Android camera app that allows control of shutter speed but auto-ISO
Started Mar 12, 2022 | Discussions
BarelyAmateur Regular Member • Posts: 369
Friends,
I'm looking for a camera app that will give me the equivalent of auto-iso min shutter speed on an android camera. That is, I want to be able to set the minimum shutter speed, and then have the app select the best ISO given the chosen shutter speed.
I tried the following apps:
  • Camera FV-5
  • Manual Camera Lite
  • ProCam X
For all of these apps, I could manually set the shutter speed, but if so I was required also to manually set the ISO.
Are there any apps that will allow manually setting the shutter speed, but allow the ISO to float to get the correct exposure?
Thank you in advance.
 BarelyAmateur's gear list:BarelyAmateur's gear list
Sony RX100 VA Sony a6600 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sony FE 28mm F2 Samyang AF 35mm F2.8 FE +5 more
Robert Zanatta Senior Member • Posts: 2,630
Re: Android camera app that allows control of shutter speed but auto-ISO
ProShot
 Robert Zanatta's gear list:Robert Zanatta's gear list
Canon EOS 5D Mark IV
OP BarelyAmateur Regular Member • Posts: 369
Perfect. It works. Thank you.
Sugasmune Senior Member • Posts: 1,519
HedgeCam.
You can set min and max shutter speed and save them to preset files.
This also works for exposure bracketing and hdr bracketing. Limiting the darkest and lightest exposure.
