Attempt to DIY a beamsplitter stuck at double image
Started Mar 21, 2022 | Discussions
Oleg L K Regular Member • Posts: 293
A question for those who specialize in optics.
I'm trying to build a 3D beamsplitter, and the worst problem is image duplication/ghosting that usually occurs on one side.
The geometry is classical - like SKF1, but mirrors aren't horizontally parallel - angle between internal mirrors is larger than that between external ones.
I'm using thin mirrors (~1.1mm). I don't see surface defects on the mirrors themselves. It's not wind/movement/etc.
Constructive ideas are appreciated.
Oleg.
Brian F Flint
Brian F Flint Regular Member • Posts: 184
Re: Attempt to DIY a beamsplitter stuck at double image
I think you need first surface mirrors
 Brian F Flint's gear list:Brian F Flint's gear list
Panasonic Lumix DMC-ZS60 Sony RX10 III Canon MP-E 65mm f/2.5 1-5x Macro
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
Yes, first surface mirrors throughout are a must.
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
Brian F Flint
I have a small rig which has two 'first surface mirrors ' positioned in a similar way to the rig mentioned above. I put it in front of the lens of my camera and half of the image was via the two mirrors and the other half was direct ( ie no mirrors in the path of the image) . I took a photo and cropped out the parts of the image I wanted and aligned it in Stereo Photo Maker and produced this cross-view image. Notice there is no double parts on the edges. The mirrors were made by Edmund Optics.
OP Oleg L K Regular Member • Posts: 293
I am trying to acquire 1st surface mirrors.
But I still doubt they solve all the problems, Why do I usually observe image duplication only on one side? I made several units, and one problematic side is the most frequent outcome.
3D Gunner Senior Member • Posts: 1,031
The formula with 4 mirrors is without problems.
Is better to by one. KÚLA DEEPER - 3D LENS FOR DSLR
