Open Camera App (on Nokia G50)
Started Mar 15, 2022 | Discussions
atom14
atom14 Veteran Member • Posts: 3,299
Hi All.
I've been using tho Open Camera app instead of the native camera on the Nokia G50. The main reason is that I can see the image thumbnails when connected to the computer. The native app shows only icons. -- But, that's just the "why". The "HOW?" is as follows:
How can I access the 48MPx resolution mode on the Nokia G50 when using the Open Camera app? Ie, has anybody managed it. The highest res I can get is the 12MPx.
Additionally, I can't seem to select to save as DNG in that app either.
If someone knows for sure that you cannot, then that's OK.
TIA.
atom14.
I2K4
I2K4 Senior Member • Posts: 1,441
Re: Open Camera App (on Nokia G50)
No personal experience but no other answers.  Web search turned up this SourceForge exchange that might be relevant - one post suggests manufacturers configure the API to fail to make 48 mpx available to third-party apps.
atom14
OP atom14 Veteran Member • Posts: 3,299
Thanks, that's interesting. I will have to re-read it again to get a better understanding of the binning, etc.
In fact, I don't really see much "benefit" in the few 48 MPx pics I tried, but might revisit that as well (using the native app). I quite like the Open Camera app, except for its long lag time from shutter press to file write.
As for the DNG output in Open Camera, I found that it's available if I set to use Camera2 API.
Thanks.
atom14.
