Disappearing Histogram?
Started Mar 23, 2022 | Questions
Lucky Sky Senior Member • Posts: 1,806
Set up my M50 II to display the histogram in the viewfinder per the owner's manual. Worked fine last shooting session; turned on the cam today and no histogram in sight.
Followed the manual (again) in numerous attempts to return the histogram to the viewfinder and all failed.
Am hoping that I don't have to reset the camera.
Has anyone else seen this? Any ideas?
Thanks.........
Lucky Sky
Your photographs are your moments in time
https://www.flickr.com/photos/luckysky99
 Lucky Sky's gear list:Lucky Sky's gear list
Nikon D810 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm F4G ED VR Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron 15-30mm F2.8
Canon EOS M50 (EOS Kiss M)
Dareshooter Veteran Member • Posts: 5,842
Re: Disappearing Histogram?
Try toggling the info button .
OP Lucky Sky Senior Member • Posts: 1,806
Tried that (again). No help
Lucky Sky
Mystery solved. The histogram is only enabled if “Shooting Simulation”, found in the menu Shooting tab, sub section 6 is enabled. I had read some info in a post where the writer had a good reason to turn it off. So I tried it.
But that takes out the histogram.
All is well again in my camera world. Just don’t ask me about the rest of the world.
Lucky Sky
