Artifacts while shooting against the light of the sun
Started Mar 23, 2022 | Discussions
Skeeterbytes Forum Pro • Posts: 23,182
Re: Artifacts while shooting against the light of the sun
whumber wrote:
TomzeLhotky wrote:
Hello dear. I'm new to the Olympus system. Own E-M1 mk III + 100-400 lens. In the photos I take at sunset and I have this light in the shot, I see a "grid of rectangles", or whatever I call it. Best if I could send you a photo. My question is whether this is normal behavior or something is wrong. Thank you, Tomas.
I enclose a 1: 1 cut-out
You're seeing the PDAF pixels.
My first thought as well but isn't that rather too many squares for the 121-point version of the PDAF sensor, or is the pattern applied to the entire surface and not just the PD sensors themselves?
¯\_(ツ)_/¯
Rick
whumber
whumber Veteran Member • Posts: 4,371
¯\_(ツ)_/¯
Rick
121 selectable AF points doesn't mean there are only 121 PD points on the sensor. The selectable PD points are a firmware construct that aggregate data from a large number of individual PDAF pixels.
 whumber's gear list:whumber's gear list
Fujifilm X-T1 Olympus OM-D E-M1X Olympus E-M1 III OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +10 more
olrett Contributing Member • Posts: 683
Interceptor121 wrote:
Pedagydusz wrote:
I have been taking pictures since the awn of Digital Photography, used Canon, Sony Olympus and Panasonic cameras, even a Sony camcorder and a variety of cell phones, and shoot regularly against the light (setting sun). I have never seen an image like that! Not even similar.
I have instead and not a coincidence a Sigma lens
That would explain why I sometimes get those artifacts on the Sigma 56mm (on the G9, no PDAF there).
 olrett's gear list:olrett's gear list
Panasonic Lumix DMC-LX3 Olympus TG-6 Panasonic Lumix DMC-GH1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GM5 +24 more
Adrian Harris
Adrian Harris Veteran Member • Posts: 7,708
Re: A blog from Jim Kasson
ahaslett wrote:
https://blog.kasson.com/a7riv/pdaf-striping-in-the-sony-a7riv/
Horshack has also done work on this as well. Jim and Horshack might respond if you post on the PST forum.
Andrew
That is an excellent test report. Thanks for the link.
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 Adrian Harris's gear list:Adrian Harris's gear list
Sony RX100 Panasonic Lumix DMC-G1 Sony SLT-A77 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8 +1 more
Interceptor121 Veteran Member • Posts: 8,691
That would explain why I sometimes get those artifacts on the Sigma 56mm (on the G9).
The G9 does not have PDAF pixels so I have never had issues. I use the 56mm mostly for long focal landscape with plenty of backlighting and I have not seen a problem yet with that combo.
It is of course still possible to get a full sensor reflection though
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
jalywol
jalywol Forum Pro • Posts: 12,301
Steps to narrow it down:
This looks exactly like the sensor banding that affected the Nikon D200 back in the day.
Here's the thing, though: It should NOT be happening on the Oly you have.
My guess is that something in the sensor image either capture or readout pathway is not behaving properly.
Here's what I would do to narrow it down:
  1. Do a complete factory reset of the camera
  2. Use brand new, name brand, formatted in camera, SD card(s)
  3. Repeat test using second card slot
  4. Use a fully charged Olympus battery (repeat with a second battery if you can)
  5. Use two different lenses and repeat test
  6. Try both E-shutter and mechanical shutter on the test shots
  7. Take both RAW+JPG shots
  8. Use the Olympus image processing software to download and process your images
If, after all of this, you STILL get banding under the high contrast situations, then I think you may have either a sensor or sensor-related hardware defect, and you will need to send it in for service.
-J
¯\_(ツ)_/¯
Rick
In order to detect a phase difference you need at least two pixels even if it is called single point in reality it is likely to have 4 to cover horizontal vertical as minimum
In addition it is possible that the PDAF mask is an entirely separate circuit which then generates a grid.
Time ago Bill Claff posted the EM1MKII results where you could see the fixed pattern and it was not 121 dots
Re: Steps to narrow it down:
There was bizarre high-ISO banding with the E-M5 (Sony sensor, not PDAF) and the 20/1.7. No other lens. Oly never figured out a fix even after acknowledging the issue. Looks different from this, of course.
whumber
¯\_(ツ)_/¯
Rick
You're probably thinking of this thread. For the OP, here's another user that ran into the same issue. It's the same thing people made a stir about back when either the A7Rii or A7iii were released, it just looks different because of the crosstype pattern Olympus uses. I haven't been able to induce anything similar with the OM-1 which is expected since it no longer needs to use PD masks.
ahaslett
ahaslett Forum Pro • Posts: 12,654
Andrew
Jim is an outstanding contributor.
Andrew
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
ahaslett
It’s not banding
If you look at the jpeg I made from the RAW that OP supplied, you can see hundreds of clearly defined squares in a square grid across the whole image.
Andrew
drj3 Forum Pro • Posts: 12,632
Sometimes that happens shooting into the sun when you get the internal reflections as in the image first image below (one of my EM1s - I don't remember which one).  Of course, sometimes you don't get it even with the sun in the image (this happens when you follow a BIF who flies by the sun in S mode - second image)
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
whumber wrote:
Skeeterbytes wrote:
You're seeing the PDAF pixels.E
¯\_(ツ)_/¯
Rick
Yes exactly that. The OM-1 sensor is back illuminated so the circuitry is not on the side exposed to the lens and in addition the cells are all the same. Yet I am not sure if the allocation to a cell to behave as PD or imaging change when the sensor is readout
Either way with a lens with AR coating on the back you are extremely unlikely to see anything
phtograf Regular Member • Posts: 156
I had the same exact issue with every lens I put on the E-M1 mk III that I owned for 1 day. I don't get it. But it was so disappointing. I had the issue with 12-40 2.8 and the 14-150 and the 75-300. I have never had this issue with the Pen-F (which I currently own) or any other Olympus camera I have owned in the past. I have no solution. Just letting you know I had the problem.
