X-E2: shutter noise/vibration?
Started Mar 12, 2022 | Discussions
Diafine Regular Member • Posts: 116
As part of my transition from m4/3 to Fujifilm, I just picked up a used but absolutely pristine X-E2 (black). It looks nearly unused, and everything seems to function properly, but one thing concerns me.
After the shutter fires, there is a very slight vibration and noise as it resets. Putting the shutter on Bulb shows that the sound/vibration definitely occurs AFTER the shutter has closed, so it doesn't affect exposure or image sharpness. It reminds me a bit of the vibration that would occur in a motor-equipped film camera after the exposure was finished.
My X-T4, in comparison, is nearly silent and completely vibration-free. Unfortunately, I have no other Fujifilm models to compare to. None of my m4/3 cameras have exhibited such behavior.
Again, it's not affecting exposure or image quality; it just bugs me. Is this normal behavior for the X-E2?
Fujifilm X-E2
Yawlen Z
Yawlen Z Regular Member • Posts: 184
Re: X-E2: shutter noise/vibration?
I'm guessing that yes, this is normal behaviour. Just testing my X-E2S with 1" shutters, it shows this too. None too loud though, and not all that different in character from the shutter-reset on an E-M5.2 Olympus, which is the only camera I have around to compare it to. I'll wait to see what response you get next.
Papa48
Papa48 Senior Member • Posts: 4,860
Same when I had my X-E2S. It’s normal.
 Papa48's gear list:Papa48's gear list
Sony Cyber-shot DSC-RX10
OP Diafine Regular Member • Posts: 116
Thanks everyone, much appreciated!
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,178
Normal
Normal.
I have an X-T20 and an X-T4.
The X-T4 has an incredibly improved butter soft smooth dream shutter. I mentioned it in my X-T4 review. When I use my X-T20 now, having made the X-T4 experience, the X-T20's shutter appears clunky.
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Papa48
Re: Normal
Rightsaidfred wrote:
Normal.
Martin
Same for me. My X-E2S shutter sounded a bit like scissors closing and opening again. The X-T4 just softly lops off time.
