Can lens damage camera mount when hanging the camera with strap?
Started Mar 30, 2022 | Discussions
AaroS New Member • Posts: 1
I have the EOS 850D and an EF 70-200mm 2.8 IS I.
Is the camera body strong enough to support the weight of the 1.5kg lens when hanging the camera+lens with the default neck strap? It feels kind of flimsy.
Is there a way to mount a strap to the lens itself?
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: Can lens damage camera mount when hanging the camera with strap?
Hello...
IMHO - Yes buy the strap and mount the lens so you don't drop it.
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
Len Philpot
Len Philpot Contributing Member • Posts: 625
I have an 850D and a Canon 70-300 IS zoom. Not as good as your lens, but probably about as heavy. I've used that lens on an 850D and a 350D for more than a decade with zero damage. I don't think there would be any problems unless you're banging the kit around pretty badly. However, I did buy a stretchy / wide / padded Op/Tech strap that made the whole thing feel much lighter. Similar to this: https://www.optechusa.com/pro-strap.html I actually bought a second Op/Tech strap for the shoulder-style camera case I had at the time!
If you want to mount a strap directly to the lens, I can't recall seeing anything that would do that. Maybe a lens collar with some kind of strap loop or something screwed on...? But if it was me, I'd not worry about it.
Len Philpot
Retirement: 4th best thing to happen to me
 Len Philpot's gear list:Len Philpot's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF 70-300mm f/4-5.6 IS USM Topaz Adjust Topaz DeJPEG Topaz Detail +13 more
Aoi Usagi Veteran Member • Posts: 3,221
No it is not strong enough.  With a large and heavy lens like the 70-200mm, the lens is supporting the camera body, instead of the reverse.
Doesn't the lens have a tripod foot?  You should be able to purchase a strap that connects to the tripod threads of the foot.
CameraCarl Veteran Member • Posts: 9,204
A good rule of thumb is that if the manufacturer provides a tripod mount or strap mounting lugs on the lens, you probably ought to hang the combination from the lens. Having said this, I see dozens of press and sports photographers carrying a DSLR or mirrorless body with a 70-400 f2.8 or 100-400 or 100-500 lens with a strap mounted on the lugs on the camera body. I have no idea if they ever run into issues with this, or if they do, if they have to pay for it since many press and sports pros use cameras and lenses from a corporate pool.  As for me, I'm not a pro and don't get free use of my gear, so I carry my combination with a strap attached to the lens mount (or sometimes with one end attached to the camera and the other end to the lens depending on the strap I am using).
Dunlin Senior Member • Posts: 2,611
I have a Canon EOS 600d and a canon 100-300mm zoom.
I recently discovered that when I used the camera with the battery grip, the 100-300mm telephoto didn't drag down so much.
I only use a cheap second-hand Neewer version of the battery grip,
Jethro B.
 Dunlin's gear list:Dunlin's gear list
Canon PowerShot SX410 IS Olympus OM-D E-M10 II Canon EF 35-80mm f/4.0-5.6 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Gimp +6 more
Sue Anne Rush
Hello...
I belong to Flickr Pro.... and smugmug - they each sent me a free neck strap.
Yes find something on eBay or B&H.
Sue Anne Rush
benjilafouine Veteran Member • Posts: 3,875
Never had an issue with the camera strap and 70-200 but I avoid letting the camera and strap hanging loose at the end of the strap. Also, if you want to use a tripod, it must be attached to the lens, not to the camera.
There is always something to shoot/snap, you just have to know how to do it and have the right gear.
Benji
 benjilafouine's gear list:benjilafouine's gear list
Canon PowerShot S5 IS Canon PowerShot SX110 IS Panasonic Lumix DMC-FZ35 Canon PowerShot G16 Canon EOS 40D +12 more
ARCA Racing shooter
ARCA Racing shooter Forum Member • Posts: 80
Here is my set up that I just put together a couple days ago.
I just upgraded to the Canon 70-200 2.8 L III IS from my previous f4 version. This lens is considerably heavier than what I am accustomed to using.
I shoot motorsports every weekend on both Fri & Sat at 2 different tracks and being I am in my mid 60's, I am concerned that carrying that heavy of a lens around my neck for hours would become an issue. A shoulder type strap seemed like a much better idea.
I went with a Black Rapid shoulder strap that is attached to the lens collar that came with my lens. I have thoughts about trying out a monopod (again for the fatigue factor) and wanted a quick release ARCA style mount attached to the foot of the lens collar. This ARCA style mount from Fusion Gear has a really beefy flip out ring to attach the Black Rapid strap, and If I decide to use a monopod, I can undo the strap and slide the plate into the monopod easily. The smaller strap is a safety strap clipped on to the ring, just in case the quick release plate became unscrewed somehow. I have no fear the camera can hit the ground.
I now have the strap on my left shoulder with the camera hanging horizontally on my right hip with the lens pointing behind me. Pretty easy to grab it and shoot. In addition, it also allows me to keep my second camera with a wide angle lens around my neck at the same time if needed.
Alternatively, I you don't care about having a quick release plate, you could just attach a strap directly to the lens collar foot.
 ARCA Racing shooter's gear list:ARCA Racing shooter's gear list
Canon EOS Rebel T6s Canon EOS 80D Canon EF 24-70mm F4L IS USM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM +4 more
