SD15 vs Fujifilm S5 Pro for bird photography
Started 11 months ago | Questions
kylep15 New Member • Posts: 4
Both camera has a unique sensor(Foveon, Super CCD) and I want to try it out.
I tried to search the comparison, but almost nobody mentioned on how it does on wildlife photography.
What I found is that both camera won't do good on low light.
However, bird photography usually takes place under bright daylight so it won't be a problem.
Which one will do the best on bird photography?
 kylep15's gear list:kylep15's gear list
Fujifilm FinePix S5 Pro Sigma SD15 Pentax K-7
D Cox Forum Pro • Posts: 32,979
Re: SD15 vs Fujifilm S5 Pro for bird photography
What lenses do you have ?
Sigma fp
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
The camera that has the best means of focusing on the bird, IMHO.
It's all in the numbers ...
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
OP kylep15 New Member • Posts: 4
I have Nikon 200-500mm and Sigma 150-500mm
I think you're in a better position than anyone to answer your question. You just have to go out with both cameras and photograph some birds to see the results.
The Fuji can probably be used at a higher ISO setting, which will allow faster shutter speeds.
I hope you will post some examples.
Don
Sigma fp
Don
My intention was to save much money as possible, but it seems like there is no answer without actual usage. Thanks!
Tiger1 Contributing Member • Posts: 581
I have an SD14 and a Fujifilm S5 Pro. I do not do bird photography but can tell you that the S5 focuses faster and more surely. Having said that there isn't a lot in it. The SD14 can resolve things much more but the S5 has a better color palette IMHO.
 Tiger1's gear list:Tiger1's gear list
Sony RX1 Canon EOS 5D Mark II Fujifilm FinePix S5 Pro Sigma SD14 Sigma SD1 Merrill +14 more
glacerda
glacerda Contributing Member • Posts: 543
I never used the Fuji; the SD15 focusing is much better than the SD14's, I have both. I go frequently to Shuttleworth shows and only use the SD15 for flying aircraft. Also the SD15 has 11 frames memory, while the SD14 is only 6.
However, I would not buy the SD15 for flying birds, the focusing is simply not suitable. I have however shown here photographs of those shows.
The lens I use is the original 70-200mm (no macro, built 2005) with a 1.4 extender. This setup may be lighter than your lens, that is also a factor. If so, I hope you have Arnold Schwarzenegger type biceps!
G. Lacerda
It is not the equipment, is my lack of skill that matters!
 glacerda's gear list:glacerda's gear list
Sigma DP1 Merrill Sigma SD10 Sigma SD14 Sigma SD15 Sigma 20mm F1.8 EX DG Aspherical RF +8 more
glacerda
Re: Camera for the Month of May: Sigma Camera Talk Forum: Digital Photography Review (dpreview.com)
G. Lacerda
