Canon M50ii + 28mm macro EF-M lens with Helicon Remote issues
Started Mar 22, 2022 | Discussions
mcaf123 New Member • Posts: 2
Hi all - new to the forum!
I recently bought a used (like new) Canon M50ii, 15-45mm kit lens and also the 28mm EF-M macro lens. I mainly shoot model cars and previously had a Nikon D3300 with the kit lens and used some extension tubes to get the macro effect on a budget with plenty of focus stacking in Photoshop.
I discovered Helicon Remote and Helicon Focus, which I thought would be amazing to help speed up my workflow. However, I've been having major issues getting the macro lens to focus front to back using Helicon Remote. Basically, I am able to focus on pretty much any point in the frame and take an individual photo with Remote. However, if I set the nearest focus point (point A) and then try and select the farthest focus point (point B), the lens simply won't step through beyond point A. Every time I hit the little arrows to change the focus point, I can hear a faint whirring sound from the lens.
I reached out to the developer of Helicon and was told the lens and camera are supported and he thinks the most likely explanation is that some kind of continuous/aggressive AF mode is active and when I try to adjust the focus position, autofocus kicks in and overrides the desired choice.
Has anyone got any experience with Helicon Remote that has faced this same issue? Perhaps there's an issue with the lens, or perhaps I'm just being stupid and missing some key settings??
TIA!
 mcaf123's gear list:mcaf123's gear list
Canon EOS M50 II Canon EF-M 15-45mm F3.5-6.3 IS STM Canon EF-M 28mm F3.5 Macro IS STM
Canon EF-M 28mm F3.5 Macro IS STM Canon EOS M50 II
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: Canon M50ii + 28mm macro EF-M lens with Helicon Remote issues
Hello...
TIA!
IDK - I don't use that but I am sure it's fine with your Canon M50ii.
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
OP mcaf123 New Member • Posts: 2
Sadly it doesn't seem to be working fine for me, which is why I've come here in the hope someone is using the same lens with Helicon Remote and can guide me
KEG
KEG Veteran Member • Posts: 4,909
Turn off continuous autofocus, see if that solves the issue
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
