SrMi
Re: Let's see the original file
rambet wrote:
SrMi wrote:
rambet wrote:
sybersitizen wrote:
Make the original CR2 file available, like you did the last time.
The OP has already stated the issue doesn't appear with the original cr2 raw file.
The solution/workaround is simple if DXO offers the option to output a tif file instead of a potentially problematic DNG file.
As I said in the op's other thread, I never use DNG files unless I have no other option.
In theory, linear DNGs are better than TIFF files in the same way that CR2 files are better than TIFF files. In practice, I have never seen any issues with linear DNGs produced by DxO PhotoLab 5. The possibility to have a linear DNG as output is a significant advantage over other tools like Topaz DeNoise AI (which I also own and use).
OP should contact DxO support. I found them quite helpful.
I don't see linear DNG files as true raw data because they have been partly processed - demosaiced to some extent and who knows what else. I am not convinced they are better than tif files.
https://www.dxo.com/tech-news/linear-dng/#:~:text=Linear%20DNG%20files%20are%20RAW,as%20denoising%20and%20lens%20corrections.
Topaz also offers the option of both tif and DNG outputs. I prefer the tif format for transferring the image to other apps.
I suspect there is an issue with the way DXO linear DNG files are created.
Yes, linear DNGs have been demosaiced. However, like CR2 files, they are still scene-referred, while TIFF files are output-referred. E.g., highlight recovery works much better with linear DNGs that. TIFF files are less malleable than linear DNGs.
You are right. Linear DNGs can be processed, which should be advantageous (e.g., less noise).
Eric Chan from Adobe wrote:
A usual TIFF file that comes out the back end of a raw converter has already been rendered, i.e., it has been mapped to a standard color space, it has been tone mapped, white balancing has been done, etc. More technically, the image is output-referred.
In contrast, the linear DNG is still scene-referred and can still benefit from many of the operations typically performed by a raw converter, such as white balance, the application of a camera color profile, HDR compositing, etc.
You are right, Topaz DeNoise AI can output DNG, but that workflow is not integrated into Lightroom as DxO's workflow. However, Topaz has the advantage that it can process TIFF files as output and can generate TIFF files, which is sometimes a better workflow.
