Re: IS mechanism does not 'lock' when detaching from body
5
these references may be helpful
Canon CORRECTING THE RATTLING SOUND IN AN IS LENS
All that’s needed is to re-mount the lens, turn the camera on, and then tap the shutter button halfway down to start Image Stabilization again. Now, just remove your finger from the shutter button, wait a few seconds for the camera’s meter to turn off automatically (IS simultaneously turns off), and you’ll hear the IS system lock and center the elements with a familiar soft “click” sound within the lens. Now, remove the lens normally and, assuming the lens is otherwise in proper operating condition, you won’t hear the rattle any more!
Avoiding this problem with certain IS lenses is simple: just wait for the IS system to lock and center the elements before you remove a lens from the camera body. Normally, this happens six seconds after you remove your finger from the shutter button (if you haven’t just taken a picture) or two seconds after taking the most recent picture. Turning the camera OFF via its main On-Off switch will also allow the IS system to properly “park” the correction optics.
Lens Rentals Should I turn off IS before demounting a lens?
As a general practice, yes. If you have Image Stabilization activated on a lens, you’ll want to turn it off, wait three seconds, and then unmount the lens. Not doing this can potentially put the IS system in what we call an ‘unparked’ position, which means the optics are still floating, which could cause damage if shaken and jarred
Peter
Nikon Coolpix 990
Olympus C-5050 Zoom
Olympus E-300
Olympus E-330
Olympus E-30
+31 more
