Canon M6 MKII L-Bracket With Battery Door Access
Started 11 months ago | Questions
Combat By Design
Combat By Design Regular Member • Posts: 331
"Note: looking for M6 MKII specific (not universal) bracket as I need battery door access"
So it looks like SmallRig discontinued the M6 MKII L-Bracket...
Has anyone found another company that makes one?
Kevin M. Byers
www.combatbydesign.com
Instagram, Twitter, Facebook:
@combatbydesign
 Combat By Design's gear list:Combat By Design's gear list
Canon EOS Rebel T4i Canon EOS 7D Mark II Canon EF 50mm F1.8 II Tamron SP AF 200-500mm F/5-6.3 Di LD (IF) Sigma 50mm F2.8 EX DG Macro +8 more
Canon EOS M6 Canon EOS M6 II
Andy01 Veteran Member • Posts: 5,188
Re: Canon M6 MKII L-Bracket??
There are plenty of generic L brackets that would work, but perhaps be a bit clumsy and would prevent the battery door opening, but if it was for fairly infrequent use they would work.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
Misha883 Junior Member • Posts: 42
Combat By Design
OP Combat By Design Regular Member • Posts: 331
I'll check it out, thanks!
Any idea if it works with the Canon lens adapter, with the tripod mount attached?
Kevin M. Byers
@combatbydesign
Larry Cunningham
Larry Cunningham Senior Member • Posts: 1,228
I'm not familiar with the L-bracket you're asking about, but I do use the now-discontinued SmallRig L-bracket. The tripod mount that comes with the EOS-EOS M adapter won't work with the SmallRig L-bracket.
I looked long and hard for any L-bracket with would work with the Canon adapter/tripod mount combination and never found one.
Larry
 Larry Cunningham's gear list:Larry Cunningham's gear list
Canon EOS M5 Canon EOS M3 Canon EOS M6 II Canon EOS R7 Canon EF 50mm F1.8 II +20 more
Mike Arledge Senior Member • Posts: 2,465
I use this one and it allows the mount adaptor to be used. I have used it with M6ii, adaptor and EF 16-35 F4 with no issues
https://www.bhphotovideo.com/c/product/1347311-REG/3_legged_thing_qr11_lc_copper_110mm_l_bracket.html?sts=pi&pim=Y
And not even really expensive, plus I can slap it on my R6 as well.
One small piece of advice, if you plan on using the tilt function of the screen, pull it out before mounting.
 Mike Arledge's gear list:Mike Arledge's gear list
Nikon Z5 Nikon Z fc Sony a7 IV Canon EF 24-70mm F2.8L II USM Sigma 28mm F1.4 DG HSM +5 more
drsnoopy Senior Member • Posts: 1,216
The Smallrig cage for the M6 mk II is still available from Amazon UK. I don’t know if you could get it sent to you from UK, but worth a try.
https://www.amazon.co.uk/SMALLRIG-Camera-Cage-Canon-Mark/dp/B08391V46C/ref=sr_1_19?crid=W75KWG1JSPCL&keywords=L+bracket+canon+EOS+m6&qid=1649528153&sprefix=l+bracket+canon+eos+m6%2Caps%2C123&sr=8-19
 drsnoopy's gear list:drsnoopy's gear list
Canon EOS RP Canon EOS R5 Canon EOS R10 Canon EF 100mm F2.8L Macro IS USM Canon RF 35mm F1.8 IS STM Macro +10 more
Jack Calypso Senior Member • Posts: 1,094
The cage is not an L-bracket, though; the Arca rail is only on the bottom, so it's not straightforward for portrait orientation. I have the similar (and I think better) cage from UURIG, and got around this by attaching a small plate that had an Arca flange on it, which I can't find on SmallRig's site now [cue the conspiracy music ]
Are you talking about attaching an L-bracket to the mount adapter? If you had an anti-rotation thing in place, I don't see why not.
If you mean a conventional setup, where the bracket is attached to the base of the camera, the dimensions of the M6 mkII are a big constraint. The distance from the rear of the tripod foot of the adapter to the edge of the LCD, which needs to swing free, is only 28mm, but an Arca rail is 39mm. And even if you can attach it, the mount foot will almost certainly obstruct the clamp on your tripod.
For that, it would be best to just detach the foot.
This one from Fotodiox would look so nice on the M6 mkII, with battery door access too.
Too bad it wouldn't fit, and that anti-rotation flange would get in the way of the LCD.  The "Senior" version would fit, but block the battery door and still has the flange.
Back to the drawing board/search engine.
Yes, but easy to add a small Arca plate to the left side, then it’s an L-bracket!
Combat By Design
No, I was talking about attaching it to the body, and just leaving it there.
I occasionally use the Sigma 18-35 with the M6, and mount it to the tripod via the adapter because that's a heavy lens, and I just didn't want to keep having to remove the L-Bracket, especially in the field.
I actually have a mini mount on there, right now, that leaves a gap about the width of a piece of paper between it, and the foot, without obstructing the screen, but yeah... It looks like most of the L-Brackets out there are a little too wide.
This works fine for normal tripod use, but I was considering picking up a wider EF-M mount lens to do sweeping, vertical time lapse shots, and wanted to be able to mount the camera with an L-Bracket.
But so far most of the suggestions I'm getting are for universal brackets which, as we know, block access to the battery/card door
Looks like I might have to forego the EF-M lens, pick up another EF/EF-S and just buy/fashion a bracket to attach to the adapter foot, instead.
Kevin M. Byers
@combatbydesign
Combat By Design
I'm very quickly realizing that the only L-Brackets that exist for this camera probably have the right-side grip because there's almost no space between the door and the mount and that's the best way they could figure to stabilize it.
Kevin M. Byers
@combatbydesign
Combat By Design
Please note:
I'm specifically looking for one with battery access.
(Also: bummer that we can't edit original posts)
Kevin M. Byers
@combatbydesign
This morning, I found the part number of the SmallRig plate engraved on it — it is the APU2389. Low profile and allows access to the microphone and remote ports. Works great.
Re: Canon M6 MKII L-Bracket With Battery Door Access
Don't make the same mistake I made: I saw a nice looking bracket on AliExpress; when I received it, I realized it was for the Mark I, not the Mark II. Didn't fit
Re: Canon M6 MKII L-Bracket?? Battery Access and Tripod bump.
The bracket on ebay I referenced above fits nicely on the M6 II with access to the battery compartment. The tilt screen opens nicely.
I'm not exactly certain about your exact issue with the EF to M lens adapter. On the Viltrox adapter the "bump" on the bottom of the adapter is removable. I'm not sure if this is removable on the official Canon adapter or on adapters made by other manufacturers.
Larry Cunningham
I can confirm that that "bump" on the bottom of the Canon adapter is not removable. It is part of the body of the tripod foot.
The "bump" on the Canon adapter is more like a flange. It's located on the camera side of the adapter, and apparently serves to keep the adapter from rotating. The red arrow in the photo below is the flange I'm referring to.
That "bump" also prevents me from using the tripod foot on the adapter with my apparently-now-discontinued SmallRig LCC2516 L-bracket.
Larry
Larry
But even if you could attach the bracket with the mount adapter installed, the foot would obstruct the clamp on your tripod. And if you were using the L-bracket, you wouldn't be using the foot. So why not just detach it and work?
Combat By Design
Larry
The foot is attached with a hand screw, and it's easy enough to detach and stuff in your pocket any time you wouldn't need it but you don't want to be fumbling around with allen keys to remove the bracket every time you wanted to switch to a heavier lens, in the field.
Kevin M. Byers
@combatbydesign
