S5 Pro vs Sigma SD15 for bird photography
Started Apr 4, 2022 | Questions
kylep15 New Member • Posts: 4
Both camera has a unique sensor(Super CCD, Foveon) and I want to try it out.
I tried to search the comparison, but almost nobody mentioned on how it does on wildlife photography.
What I  found is that both camera won't do good on low light.
However, bird photography usually takes place under bright daylight so it won't be a problem.
Which one will do the best on bird photography?
 kylep15's gear list:kylep15's gear list
Fujifilm FinePix S5 Pro Sigma SD15 Pentax K-7
kwa_photo
kwa_photo Veteran Member • Posts: 3,649
Re: S5 Pro vs Sigma SD15 for bird photography
I am moving this thread over to the appropriate forum.  The Fuji X System / DSLR talk.  This is where the discussion should continue with the old Fuji S5 DSLR vs. the Sigma SD15 DSLR from "way back when"....you will likely encounter more users over there who will have input.  The Fuji FinePix forum is for the small sensor Fuji compacts.  Thanks for being a member of DPR's forums!
Ken
FujiFilm FinePix Moderator (Please PM vs. a public post if you have concerns or questions about the forum)
 kwa_photo's gear list:kwa_photo's gear list
Fujifilm X100V Fujifilm X-T3 Panasonic Lumix DC-S5 Fujifilm XF 50-140mm F2.8 Fujifilm XF 16-80mm F4 +3 more
