Occasional blank images, throw camera in trash or is there a solution?
Started Mar 15, 2022 | Discussions
Blood N Guts Murphy
Blood N Guts Murphy Regular Member • Posts: 362
I get occasional blank/black images. Maybe 1 in 40. Missed a really nice shot today. Using an XE2, pretty old now. Time to throw in the trash or has anyone found a solution yet?
I have seen threads where many have the same issue, but no answer. There is no common thing here, the camera is broken e.g. I use different cards, lenses, SS, aperture etc.. and it always happens. It never happened for a long time. No settings changed.
Thanks.
 Blood N Guts Murphy's gear list:Blood N Guts Murphy's gear list
Fujifilm X-E2 Sony a6400 Sony E 20mm F2.8 Fujifilm XF 27mm F2.8 Sigma 56mm F1.4 DC DN | C (X-mount) +1 more
Fujifilm X-E2
Raymond L
Raymond L Contributing Member • Posts: 674
Re: Occasional blank images, throw camera in trash or is there a solution?
Guessing you don’t chimp ? ! 😀 Guessing you tried the basics ? - New memory card, Raw + jpeg ?
But it sounds like the camera could still be used on non-critical stuff.  Personally wouldn’t throw it away.. and just to confirm the black image has no data ?
 Raymond L's gear list:Raymond L's gear list
Sony RX100 IV Sony RX1R II Leica M9 Nikon D800 Fujifilm X-E1 +29 more
Blood N Guts Murphy
OP Blood N Guts Murphy Regular Member • Posts: 362
Never... almost
Yep
It has exif data, but nothing weird like high SS. I will just be honest selling it and may get £100 as the prices have gone up £100 recently to ~£260.
Wishing I hadn't ordered that XT10 for when I get back to the UK in a few months. Might grab a graphite XA5 for now, curious to see if the Bayer files are better in Lightroom.
Apparently switching to EE may fix it but that's no good to me.
Greybeard2017
Greybeard2017 Veteran Member • Posts: 3,112
Blood N Guts Murphy wrote:
Never... almost
Yep
Can you share a file?
 Greybeard2017's gear list:Greybeard2017's gear list
Fujifilm X-T30 Fujifilm X-S10 Fujifilm X-H2S
Raymond L
Example: Fujifilm X-T100
Raw Files - https://drive.google.com/drive/folders/1D_z287hrgSyyCawd2Xeh1L5YYm2FbclD
Source - https://mirrorlesscomparison.com/galleries/fujifilm-xt100-sample-shots/
Example File:
DSCF0138.RAF - Actually looks great (Adobe LR + default sharpening). Try it out for yourself.
@200%
PT
PT Contributing Member • Posts: 911
Have you tried to bracket exposures, say a third of a stop to see if all the frames are blank or just one in the set ?
 PT's gear list:PT's gear list
Panasonic Lumix DMC-FZ2 Fujifilm X100V Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +6 more
Blood N Guts Murphy
https://1drv.ms/u/s!AlH2T23h5KRS3k2ro1TFAVAOHuhA?e=w3We2e
Blood N Guts Murphy
trying now, it's not done it yet but will continue until it does.
Blood N Guts Murphy
No text.
Blood N Guts Murphy
These look great, thank you.
Now gone from 95 to 99% changing to a Bayer camera when I get home. Might even keep the XE2 for the occasional trip down memory lane and as an ornament. Just missed a great deal on a graphite XA5, but will also add the XT100 to the search.
I know people say Lightroom is cool with Xtrans but even with an XT3 I wasn't convinced. Want to order my Leica CL now but after seeing someone selling a camera with marks on the sensor the other day I am sceptical. Will start a thread about the UK seller. Now I know I can use Fuji Sims on other brands there is nothing stopping me leaving Fuji's crappy left EVFs.
Greybeard2017
Thanks - doesn't seem anything wrong with the file structure - doesn't seem corrupted - just blank (and blank thumbnail and preview images).
Mustafa K Senior Member • Posts: 1,995
Re: SD card issue?
Could it be a SD card issue? Have you tried different SD cards? Do you format the memory cards in the camera? I would change the SD card and format always using the camera before using it.
Mustafa K.
Galleries:
Photos from exhibitions: http://www.redbrook.smugmug.com
 Mustafa K's gear list:Mustafa K's gear list
Nikon D7000 Fujifilm X-T20 Fujifilm X-S10
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Sorry you are so disappointed. Nothing in life should be this serious. Do what makes you happy. Good luck and happy shooting!
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
Temna Zvezda
Temna Zvezda Junior Member • Posts: 34
Any chance you're putting it in your bag while it's still on, or alternatively, it's getting switched on while in your bag, and the shutter is being activated? I ask because this was happening to me. Seems like a most obvious course of investigation?
An other, far more distant connection might be that while this was happening to me, I also appeared to be suffering from a failing shutter button, which eventually rendered the camera unusable and required a trip to Fuji Canada for servicing (still there, it's being repaired, I miss it incredibly). I don't know if there is any connection between the two (the black frames and the failing shutter button) but it might be worth looking into?
Just thoughts.
Without the shadows, we cannot see the light. Music is what happens between the notes. Life is what happens while you're making other plans.
 Temna Zvezda's gear list:Temna Zvezda's gear list
Fujifilm X100V Olympus E-M5 II Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 45mm F1.8 +5 more
baobob
baobob Forum Pro • Posts: 18,248
Before the trash :
reset to defauilt
try different sdcard formatted in the computer using the complete (not the fast one) formatting process
test batteries use different batteries
check for Firmware body and lens
use different format for record (JPeg with without raw, different size)
report
Good luck
Bob
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Morris0
Morris0 Forum Pro • Posts: 32,175
Thanks.
This is a common complaint when a camera's shutter is going to totally fail.  Another common symptom is a frame with part of it dark.
Try taking the lens off and watch the shutter opperate.  You may see it happen.  If you don't observe the problem, try using the electronic shutter and if no issues you know the mechanical shutter is failing.
Even if the mechanical shutter is failing, you can use the electronic one as long as the shutter dose not jam covering the sensor.
Good luck,
Morris
Fujifilm X-T3 Fujifilm X-H2S Canon EF 200mm f/2.8L II USM Nikon AF-S Teleconverter TC-17E II XF 90mm +11 more
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
Thanks.
Good luck,
Morris
Yes, but with the important caveat that it doesn’t work well for motion photography, often resulting in unwelcome artifacts.  For anything else, it’s certainly a decent substitute until the shutter can be repaired.
Jerry-Astro
Fuji Forum co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
baobob
Before to decide than the shutter (MS) is broken  it couild be serviced for lubrif ication
Very few people use a camera till the end of the 150000 actuations. The use of only ES is a problem for fast targets.
