I have to write a praise for this lens.
Started Mar 29, 2022 | User reviews
nonproshooterdad Senior Member • Posts: 1,106
After I got  this lens, I found I use my 7D mark ii more than I expected, even though I have multiple cameras, including Canon, Sony, full frame and crop. It is as sharp as my best L lenses when used on crop camera. When I don't have bokeh objective, this lens is the choice. It has the same contrast of the best Canon lenses. You can see the eyelash clearly, better than my Tamron 28-200 and 70-180 on Sony cameras. Full frame can be better, but with this sharpness and contrast, the crop cameras can be very close.
Canon EF-S 18-135mm F3.5-5.6 IS STM
Telephoto zoom lens • Canon EF-S • 6097B002
Announced: Jun 8, 2012
nonproshooterdad's score
5.0
Average community score
4.8
Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EOS 7D Mark II
tdbmd Senior Member • Posts: 1,547
Re: I have to write a praise for this lens.
I agree, the 18-135 STM and newer NanoUSM are really good all around lenses on crop bodies.  I use mine more than any other EF lens on my 7DII and T8i.
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
BlueRay2 Forum Pro • Posts: 14,816
i played with this lens a few years ago, and it was ok - nothing close to a "L" lens. i really never warmed up to non-L lenses, i always saved until i had the fund and bought the "L" lens i wanted. the only non-L i have is EF 85 f1.8, which i find quite decent. i kept using my "L" lenses on my 40D when i had it with great result. i know your post is about 18-135 but i just wanted to inject another perspective, hope you don't mind
Unexamined world isn't worth living in. "Socrates"
OP nonproshooterdad Senior Member • Posts: 1,106
Copy variance everywhere. It's very rare to get a copy this good. I had several copies of this lens in couple years. They're just ordinary, you adjusted tele end, the wide end can be off. QC is always a problem for non-L lenses. This is the only non-L lens I have. I'll keep it. Macro, range, sharp and contrasty in full range. If I ever need a kit lens, this is the best I've encountered.
Larry Rexley Senior Member • Posts: 1,242
The 18-135 IS STM is a very good lens... I got one with a used 70D off ebay a few years ago. Continued using it with an adapter as I upgraded to the M6 then to my current M6 Mark ii with very good results.
It does well with the 32 MP sensor of the M6ii (same sensor as the 90D) but as you move to higher res sensors the difference between the 18-135 and L lenses and sharp primes gets more obvious.
My copy was slightly decentered with slightly unsharp upper left corner at the wide end at apertures wider than f5 or so.
I upgraded to the EF-M 18-150 IS STM which had a very slight edge in sharpness and micro contrast over the 18-135. The 18-150 is similarly decentered, but in the lower right corner so I always shoot it at f5 or darker.
The 18-135 did zoom much more smoothly which gave better results for 4k video over the slightly jerky zoom of the 18-150.
 Larry Rexley's gear list:Larry Rexley's gear list
Canon EOS M6 II Canon EOS M200 Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Canon EF-M 11-22mm f/4-5.6 IS STM +21 more
J A C S
J A C S Forum Pro • Posts: 20,544
Sure, it is.
