idea?
Mike
BackToNature1 Senior Member • Posts: 1,796
Re: f/5.6 example
HHHR
Standard
Are you shooting handheld or using a tripod for the Standard shots? Also, when shooting in standard mode for these types of shots, are you manually assuring critical focus for things you might want more in focus?
Re: f/5.6 example
BackToNature1 wrote: shooting in standard mode for these types of shots, are you manually assuring critical focus for things you might want more in focus?
The last examples are all handheld and yes everything is in focus at f/5.6 the images are quite flat
Re: f/5.6 example
Mike
Mike
The images I posted today have been processed with lightroom the previous ones with siklypix
When I look at the same images in adobe they look almost identical so I guess silkypix is adding something to the mix or adobe is flattening the differences
pdelux Senior Member • Posts: 1,113
Re: f/5.6 example
HHHR
Standard
interesting, there is very small increase in sharpness/detail in the HHHR, but only because I tried really hard to look for it.  I cant see any DR improvement but maybe you need to push shadows to see it.
this is a little disappointing and not inline with my expectations.
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
Re: GH6 Standard vs HHHR vs HR examples
Maybe the higher bit depth of the raw files helps with tonality
I always thought 12 bits was a bit busy
So the RAW files are 14 bit ?
16 bits
We've had demands in the past on here for a 14 bit sensor, then we get one with an even higher bit rate and nobody even mentions it....
If it was from Olympus and not Panasonic, some people would have wet themselves
there no point in a 14 bit file if the 13/14th bit is full of noise. When M4/3 can reach 15ev of tonal range, then maybe it will be useful.
Right now, I cant see where those extra bits are being useful.
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: f/5.6 example
HHHR
Standard
But if the standard image was scaled up to match the HR image you would easily spot the difference.
20-25mp really is enough for 95% of usage. The other 5% either print enormous sizes or crop a lot!
NB: the above percentages are a guesstimate
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Re: f/5.6 example
Adrian Harris wrote:
HHHR
Standard
I think something may be going on with lightroom as the images in silkypix look better see original thread you could see a difference in a 2 Megapixel file
Richandhiscat Senior Member • Posts: 1,199
Why should the 13th/14th bit be full of noise, and the other 12 aren't?
Haha very funny in effect most of the read noise will be in the shadows so actually in the least significant bits!
In general terms more bits are a good thing as one noise source is quantisation noise so the argument of your opponent is flawed by definition as read and shot noise are always there regardless and quantisation noise increases as bit depth reduces
In general higher bit depth bigger files but if you have a set value and you convert it to 12 bit precision you don't have less noise than if you converted to 14 bits precision in fact the opposite as you reach the bottom or top of the scale
More the better.
Bits and bit depth explained - Life after Photoshop
Re: f/5.6 example
Even in the original images - its hard to see any gains in detail in high res.
The high res shadows look lifted so perhaps there is cleaner data there.
As Adrian suggested -- i wonder if you blow up the standard shot to the High res image size -- we should see a more notable difference.
please see this article
https://www.dpreview.com/articles/4653441881/bit-depth-is-about-dynamic-range-not-the-number-of-colors-you-get-to-capture
"In other words, 12-bits provides enough room to encode roughly 12 stops of dynamic range, while 14 bits gives the extra space to retain up to around 14EV. Or to look at it from the opposite perspective: if your camera is overwhelmed by noise before you get to 12 stops of DR, you don’t benefit from more bit depth: all you’d be doing is capturing the shadow noise in your image in greater detail."
Even on FF - you will be hard pressed to see any IQ improvement from 12 to 14. By ISO 400 on FF there is almost no advantage at all. In M4/3 terms with current sensor = thats like ISO 100.
