Stylus1s minor repair.
Started 11 months ago | Discussions
Ken Croft Senior Member • Posts: 1,803
8
My old and well used Stylus1s had a problem with the mounting of the rear screen.  The whole rear screen hinges on 2 metal brackets fastened to the rear of the camera, and these brackets were both loose allowing the screen to rattle about when tilted. I thought at first of gently getting some epoxy glue underneath them to stop them rocking about but in the end I took the bull by the horns and I decided to open up the camera. There are 8 small screws holding the camera back in place and when removed the back can be gently eased off. [Two of these are only accessible when the viewfinder eyepiece is slid off upwards]. I removed all 8 small screws and removed the complete camera back. There is a wide ribbon cable attached to the camera back and I left this connected. The brackets about which the screen pivots are held in place by 4 small screws all of which were very loose. They were easily tightened and when back together the screen is now as solid as when new. And the camera still works!!
I will attach a picture of the inside of the camera with the problem screws circled in red. I hope this may be of help to anyone having a similar problem, or just wanting for the fun of it, to have a look inside a Stylus 1.
Stylus1s. Screws holding rear screen brackets circled in red.
Ken C
Kerusker
Kerusker Senior Member • Posts: 1,446
Re: Stylus1s minor repair.
Ken,
thanks a lot for the info.
If necessary, I'm encouraged to grab the bull by the horns.
][.Kerusker
we don't see that we don't see (eye's blind spot)
 Kerusker's gear list:Kerusker's gear list
Sony RX10 IV Pentax K-1 Pentax smc DA 15mm F4 ED AL Limited Pentax K-5 IIs Pentax smc FA 50mm F1.4
xmeda
xmeda Senior Member • Posts: 1,898
If you have camera opened like this it is also a good idea to clean the PASM switch area and remove all dust particles you can see with blower and careful use of vacuum cleaner .)
 xmeda's gear list:xmeda's gear list
Casio QV-R40 Casio Exilim EX-Z110 Olympus XZ-1 Pentax X-5 Olympus XZ-2 iHS +42 more
