Yannis1976 wrote:
elmar1 wrote:
Thanks for all the feedback. I carefully weighed all the arguments and pixelpeeped the results of the sony rx0 ii and the tg6. Fun fact: though a lesser resolution, the details and color were better.
This argument and the fact that the tg6 was at 440 Euro and the rx0 ii at 650 gave the advantage to the tg6. I received it yesterday and found a setting locked somewhere in a customisation menu how I can set the resolution to 4000x3000 with super fine as compression. So the results should be better now than before looking forward to take the camera along with me on my swimming trip to Greece, starting end of next week. Thanks for all the help.
The TG6 is great and I would also recommend one of the two wide lenses for it!! Here are some of my samples, almost all with a wide lens:
https://www.dpreview.com/forums/post/65430226
https://www.dpreview.com/forums/post/64324770
https://www.dpreview.com/forums/post/63102057
However I need to warn you that TG6 is quite a fragile camera. Since 2020, I have lost two of them!! One had the usb door broken (still working though) and the one leaked through the battery door and went off!!
Although I used to be a big fan of them, I am know looking for the GoPro alternative in case it seems more robust.
Yes, the TG6 screen also scratches very easily. I received one from Amazon with a scratch on the screen from the getgo which I had to send back.
And unlike the GoPro there is no waterproof protective lens filter.
Another issue I have is that the screws on the front around the lens corrode very easily. If you do not remember to rinse and dry immediately (or you dont have a clean towel to do so) you will see corrosion. The GoPro simply doesnt have any exposed screws, so this is not an issue! That’s really how something like this should be designed; if not then better quality stainless screws need to be used.
All around however, having used both this summer, the TG6 takes the better underwater pics. The built in flash is great for fish (have not tested the gopro flashes) and the macro mode is amazing. Focus stacking impresses, considering this feature is not even available on the em10.
both have their place of course; the video is not as good as on my 5k gopro. GoPro’s stability correction for the video is unmatched and really smoothes out the camera shake. But the colors are never as good in GoPro stills as they are in the oly, and there is no zoom in the GoPro.
a bonus with the tg6 is having the handy live compisite mode, which is great for quick night shots like star trails or light trails. The gopro might have an equivalent mode for that, but the dials and buttons on the tg made that mode much easier for me to find.
