Just bought a used X100T, FRAUD ?
Started Mar 19, 2022 | Discussions
Sam Nikon Forum Member • Posts: 67
Hi,
Just got a used X100t, two thing bother me -
1. The lens internal aparture looks weird, is it broken ?
2. Camera won't turn on. The charger blinks green when I try to charge it. (Bad battery)
The second thing is probably a battery issue - but the first pne bother me a lot,
Does the lens aparture look like that or is the a frraud ?
Thanks a lot,
Sam
Was this a fraud ?
Fujifilm FinePix X100 Fujifilm X10 Fujifilm X100T Leica X1
Raymond L
Raymond L Contributing Member • Posts: 674
Re: Just bought a used X100T, FRAUD ?
Can you provide more context ? was this purchase on eBay (paypal) ? or a cash transaction ?
 Raymond L's gear list:Raymond L's gear list
Sony RX100 IV Sony RX1R II Leica M9 Nikon D800 Fujifilm X-E1 +29 more
OP Sam Nikon Forum Member • Posts: 67
Hand to hand with a person. Cash.
Haven't noticed the lens issue when got it,
The battery - as he claimed - 'just needs to be charged'
rsn Contributing Member • Posts: 788
Good news - not a FRAUD
I just grabbed my X100f and the shutter looks just like yours. I'll let you do a little homework on your camera, but that model, all X100 cameras have a "leaf shutter." This is good news but I'll let you do the necessary homework. So your shutter is different than most cameras.
Here's a copy and paste for you:
"The Fujifilm X100 is a huge draw for photographers that are looking for something a little different, but what makes it special has largely been missed in recent years by reviews unfamiliar or unaware of its leaf shutter and built-in ND filter."
Google leaf shutter.
 rsn's gear list:rsn's gear list
Fujifilm X100F Fujifilm X-T1 Canon EOS 5D Mark IV Canon EF 35mm F2.0 Canon EF 85mm F1.8 USM +11 more
Re: Good news - not a FRAUD
Good news !!! Thanks a lot !!!!
A dead battery is probably something I can live with.....
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
5
Why would anyone purchase a used camera with the private seller stating that ‘the battery just needs to be charged’….? Would you want to be able to turn the camera on and snap a few captures?? You could have even tested the sensor for dust - it’s a 10 second exercise. I’m just stating the point as a reference item when reading this thread.
Good questions but other things to consider as well when purchasing a used camera in the setting you experienced. Good luck and please let us know how it works once the battery is charged up.
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
BurpeesAreHard Contributing Member • Posts: 880
This archived web page from the first iteration (but same lens) is something you might find instructive https://web.archive.org/web/20160316192707/http://www.finepix-x100.com/en/story
The X100T needs a battery in it to turn on. But if you have a power source plugged into USB, it should switch to using that power source after a moment.
When the camera is turned off, if you have a power source plugged into USB, the battery should charge from that USB power source.
dezinerd
dezinerd Senior Member • Posts: 1,309
When a battery is severly depleted of charge a smart charger may reject it, ie the fast blink error. Id try the usb overnight to see if that helps. I have in the past just kept inserting the battery into the charger and it finally after a few insertions took off. Some times its just dead. A bright note Adorama has a special on a Greene extreem charger and 2 batteries W126 for less than $30. I had a swollen one that needed to be replaced so I lucked out.
Dennis
 dezinerd's gear list:dezinerd's gear list
Olympus C-2100 UZ Panasonic LX100 Nikon D70s Nikon D200 Nikon D700 +8 more
