Photographer's mask?
Started Mar 20, 2022 | Discussions
PHXAZCRAIG
PHXAZCRAIG Forum Pro • Posts: 19,651
I've been using the same mask since 2009 when I got back into scuba.   It's the only mask I've ever owned with prescription lenses.  Actually just a selection of different diopters you plug into the mask frame, but they've worked very well my entire diving career.
A bit long explanation, but I suspect I'm not alone in finally realizing this.
But I had a revelation on my last trip when I started shooting video.   It was that my mask limits my viewing angle so much that I completely don't have a feel for the seascapes I've been diving in.
I've shot two lenses with my underwater DSLR rig since 2015.   A 105mm macro, or a 16-35 wide angle behind a 230mm dome.
So here's the thing.  I'm looking through a flat port which magnifies things 20% over reality, with a very limited field of view.  I'm guess the equivalent of a 60mm lens above water, but also cropped.
At the same time I'm shooting 16 behind a big dome port that gives no magnification.
The first thing that struck me over the years of using it was this dichotomy between what I see and what the camera sees.   I look at something and it is big.  I look at it through the viewfinder and it is small - takes a while to get the brain to look through the flat-port mask and visualize what it will look like with the dome port.
But this last trip I started shooting video, and unlike stills, I can't get enough width.   Shooting stills I was sort of trying to shoot what I saw with wide angle.   That often meant trying to get closer and zooming in as far as I could to isolate the subject more.
Which I think is an outcome of looking through my (flat-port) mask and seeing the surroundings that way, and trying to image it.
My revelation came when looking at this 16mm videos and realizing I've not been seeing the shape of the seascape at all, because my mask viewpoint was so restrictive.  I've got the idea now to start diving and constantly scan around to try to build up a wide angle image in my mind.   But I'm wondering if I can't get a lot farther down that path with a different mask.
So - what masks are best for photographers trying to get as wide a field of view as possible?  Doesn't have to be in focus.
And it seems we no longer get masks with replaceable diopter glass, but instead get some sort of prescription lens glued onto the mask.   I'd like any recommendations or voices of experience here.   My eyes haven't changed my since 2009, but those diopters only came in 1/2 diopter increments, and one of my eyes needed a 1/4 diopter prescription, so I've always been close, but not perfect focus.
Phoenix Arizona Craig
www.cjcphoto.net
"I miss the days when I was nostalgic."
Nikon D80 Nikon D200 Nikon D300 Nikon D700 Nikon 1 V1 +45 more
Architeuthis Regular Member • Posts: 491
Re: Photographer's mask?
Hi Craig,
First, the human eye does not have different angles of view, but only a single type of facial field exist, perceived similar to standard focal length on a camera. Therefore it is just natural that the perspective of a telelens or of a WA lens is different from yours, there is no zoom or interchangeable lens in the human eye...
The same issue exists on the surface, you need to perceive your motif via the viewfinder, then everything is natural and o.k. ...
(Divers often use transparent silicone masks to (seemingly and subjectively) increase the restricted angle of view, but I personally prefer black silicone, that makes looking through the 45° viewfinder easier)
Regarding the optical mask, I would go only for the good but expensive glue-in lenses, when I needed correction of astigmatism or multifocal (I need both, since I am old, hence I have glue in lenses - expensive but perfect solution). 1/4 of a dioptrie is not enough to justify this expensive solution. 1/2 increments are more than enough, in case you just need this type of correction...
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
kelpdiver Veteran Member • Posts: 5,564
I believe there are still a few masks out there offering the drop in replacements.
Now by design, these two pane masks do limit the view perspective compared to a single pane.   Possible exception being the two pane ones that are not aligned (bug eyed).   There are also the more exotic masks that attempt to correct for the magnification and require the user to either be near sighted or wear contacts to become so.
But is any of this progress?   In getting a wider angle, you compromise your ability to look at narrower angles.  Doesn't sound good for macro either.   But in terms of WA composition,  you still need a foreground subject, and short of a disqualifying element, it doesn't matter so much how the edges go.   The subject is still the focus.
Craig, you might consider instead attaching a 5" monitor via HDMI to the top of the rig.  It is yet more bulk, but it would be useful both for seeing the camera perspective and also for macro focusing.    It's for the latter that I'm considering it.
PHXAZCRAIG
OP PHXAZCRAIG Forum Pro • Posts: 19,651
I didn't really think about this seriously - partly because I think it's mostly useful for video, and I'm not that into video - but I may have the opportunity to try it and see.  I'm going to the Digital Shootout, and it does look like there are vendors that provide demo equipment.
For a mask, I don't want less magnification, just a wider view on the sides.  Doesn't even have to be in focus.  I'll still get a better impression for the surroundings than I do now.;
I have until June to deal with this.  Need to get moving!
www.cjcphoto.net
Barmaglot_07 Contributing Member • Posts: 633
It'd work for video, yes, but wouldn't that significantly degrade focusing performance in stills mode? Craig is shooting a DSLR, and using a monitor is functionally equivalent to live view, which takes the dedicated AF array out of optical path.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
true, he is on a true DSLR, not the mirrorless FF of the R5 or the Sonys.
For macro, that may still be an acceptable price to pay.  And AF for WA is generally a non issue.   It will, otoh, represent another leap in drag and weight.  His poor DM already has a hernia.
PHXAZCRAIG
Well, I'd probably only mount it when doing video and wide angle.
My last dive was the only time I've ever actually tried doing video on my DSLR seriously.   Before I did a short clip or two just to try it out.   Last time I worked at it until I got ... the best I could, I guess.
I found something interesting, and that was that I preferred to shoot video when using wide angle.  Maybe that is because it was new, maybe because I don't really know how to shoot wide stills effectively.   So it would not be a big deal to me to only mount a monitor also with the big dome port and so on.   I'm not sure how much it would actually help though.  Maybe I'll get the chance to try one at the Digital Shootout in June.
I've been unable to effectively do macro video.   For that I think I need to stabilize the camera better on some form of tripod.   So I'll likely continue shooting macro with my eye pressed up to my 180 degree viewfinder.
www.cjcphoto.net
PHXAZCRAIG
making progress
Working with prescriptiondivemasks.com now, and they've sent me several masks to try out.   I'm going to go with the XS Scuba Fusion, which is a mask with 'side windows'.   Definitely wider field of view than my old mask.
I had my eyes checked last week and was surprised to find that my eyes had improved a full diopter.  (-6.5 to -5.5).   Maybe now I'll be able to see those wire shrimp!
I've been using my old mask exclusively since 2006.  I think I got my money's worth on that one.
Now I have to decide where the bifocal part positions, etc.
www.cjcphoto.net
Konrad Hoelzl Regular Member • Posts: 192
one advice for the photographers who need reading glasses...
At my last dives (2019 before corona) the resort owner of my favourite diving place lent me his "underwater glasses". They were a DYI solution made of some very cheap reading glasses with a thick frame with the side pieces removed and with  some bungy cord replaced. This way you could put the glasses over your diving mask with just a motion.
The optical quality of these cheap glasses were WAY better than my prescribed glasses in the diving mask (which i also always had problems with heavy fogging).
taking some stronger glasses (like +3 or +4 for me) you will be able to get even closer to your subjects (i am a macro shooter) and see details which you havent seen for years (at least for me - i am 60+)
getting the bungy cord attaching to the frame of the glasses might be a bit fiddly but since the parts are cheap you can play around with it. just get the right length of the bungy cord so its sits firm an your mask - not too tight and not too loose.
enjoy the regained sight
konrad
