RF 16 mm f/2.8 or 35 mm f/1.8 for EOS RP user ?
Started Mar 9, 2022 | Discussions
thunder storm Forum Pro • Posts: 10,139
Re: My RF 50mm f1.8 is gathering dudt since I got the 35mm f1.8
liam J wrote:
I loved the images and bokeh from the 50mm F1.8 but missed having a wider angle and IBIS. The 35mm is the usual lens that I have on the camera as it nearly covers everything with great image quality. Don't know about the 16mm, but I see it more as an interesting but niche lens.
I think this makes sense.
45 is more than enough, but 500.000 isn't
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
Re: RF 16 mm f/2.8 or 35 mm f/1.8 for EOS RP user ?
This is tricky. Ideally, you'll eventually have both. I use my 35 quite a bit more than my 16, but I find the 16 is more fun to use, because it's so different. The 35 is a workhorse of a lens. The main reason to get the 16 first is that you already have the 35mm length covered with your zoom. On the other hand, if you get the 35, you will probably find yourself using it more than the zoom. I have the excellent RF 24-105L, but still use my 35 quite a bit more. I guess I'm saying I can see good arguments either way. I suppose I'd say it's about 55-45 in favor of the 35 first. But definitely plan on getting the 16 as well when funds allow.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
akjos
akjos Veteran Member • Posts: 4,595
ggasquecc wrote:
Hi there,
I've been using a canon EOS RP since 6 months and I'm very happy with it. I bought it as part of an offer with RF 24-105 STM, RF 50 mm STM and a spare battery. Photography is one of my passion but I'm far to be a "pro" and I'm not ready to spent k€ in gears.
I really enjoy using the RP and I'm thinking of buying a new lens. I spent a lot of time reading reviews and forums, trying to figure out what the best lens is for my needs.
I ended up choosing two prime lenses: the Canon RF 16 mm f/2.8 and the Canon RF 35 mm f/1.8. I want a good quality lens for indoor shooting (mainly portraits of my family or friends) and the RF 50 mm is not wide enough for that. So 35 mm seems perfect for me. But it is 35 mm, a focal length already "covered" by my 24-105. Is the quality gap between 24-105 STM and 35 mm really worth it ?
On the other side, although it is not a portrait lens, the RF 16 mm will open up new possibilities to me (I've never used such a wide angle), such as landscape or astrophotography.
So please, based on your experience which one would you choose ?
Thanks a lot.
You really want both eventually … just have to prioritize which one first.  Even though I own both and the 50 and the 24-105 I don’t use the 35 hardly at all but then again I haven’t taken any low light photos last 6 months. 16 is “ fun” lens  and can be very useful in some situations. It is actually very hard focal length to use properly and create meaningful compositions . If you finding yourself constantly wishing for wider then 24mm lens it is your lens. If not get the 35 first I’d say.
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
My RF 16mm gets used a lot
Whenever I leave with just a 24-xxx zoom on my camera, I instantly see something that makes me wish I had my 16mm lens with me. I use it quite a bit.  I also have a 17-40 f4.0L and use it too, but the 16 is so small and unobtrusive that I use it more.  IQ is fine.  Sure it needs to be "corrected" in software, but so what?  I use it for environmental photos of streetscapes here in Louisville, landscapes, whatever I happen to see when I have it with me.    It saved me a lot of money, too, since now I have no desire to buy the RF 14-35 f4.0L.  When I go out, I usually have the 16mm 2.8 on one RP and a RF 24-xxx zoom on the other.  Here are three streetscape shots I took with it over the last few months.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
OP ggasquecc New Member • Posts: 4
Wow, I really want to thank everyone who took the time to reply to my message. All your comments are a great source of reflection and inspiration.
I've spent time to read each reply carefully and have come to the conclusion that:
- both lenses are great options, depending on individual practices and sensibility
- I will definitively buy both as mentioned several times. The question is more which one should I buy first
- I should also consider a bounce flash for my indoor portraits. This is a new thought for me as I've only used pop-up flash so far and really hate the results
So again, thanks a lot for your answers.
SteveinLouisville
A Godox TT350-c is a good option for a small bounce flash.  A Canon 430EX ii, used, is also a good choice.  I got one from B&H in "like new" condition for $125.  My brand new Godox (also from B&H) was $84.
G Rash Senior Member • Posts: 2,890
Similarly, the 580EX ii can be found in good condition for about $120 from stores like Robert's on EBay.  Mine works great, although it is a good bit bigger than the Godox 350 or Flashpoint Mini.  FYI the Flashpoint brand at Adorama is just Godox rebranded.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
tkbslc Forum Pro • Posts: 17,522
580ex is massive on an RP.  I’d go 430EX or smaller.  ISO noise on the RP is good enough that using 800 barely looks different from 100, so you don’t need a monster flash.  I like the EL-100 for RP personally.
Honestly vice versa for me. I only bought the 35 because the 50 didn’t exist yet. 50 is so much more compact and basically same image quality.barely touched 35mm since I got 50.
SteveinLouisville
The 580EX is very large on the RP, for sure.  That's one of the reasons I got the 430EX.  Smaller, and still quite powerful.  I have the EL-100 as well, and like it a lot.  The Godox TT350c is just as small, however, has a zoomable flash head and, best of all to me, can be either a master or slave in the Godox wireless flash system.  It is also about $70 cheaper.
Zeee Forum Pro • Posts: 25,627
I just got the RF 16. It will make a nice novelty/niche lens.
Corners not bad at f 7.1
Our car rental
FP
 Zeee's gear list:Zeee's gear list
Canon EOS R7 Canon EOS R6 Mark II Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +1 more
I’ve used tt350 on both Fuji and Panasonic in the past.  It’s a good flash for the price, I agree.
sportyaccordy Forum Pro • Posts: 20,562
35 @ 1.8 is very different from 35 @ F/4. If you're not sure what prime to get a 35 is always a safe bet.
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
