Sleeve for X-T4 + XF 27mm 2.8
Started Mar 10, 2022 | Discussions
Henrique Dias Junior Member • Posts: 28
Hi!
I've been looking online for a simple sleeve where I can put my X-T4 with the pancake lens XF 27mm 2.8 to keep on my backpack.
  • The camera dimensions are (W) 13.46 cm x (H) 9.28 cm x (D) 6.39 cm
  • The lens dimensions are (H) 6.1 x (D) 2.3 cm
I also measured to make sure. So I'm trying to find something that would fit (W) 13.5cm x (H) 9.3cm x (D) 9 cm.
I don't need anything fancy: it doesn't need a strap or to be extra protecting since it will be in my backpack which, by itself, already offers quite some protection. I already looked but what I could find is mostly too large or too small.
Do you have a similar setup or any suggestion?
I appreciate your help!
allineedislight Senior Member • Posts: 1,311
Re: Sleeve for X-T4 + XF 27mm 2.8
I would suggest to simply use the soft sleeve that came with your lens! That is what I use when I carry my X-E1 with the 27mm (and also with the 35mm and even the 18-55mm, it is large enough). This protects camera and lens against scratches and takes up little to no space.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
OP Henrique Dias Junior Member • Posts: 28
That is surprisingly a good idea. Thanks for that!
