Raynox 250
Started Mar 24, 2022 | Questions
Columbusrat Regular Member • Posts: 296
Raynox 250
Quick question: I shoot hand-held, with a 55-250 lens, Raynox 150 and built-in flash. I know different equipment and techniques could give better results, but this is what I'm happiest with (the 'communing with nature' bit is more important to me than the final result).
I'm often aiming at tiny bugs of around 2mm long. My hand isn't the steadiest, and AF can be tricky as the 'target' is so tiny (MF occasionally gives better results but is still iffy). If I used a Raynox 250, would focusing be easier as the target is bigger, or would it just amplify my wobbles as well as the bug?
Below (cropped) is what I typically get with a tiny bug (Chlorops) - just about good enough for id purposes, which is pretty much all I can hope for at this size:
 Columbusrat's gear list:Columbusrat's gear list
OM System OM-5 Olympus M.Zuiko Digital ED 60mm F2.8 Macro
gardenersassistant Veteran Member • Posts: 9,656
Re: Raynox 250
I have used that setup (Canon 70D, EF-S 55-250 STM, Raynox 150 and Raynox 250).
2mm is small for that setup with the 150. With the 250 the subject will obviously be larger on the screen and that may help with AF and/or MF. As you suggest though, hand-shake would have a larger impact, although with luck that may affect where the subject is in the frame more than whether you or the camera can place focus right onto it. That is partly a timing issue. How fast can you respond; how fast can the camera respond.
I'm afraid this is not specific enough to be helpful. A couple of additional thoughts though.
When I was using this setup I used the 150 most of the time, as that was most suitable for most of my subjects/compositions, but I switched to the 250 when the subject was smaller in the frame than I wanted. The 250 is more difficult to use because the range of working distance over which it can gain focus is much smaller than with the 150. And of course the subject bobbles around more. I did find it worked ok with the 250 though, probably (I don't have numbers or tbh the recollection) with a higher failure rate.
Talking of failure rates, mine have always been quite high, even with the 150. (I don't have steady hands btw.) I always take lots of shots of a subject if it sticks around long enough. Especially with subjects as small as the size you are considering that was (and still is) the only way I can get a decent shot of them, by getting one (or more if I am lucky) out of 5, 10 or more, especially if it is moving around and/or is on a leaf or grass that is moving in the breeze. Given hand shake, I feel that getting an in focus shot is very much a matter of timing. I found my timing and hence success rate improved with practice - lots of practice.
As to the 55-250 in particular, Canon made three versions of the 55-250 and with the first one I had the 150 autofocused only slowly and unreliably and the 250 not at all. When I got the more recent EF-S STM version of the 55-250 autofocus worked fine with both the 150 and the 250 (that was with live view on the 70D). With my current setups I have been forced to use manual focus (having previously almost always used autofocus), but I have found that I now get at least as high a success rate as with autofocus, even perhaps higher. That is much helped by the fact my current setup does focus peaking. It doesn't always work, but when it does I find it very helpful, including being easier on my eyes than trying to see directly where the focus plane is falling.
OP Columbusrat Regular Member • Posts: 296
Re: Raynox 250
Thank you Nick That's very helpful, even if it is a case of 'might be better, might be worse, depending on the photo gods'! I'm attracted to the Raynox 250 as it's so much cheaper than new lenses or other equipment. And I do like being able to whip off the Raynox if a butterfly or bird suddenly puts in an appearance - changing lenses in the field would go badly, knowing me.
Re: Raynox 250
Sorry, I meant to add - it is the STM lens that I have.
Re: Raynox 250
Yes, that flexibility is definitely advantageous. You can of course also go to the bare 55-250 for larger insects such as dragonflies, and for non-tiny flowers.
You can also use the 150 and 250 together to get more magnification. It isn't a combination I used a great deal, but it does work ok.
Re: Raynox 250
That's good. (I think it is an excellent lens - small, light and sharp.)
JimH123 Veteran Member • Posts: 3,885
Re: Raynox 250
The greater the magnification, the more difficult it is to hold the camera steady.
It is much easier if the camera/lens can be mounted on a tripod, and a focus rail can really make a difference.
Opting for an old, legacy, manual focus macro lens can produce incredible results. Macro shots don't need autofocus and instead are best used by moving the camera back and forth to get best focus.
Here is an example where I used an old Vivitar 90mm f2.8 macro lens with the camera/lens mounted on a focus rail. This leaf is small enough to fit on top of a nickel with nickel still showing. I set the lens to 1:1 and move the camera/lens on the focus rail to obtain focus.
I throw this out as just an example.  I see you have a Canon, and I don't know if this lens can be obtained with a Canon mount or not.  But I know that there are many manual macro lenses that fit a Canon.  I also have it's little brother, the 55mm f2.8 macro.  Both are made by Komine.   Both are incredible lenses for something that is likely 50 or more years old.
The Ultimate Vivitar 90mm F/2.8 Macro Review! – Photography Paws
 JimH123's gear list:JimH123's gear list
Nikon Coolpix P1000 Sony RX100 VII Olympus E-M5 II Sony a6300 Olympus E-M1 II +2 more
Re: Raynox 250
Thank you, Jim. I know a tripod and focus rail could improve my photos a lot, but they wouldn't work for the way I do my photography - think kitten and butterflies! I could, of course, set up a shot in one position, put some sugar water on a likely-looking flower, then sit and wait... and wait... but I'm much happier just wandering round seeing what I might find, and then hoping I can get a few shots off before it flits off again. It's pretty much the equivalent of meditation for me.
I've ordered the Raynox 250. It'll be interesting to see how I get on with it. Reviews tend to be quite polarised, but at least with experience of the 150 I have an idea of what to expect.
macrouser
macrouser Senior Member • Posts: 3,979
Re: Raynox 250
When I have a craving for small insects to photograph, I have a Sigma 150 mm macro lens and teleconverters.
I have a very strong tripod that can help me a lot to hold still.
With the 2x converter I can get a 1:1 photo at near .5 meters.  I can use manual focus assist to look at things very closely that I would never find with my eyes alone.  It gives me a great working distance.  I can add some extension tubs to it and get even more magnification.  It will let me focus from near 3 meters to less than 300 mm.  It does reduce the light reaching the sensor by up to three stops.
Another advantage to using this set up is that the field of view doesn't change as much with small changes in distance.
 macrouser's gear list:macrouser's gear list
Sony SLT-A77 Sony a7R III Sigma 150mm F2.8 EX DG Macro HSM Sony FE 90mm F2.8 macro Sony FE 70-300mm F4.5-5.6 G OSS +2 more
Re: Raynox 250
I should, probably, try to experiment with something resembling a light tripod that I could rest my arm or hand on (rather than fix the camera to it). It's a question of whether I can come up with something workable that doesn't get in the way of the 'communing with nature' bit.
I do at one point want to go to a local(ish) camera shop where I can actually look down the lenses of different lens/extension tube/teleconverter combinations. Unfortunately I'm stuck at home with an extremely needy dog with the beginnings of dementia, so that will have to wait until either his brain or his back legs give out completely - it's a toss-up which will happen first...
Re: Raynox 250
Another option is software to correct camera motion and for resizing. Attached is an example of a Hibiscus flower starting to open. The ants had placed their aphid herd on this one.
Original hand held closeup
Using Topaz Sharpen AI - Motion Blurry Mode to correct hand shake. Some cropping was done.
Using Topaz Gigapixel AI to resize a tighter crop by 4x
Re: Raynox 250
You're right, Jim, I really should try a sharpening tool - I'd always imagined that my less good photos didn't have enough 'raw information' (pun intended;-) ) to be salvageable, but I could be wrong. My son's pretty good with photo editing software - I'll have to send him a selection and see what results he can get. And then aim to master them myself when I have more time and headspace.
Re: Raynox 250
I've been pleasantly surprised with my first results with the Raynox - it's damp and grey out, but I found a cooperative spitting spider in the conservatory...
How I get on in the garden, with more mobile subjects and possibly a slight breeze, is another matter, of course. Spitting spiders effectively glue their prey to the ground/windowsill before tucking in, so don't tend to move much - I thought it must be dead at first.
Gary from Seattle Veteran Member • Posts: 7,852
Re: Raynox 250
I find the 250 quite good, albeit with a very shallow DOF and very little range of focus distance; this with the OLY Macro.
I think on your OP shot there are any number of things that could have affected the "sharpness" of the image.
DOF is one but you used F32. That might be a bit into diffraction.
A SS of 1/200 may not have been enough (overall SS not just narrow zone of sharpness) given your hand motion, the bug's or leaf motion, and the magnification of the image. I might think using 1/1000 or greater would be helpful unless on a fixed substrate.
I shoot Focus Stacked on tripod mosses, but also shoot a lot of handheld bees where really I think 1/1000 is very minimal.
 Gary from Seattle's gear list:Gary from Seattle's gear list
Olympus E-M1 Olympus E-M1 II Olympus OM-D E-M1X Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 +7 more
Re: Raynox 250
Thanks Gary. I'm limited to 200 by the flash though, and I really want to use the pop-up. I do realise that I'm pretty much asking the impossible though, and can't expect great results - they just have to be good enough for me. And I'm setting the bar pretty low!
Re: Raynox 250
If flash is providing most of the illumination then the effective shutter speed is the length of the flash pulse. This is likely to be quite short. The length of the flash pulse gets shorter as the flash power is reduced. I run my flash at 1/4 power and have no problem with motion of my hands, the subject or the substrate it is on at up to 8X magnification hand-held.
As to image quality using the camera's pop up flash, have a look at Mark Berkery's images. (Mark posts here as macromeds.) For a long time Mark used the camera flash and he produced wonderful images that way. Search for "Velcro" on this page to see the way Mark diffused the camera flash with a small, home-made snoot.
