Thoughts on the x-s10 and 16-55mm
Started Mar 25, 2022 | Discussions
Giuloco New Member • Posts: 19
Hello,
I planning to replace my old x-e2, and the x-s10 seems to be a nice update. But I am concerned about basically two issues, the viewfinder and the grip.
I saw some comments on how small the x-s10 viewfinder is. But the specs look quite similar to the x-e2 and I am quite comfortable with its viewfinder. Should I expect a downgrade on the viewfinder size and quality?
Regarding the grip, do you think there is enough room for the fingers when using the 16-55mm. I really love this lens and planning to sacrifice it for a new camera body. Do you have any experience with this combo? Is there enough room left for the fingers?
I appreciate all comments and insights!
Cheers
Fujifilm X-E2
OrigamiCactus Contributing Member • Posts: 667
Re: Thoughts on the x-s10 and 16-55mm
Giuloco wrote:
Hello,
Cheers
If you don't use glasses then the viewfinder is completely fine, and if you use them, then most probably it is still usable.
When you have small-mid sized hands, the 16-55mm will fit wonderfully to the X-S10, when you have larger hands the knuckles may go against the lens, but should still be usable.
 OrigamiCactus's gear list:OrigamiCactus's gear list
Fujifilm X-Pro3 Fujifilm X-T4 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR +1 more
Scotty Contributing Member • Posts: 658
I wear glasses, and wear size XXL gloves, and use the 16-55 on the S-X10.  No issues for me.  Great little camera IMO.  Same sensor and processor as my X-T4 in a smaller package.
Nice to hear that! I also use glasses and can use even the most terrible evf's, so X-S10 is totally fine, but not all glasses are made equal, and I've heard some people complain about the eye relief distance, so I just had to say it.
While i wear my glasses almost against the eyeball, there are people that wear them closer to the tip of the nose, in which case 17.5mm might not be enough eye relief.
I suppose nose relief matters.  I have a very shallow nose, so maybe that explains why I generally don't have issues.  Those with real noses might have a different experience.  😁
Atleast on the X-T4, XPro3 and X-S10 the screen folds inwards, so you can smush your nose right against the camera with no problem, on the X-T3 my nose always activated some weird functions and messed with AF point.
ksoltys Forum Member • Posts: 55
The viewfinder shouldn't be an issue. It's not as big as those on the X-T3 or X-T4 but it's very clear. I am quite nearsighted and can still use it comfortably with my glasses. There is a setting that you can configure to use large icons in the display. I have set up the camera to use the large icons in the viewfinder and the normal ones on the LCD. Generally, I prefer to use the viewfinder outside and the LCD inside.
Regards
Keith
Keith
** Any sufficiently advanced technology is
indistinguishable from magic. - Arthur C. Clarke **
wantfastcars Regular Member • Posts: 206
I personally can't use my glasses with the X-S10's viewfinder, but luckily my vision is "good enough" that I can take them off (or simply go without) when I'm out taking pictures.
I don't have the 16-55, so I can't comment too much on the size there, but I have relatively large hands/fingers and have lots of room to spare with the (admittedly, much, much smaller) 15-45 and 50-230. It's also extremely comfortable in the hand in general.
 wantfastcars's gear list:wantfastcars's gear list
Fujifilm X-S10 Fujifilm 50-230mm II Fujifilm 15-45mm F3.5-5.6 OIS PZ Fujifilm XF 16-80mm F4 Fujifilm XF 70-300 F4-5.6 R LM OIS WR +8 more
miles500
miles500 Senior Member • Posts: 1,215
I have both the xS10 and the 16-55 and find no problem with operating the lens although my hands are not unduly large. However the bigger question for me is that of adding a really heavy lens to a relatively tiny camera and I find the combination rather unbalanced, so I stick to using the 16-55 with the larger and heavier XT3 but keep my 18-55 for use on the xs10.  If I need wider I have a 10-24 which pairs well with the xs10
Miles500
 miles500's gear list:miles500's gear list
Ricoh GR III Fujifilm X-S10 Fujifilm X-T5 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
OP Giuloco New Member • Posts: 19
I appreciate all your comments. Overall, I think I won't have problems with this combo, except for the nose issue! I really like the position of the viewfinder in the x-e2, but I think I will just have to get used to that!
Thanks again for all your answer!
