'22 Junior Biathlon World Champs 16-80, 70-300, X-S10
Started Mar 9, 2022 | Photos
Papa48
Papa48 Senior Member • Posts: 4,861
Re: '22 Junior Biathlon World Champs 16-80, 70-300, X-S10
doak wrote:
Erik Baumgartner wrote:
Very nice set, but they would have been significantly (2 full stops+) cleaner at DR100 with optimal exposure. DR400 won't change the contrast significantly, try setting the highlight tone at -1 or -2 instead (or try D Range Priority).
Thanks much!
I do have -1 highlights as a default setting in my cam. I tried DRP but iirc things looked unrealistically flat & doesn't DRP require some higher ISO headroom just like DRx00?
No, DRP only adjusts highlight and shadow values within the tone curves menu, working together with whatever DR parameters you have set. It does tend to flatten the look.
 Papa48's gear list:Papa48's gear list
Sony Cyber-shot DSC-RX10
OP doak Regular Member • Posts: 244
Re: Battery
a_c_skinner wrote:
How cold was it? A quick Google suggests pretty warm. Klister even?
Saturday started at 10 deg F and warmed to maybe 30 and sunny.
Sunday was a bit warmer but with clouds.
The biathletes skate so no klister.
 doak's gear list:doak's gear list
Canon G7 X II Fujifilm X100V Fujifilm X-S10 Fujifilm XF 18mm F2 R Fujifilm XF 10-24mm F4 R OIS +6 more
rattrr75 Regular Member • Posts: 271
Thanks much!
I don’t think this is correct. Engaging DRP grays out the DR100/200/400 setting. And DRP Weak will set the starting iso to 320 and Strong, 640. I don’t see a way to adjust DR separately from DRP.
 rattrr75's gear list:rattrr75's gear list
Fujifilm X-T4 Fujifilm XF 50-140mm F2.8 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR +1 more
a_c_skinner Forum Pro • Posts: 13,047
Re: Battery
Of course! I never skied enough to learn to skate, but I did wonder if it might help when the wax wasn’t working. Skin skis now of course.
So not that cold so the batteries would not hold up.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
sir_c Contributing Member • Posts: 740
Re: You asked about white balance and brightness…
I shoot raw with awb. Then in captureone i set one image correct and then copy this to all similar ones in the series.
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
