In-camera focus bracketing: usable past 1x magnification?
Started Mar 21, 2022 | Questions
16GreenBeans
16GreenBeans Forum Member • Posts: 73
Hey all,
As someone interested in trying out macro photography around the 2x-5x level, from what I understand, focus bracketing seems pretty vital to ensuring a sharp, detailed photo.
As focus bracketing manually using a rail seems rather time consuming, I was wondering, would using an in-camera method of automatic bracketing be precise enough at such a high level of magnification? Say the kind found in newer fujifilm and olympus mirrorless bodies?
My thinking is that powerful focus stacking software like helicon or zerene, or even a focus stacking feature in a photo editing program like affinity photo, would be able to compensate for any major issues with sharpness and accuracy. For those with experience, does this hold true?
Also, this might be a stupid question, but has anyone had experience reverse mounting an enlarging lens onto the olympus 60mm macro? I found a good deal on a Schnieder componon 28mm f4 and am wondering if it possible to mount it while using the 60mm lens normally, as this would allow me to use the in-camera bracketing and stacking features.
Cheers!
GB.
 16GreenBeans's gear list:16GreenBeans's gear list
Sigma sd Quattro Sigma 70mm F2.8 DG Macro Art
AeroPhotographer Regular Member • Posts: 462
Re: In-camera focus bracketing: usable past 1x magnification?
Regarding reverse mounting a lens on another lens.  The lens on the camera needn't be macro.  Any lens will work.  The lens on the camera can be focused on infinity and so can the reverse lens.  Note I say "can be" as that's not essential.
If both lenses are focused on infinity, then the reverse lens can be any ordinary photography lens.  It's not essential that it be an enlarging lens which is designed for close conjugates.
Alan
jarlrmai Regular Member • Posts: 110
In camera focus bracketing requires that lens is able to be driven by its autofocus motor, this generally excludes most high magnification lenses that are manual focus only, you can use a 1x lens with extension tubes to increase the magnification as long as the AF motor can still be driven.
Sheeno Forum Member • Posts: 94
I can't speak for the reversed enlarging lens, but there are other ways to increase magnification whilst retaining autofocus and thus focus bracketing, such as extension tubes, teleconverters and dioptres (such as those made by Raynox). oneofone25 is a member over on the M43 forums who has a lot of success with these in conjunction with the Olympus 60mm macro that you mention. Here's one of their threads, but it's worth looking through other posts for more information.
Essentially, you can increase magnification by 1.4x or 2x depending on which Olympus teleconverter you use, but as the teleconverters are not built to work with the macro lens you need to connect them via an extension tube, with Kenko and Pixco being brands that people have success with. The diopter then goes in front of the lens, and there are a variety of options; the Raynox DCR-250 is the most versatile, which I've used in the field to create focus stacks of insects handheld with the Oly 60mm, whereas the Raynox MSN-202 and MSN-505 are much harder to use, necessitate a tripod and stacks with a very large amount of images, but provide much more magnification (with the 505 providing the most).
gardenersassistant Veteran Member • Posts: 9,656
16GreenBeans wrote:
Hey all,
Yes. See the work of OneOfOne25, who uses in-camera bracketing with an Olympus camera and an Olympus 60mm macro lens with and without a teleconverter and/or Raynox close-up lenses, sometimes at very high magnifications, producing superb, super-detailed images.
That said, if you are intending to photograph animals, especially live animals, particularly live animals out in the field, most particularly ones that are rather small and ones that may be wandering around/on foliage that is moving in the breeze/engaging in active behaviours/not in one place or pose for very long, then using focus stacking will considerably restrict the range of scenes you can tackle.
FWIW (and obviously your mileage may vary), I prefer the flexibility that single-capture imaging gives me for active subjects out in the field at magnifications of up to 8X. I can't get the details or depth of field that focus stacking would enable, but there are compensations, such as being able to photograph subjects as they move around and/or engage in behaviours such as grooming, blowing bubbles, wrapping prey or giving birth. In terms of sharpness and accuracy I make do with images like the ones below. But obviously, this may not be the sort of thing you are interested in, or if it is the sort of thing you are interested the image quality may not be up to your standards. We each have to find our own way.
A globular springtail, head and body probably around 2mm long
One of a 26-image series captured as the snail was moving around, varying from shots like this through "full body" shots out to "environmental" shots.
This ant was rushing around. It had, possibly, stopped momentarily (I don't recall).
Aphid giving birth.
From an action sequence. A wasp trying to tear flesh from a pheasant carcass. (They had to work really hard at it.)
This mite's body was probably around 1mm long. It was moving around.
This woodlouse was in motion.
This fly wasn't moving. Perhaps it stayed still long enough to be stacked. I don't recall. But this sort of thing is good enough for my purposes.
I have nothing against focus stacking btw. I use it quite a lot for close-ups of flowers etc (hand-held, using in-camera focus-racked video and stacking in Helicon). Just not for invertebrates.
MacM545 Contributing Member • Posts: 780
16GreenBeans wrote:
Hey all,
Cheers!
GB.
It is possible to do such stacking by use of an automatic rail, which can be many times as expensive as a manual rail. You might also want to consider the fact that at such a high magnification, camera shake can be a real problem, especially with a high-resolution camera. So, it is important to use a sturdy setup. Macro Magnification can be problematic also because the range of focus is likely to be in the Millimeters; but it is possible to use autofocus with a single reverse-lens system by Novoflex. It's the reverse lens Autofocus Adapter. Stepping down the aperture is a technique that can help (but is essential) and might require a bright light source. One person who has used an Olympus 60mm macro for extreme macro can be found at Instagram (1of1 snowflakes) and Flickr (Ethan Beckler).  I don't instantly remember how he did it, but the equipment was listed somewhere in one of his posts.
 MacM545's gear list:MacM545's gear list
Sony RX100 II Canon EOS 500D Fujifilm X-T2 Canon EF-S 18-55mm f/3.5-5.6 Fujifilm 50-230mm II +1 more
philzucker
philzucker Forum Pro • Posts: 10,390
In camera focus bracketing in my experience really isn't less sharp or accurate compared to doing it with an automated macro rail - I'm doing both with different cameras and purposes.
On stacking rails the whole setup - camera, lens, extensions etc. - has to be moved, so you have to be very careful to let everything settle down to avoid unsharpness caused by residual vibrations/movements. Automated rails allow you to dial in appropriate waiting times for this.
Compared to that in camera focus bracketing only needs to move the focus elements of one lens, and if you use an internally focusing lens seen from the outside nothing seems to move at all. Of course something moves - the internal lens elements do -, but since there is much less mass to move this causes less vibrations/movements and allows for very fast picture taking. It also allows for very simply setups, BTW - you don't have all the cables hanging around typical of an automated rail, and you don't have to worry for a moving rail or a extending front element to touch anything on their stacking journey ruining the shot.
The problem of course is the lenses. With stacking rails you can use and try anything that comes your way, with focus bracketing you're limited to the lenses that support it. To go past 1:1 you have to use extension tubes (those with contacts allowing AF to work) and/or teleconverters (also able to transmit those signals) and/or close-up lenses. The technique OneOfOne25/Ethan (as already referenced by the others who answered in this thread) has developed allows for magnifications up to 9x by a combination of those things with excellent results using Olympus cameras. I recently adopted this technique and have gotten very good results up to 7x myself. See my recent threads in this forum for some examples, if you like, e.g. https://www.dpreview.com/forums/thread/4636642 or https://www.dpreview.com/forums/thread/4636307.
I'd recommend to start with a bare 1:1 macro lens for getting experience with focus bracketing - 1:1 is nothing to scoff at especially at smaller sensor sizes like APS-C or m43, and it's absolutely doable hand held - see e.g. here https://www.dpreview.com/forums/thread/4635340.
For the next step I'd add extension tubes first because they are really cheap, some close-up lenses later - the Raynox 150 and 250 ones are really affordable and offer very good quality. With a combination of both and some extension tubes I managed to get excellent sharpness up to 3:1 - see here: https://www.dpreview.com/forums/thread/4634760
That should be possible, but in my experience enlarging lenses give best results used on their own in combination with a bellows or extension tubes. You can try reverse mounting them on a macro lens, but asides from possible sharpness issues you may or may not encounter, on the 60mm you would "only" get an magnification of approx. 2:1, something a smaller and cheaper Raynox 250 in combination with the same lens would also reach.
Phil
DonBMichigan Junior Member • Posts: 38
I'll add, for focus bracketing: I've used the 60mm Olympus on E-M1.ii with (or without) extension tubes and Raynox 150 using (1) Olympus Capture in MF with focus adjustment through Capture (see this thread ); (2) using a rail with the shutter on a timer (wait 5 seconds between shots, adjust rail right after shutter with 4 seconds to let tripod shake stop); (3) trip shutter with Olympus Capture after adjusting rail position and letting tripod settle.
All of the above would be with the camera in MF. Capture works with certain models of Olympus cameras, I'm not clear what camera you're using. Option 2 should work for any camera with a timer.
I bought a thread adapter for the Raynox so I could screw it directly to the end of the 60mm, which makes the combo a little easier to handle. If you get extension tubes, make sure they can autofocus to make hand-held work easier.
Don
 DonBMichigan's gear list:DonBMichigan's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Tamron 14-150mm F/3.5-5.8 Di III Olympus 12-100mm F4.0 +2 more
16GreenBeans
OP 16GreenBeans Forum Member • Posts: 73
Alan
Hey Alan,
That's a solid bit of advice. My only major concern would be the presence of field curvature when not using a macro.
Good to know I don't have to use an enlarging lens.
Best,
GB.
16GreenBeans
Hi Sheeno,
Holy smokes, those are some incredible photos by oneofone25.
I think this might have solved things for me. Teleconverters, tubes, and diopters definitely seem like the way to go.
Thanks!
GB.
16GreenBeans
gardenersassistant wrote:
16GreenBeans wrote:
Hey all,
Aphid giving birth.
Hey Garden,
I think for the most part I'll be sticking to static, non-living things when it comes to macro. That said, fantastic shots you have there.
Thanks for the advice.
GB.
16GreenBeans wrote:
Hey all,
Aphid giving birth.
Hey Garden,
Then focus stacking is the right way to go I think.
Thanks.
GB.
oneofone25
oneofone25 Senior Member • Posts: 1,586
16GreenBeans wrote:
Hey all,
Cheers!
GB.
You need to check out my posts in the Olympus forums...
I use the Raynox macro filters on the Olympus 60mm macro lens, as well as coming up with a way to use the 2x teleconverter, the MC-20, with the macro lens.  Using the MC-20 teleconverter with a kenko 16mm extension tube, connecting to the Olympus 60mm macro lens gives me about 2.3x magnification when lens is set to 1:1, and focus bracketing works splendidly at f4.5 and anywhere from 1/10 to 3/10 for focus bracketing mode.
here are some shots I have taken over the last 6 months using this setup, in combination with one of three different Raynox macro filters - the Raynox 250, the 202 or the 505.  Using the 505 with this setup, i get 9x magnification and regularly stack images of sand grains that are 0.2mm to 0.3mm wide.
the right eye of a stink bug
under 1mm field of view, focus stack of more than 175 images if memory serves me right, using the 202
two grains of sand, the top one being a garnet at 0.2mm in width - used the 505, about 200 images stacked
dew drops hanging in a spider web, using the Raynox 250 (all of these I am using the 2x teleconverter for as well), focus stack of 75 images
scales on a mosquito shoulder, used the 505 for 9x magnification and stacking high resolution images by hooking up the camera to my computer and manually moving the focus
 oneofone25's gear list:oneofone25's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Samyang 16mm F2 +1 more
oneofone25
Hi Sheeno,
Thanks!
GB.
they work well, glad to see many people in this thread referenced my stuff; feel free to send a message and ask me anything
oneofone25
16GreenBeans wrote:
Hey all,
Aphid giving birth.
Hey Garden,
GB.
always blown away by Gardenerassistant's shots....and probably have been most inspired and also most taught by their work
3D Gunner Senior Member • Posts: 1,025
Amazing shots! 👏 👍
Gosh! Given the quality of what you produce I ...... well, I don't know what to say to be honest. Just, Thank you so much will have to do.
3D Gunner wrote:
Amazing shots! 👏 👍
Thank you.
