FastStone Ver. 7.6 Just Released
Started 11 months ago | Discussions
John McCormack
John McCormack Veteran Member • Posts: 7,098
https://www.faststone.org/index.htm
I'm not affiliated with the program, but consider making a donation.
History
Version 7.6 (March 31, 2022)
  • Used a new database engine for better performance, capacity, and reliability
  • Added a rating system to classify files from 1 to 5
  • Added "Pre-scan folders into thumbnail database" tool under Settings menu. Now, use this tool to get the thumbnails ready before visiting the folders/drives
  • Added 3 new sorting options: Date Taken, Rating and Tagged
  • When copying or moving files, tags and ratings will be preserved
  • Optimized the program for reduced launch time, faster folder tree creation and network folder access
  • Enhanced the 3 built-in themes: Bright, Gray and Dark
  • File size of selected items shown in status bar
  • In windowed view, merge two status bars into one to maximize viewing area
  • Now you can shuffle images in current folder before thumbnail creation is complete
  • Added an option (Settings > "Dual Monitor" tab) to select the secondary monitor when more than 2 monitors are detected
  • Added "Center" option to Image Strip Builder
  • Added "Preserve Aspect Ratio" option to Image Size in Design and Print tool
  • Added hotkeys for Google Maps (Ctrl+Shift+M) and Google Earth (Ctrl+Alt+M) when current image has GPS coordinates
  • Added "EXIF Lens Model" option to caption in Contact Sheet, text in Slide Show and text in Batch Convert tool
  • Many other small improvements, including vulnerability and bug fixes
olytopeka Forum Member • Posts: 83
Re: FastStone Ver. 7.6 Just Released
Thanks for the tip.  It's a very neat program.
Paul
 olytopeka's gear list:olytopeka's gear list
Olympus XZ-1 Olympus SZ-30MR Olympus Stylus 1 Olympus OM-D E-M5 Olympus M.Zuiko Digital 17mm 1:2.8 Pancake +4 more
(unknown member) Veteran Member • Posts: 3,467
Thanks for the warning,
just updated that wonderful piece of software
"Travel is fatal...for prejudice, bigotry and narrow-mindedness" (Mark Twain) - "The world...is our home" (eMBie)
You can edit and repost my pictures until you drop but they will still be mine Please respect my copyright
Jdogg New Member • Posts: 4
I really like fast Stone. Been using it for years. It's what I use to initially cull my photos. I haven't found anything that is faster or more simple. Pics either get "right arrow" (it's safe, on to the next photo) or "delete".
Chesapeake Imagery
Chesapeake Imagery Contributing Member • Posts: 602
Been using FastStone for the same for years. Donated to the cause. Except I hit the Q key to tag the ones I want to save, then delete the duds by using the "select untagged" function, and delete en mass
 Chesapeake Imagery's gear list:Chesapeake Imagery's gear list
Canon EOS R5
