GH6 Standard vs HHHR vs HR examples
Started Apr 11, 2022 | Discussions
Interceptor121 Veteran Member • Posts: 8,691
I am doing some HR as I have had the opportunity to shoot some landscapes recently
Generally the images come slightly brighter (I prefer the look of the standard ones) and the benefit is mostly SNR for HHHR with HR having some resolution benefit in essence it confirms the theory that resolution does not improve but IQ does
Here are some shots scaled down to 2048 wide as I am a slow connection during the trip
Standard shot
HHHR shot
Standard shot
HR shot
HR shot with sharpening
Generally HR shots can take more sharpening as in the last example
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
glassoholic
glassoholic Veteran Member • Posts: 7,641
Re: GH6 Standard vs HHHR vs HR examples
Standard shot
HHHR shot
Standard shot
HR shot
The 2048 size makes it hard for me to glean much from this. Also f10/ 11 is not doing the sensor any favours.
Regardless, images from the GH6 look different to me. Maybe I am wishing for something and talking myself into it, but the GH6 images look better than the 20mp sensor we are all so used to. It can't be the small extra resolution, so I wonder what it is. It's hard to find words, but "richer, smoother, more depth, greater tonality range" is my attempt to describe what I see, whereas the 20mp sensor would be "more crunchy looking details, harder, harsher tonality, flatter" looking. Dunno??? Hopefully as more people use the GH6, a pattern one way or the other will show through.
Addicted To Glass
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me... Make the best you can of every day!
OP Interceptor121 Veteran Member • Posts: 8,691
There is no issue with f/10 f/11 in general although the first shot I could have taken at f/4 as there is nothing behind the rock the second requires small apertures as the valley is km away from the rocks
With regards to the look you mention I am victim of the same effect perhaps but the images look very similar to my last APSC DSLR Nikon D7000 at ISO 100
glassoholic
A reference I have is a Nikon D700. The GH6 has that D700 smoother, richer and deeper look to it, but very similar in other technical qualities (other than the D700 being overall superior at >ISO3200).
Addicted To Glass
Took this shot few days ago with the 25mm
glassoholic
Super skin tones to my eyes... I had that lens and am familiar with its rendering. GH6 seems to make it look even better.
Could you do something similar with your G9 and the GH6 at matching settings?
Addicted To Glass
I am on a trip and I only have the GH6 but will try something when I get back
as i said it may be placebo!
Richandhiscat Senior Member • Posts: 1,199
Tat's the impression I get, the later portrait shot looks even better.
Maybe the higher bit depth of the raw files helps with tonality
I always thought 12 bits was a bit busy
glassoholic
Instead of 1.4, shoot at f4.0 so that any "softness" or "smoothness" influence from the lens is more eliminated and the sensors from the two can be isolated better for their character and compared.
That PL25 is similar to the Oly 25 Pro, in that they both render skin tones very nicely, especially at f1.4-2.0.
Addicted To Glass
I don’t think I ever got past f/2.8 !
So the RAW files are 14 bit ?
Virtual Photon Senior Member • Posts: 1,701
You might want to take a look at this explanation  of diffraction about 2/3rds down the page.
The depth of field necessary to hold the details in the valley of the second image might have only needed f4 given the DOF of 12mm with a subject at 10m, everything from about 2m to infinity will be in focus.
 Virtual Photon's gear list:Virtual Photon's gear list
Nikon D500 Nikon Z7 Nikon Z6 Nikon AF-S Micro-Nikkor 60mm F2.8G ED Voigtlander 20mm F3.5 Color Skopar SL II +9 more
16 bits
That website is trash. The start if diffraction effects is f/11 and doesn’t depend on pixel pitch
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
If pixel peeping at 1 to 1,  diffraction will be more visible with smaller closer pixels.
However if we consider the whole image, then having smaller closer pixels 'should' not show any observable adverse effect from diffraction - at the same settings.
PS. I have always found Cambridge in Colour to be a very helpful website..
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
eques Veteran Member • Posts: 4,115
Difficult
Thank you, landscapes are where I would wish for more resolution!
At this size it is difficult to see any differences in resolution, DR or noise. At least not at the level of Standard vs HR modes. Perhaps you could provide some 100% details?
Standard shot
More difficulties:
  • the Standard image is darker and has much more contrast, this makes it appear sharper.
  • t f/11 the lens is nowhere near it's sweet spot. You loose about 1/3 of the highest possible resolution around f/4:
  • as you mention, HR and HHR mode needs more sharpening than standard mode according to what I read.
Nice pictures by the way and interesting scenery!
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
Diffraction is a process driven by the lens and sensor size
This is a good website
https://www.scantips.com/lights/diffraction.html#calc
f/9 identical to sensor resolution, f/10 not diffraction limited, f/11 start of diffraction effect
For those landscape shots I would normally shoot f/9 f/10 not f/4 if there is a feature close by. If there is nothing near I would go f/4
Adrian Harris
Diffraction is a process driven by the lens and sensor size.
I think we are often a little loose with terminology. The Diffraction process is certainly by lenses, and it's observable effect in our images will differ depending on sensor size.
That is a very interesting webpage. Thank you.
16 bits
We've had demands in the past on here for a 14 bit sensor, then we get one with an even higher bit rate and nobody even mentions it....
If it was from Olympus and not Panasonic, some people would have wet themselves
