Spring coming (GH6+100-400)
Started Mar 12, 2022 | Photos
Interceptor121 Veteran Member • Posts: 8,691
15
With spring red deer loose their antlers here a few shots taken today with my gh6
Before and after
Mono
In a line
Illusion
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Comment & critique:
Veggiedean DTP Regular Member • Posts: 161
Re: Spring coming (GH6+100-400)
Nice.    The images look good.  I am looking forward trying out the focus limiter (as you mentioned). Also, the now focus transition setup looks like a nice feature.
Dean
dtp-realestate.com
deantylerphotography.com
 Veggiedean DTP's gear list:Veggiedean DTP's gear list
Panasonic GH5 Panasonic Lumix DC-S1R Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Leica Nocticron 42.5mm +8 more
OP Interceptor121 Veteran Member • Posts: 8,691
Today I had a lens that has a physical switch
If tomorrow does not rain will go out with the 50-200mm and use the software limiter
dap35 Junior Member • Posts: 39
Handling comparison?
The photo's look great!   How do you feel about the weight of the GH6 compared to your G9?
Doug
 dap35's gear list:dap35's gear list
Panasonic G85 Panasonic 12-60mm F3.5-5.6 OIS Panasonic 45-200mm F4-5.6 II
Re: Handling comparison?
I use the GH6 in a cage while normally I use the G9 with a base plate, that I remove when I need to use the anchor on the bottom.
Today I had the GH6 in the cage with the 100-400mm a manfrotto 290 aluminum tripod and a second camera bag with the G9 in it (I took it as second when I was doing a timelapse). With this set up I walked around 11,000 steps
So am not the best person when it comes to light gear
It does not bother me personally as my other rig has the camera in the cage with  a top handle and the monopod with the 50-200mm perhaps 2.5 kg and I carry it for long distances
Based on my experience with full frame tele lenses the key issue is the weight of the lens as that induces a torque. The camera body for me makes little difference
My heaviest lens the 200mm i mount an anchor on the bottom and carry it sideway like a bag shotgun mode again the lens is the heaviest part but all in all not that heavy (for me)
Dave in Wales
Dave in Wales Contributing Member • Posts: 901
Love #3, the trio.
Neon Birding
Neon Birding Regular Member • Posts: 197
Great photos of the Deer.
